Results 1 to 10 of 10
    Reputation: r18k20's Avatar
    Dec 2010
    Norco Range vs. Seatpost
    Hi all, I知 looking for the consensus on my conundrum. I知 the new owner of a large Norco Range. However, I知 concerned about how much seat post extension I need on this frame. I originally bought an XL but felt too stretched out even with a 40mm stem. So I exchanged it for a large. Is 10 inches of seat post extension too much for a Clydesdale rider? Am I placing the frame, post and myself in jeopardy?
    The Range has a beefy seat tube mast. Does having the seat post inserted past the seat tube still apply? Or is it fine where it is? The seat post in question is a 410mm Thomson elite.
    Thought I would add that I知 62 with a 35 inseam and weigh 215lbs. Intended use of the bike is all mountain riding, hills, small rocks and roots. Nothing too crazy.
    Here is a picture of the bike in question labelled with where the seat post is within the frame.
    Thank you in advance for any help.
    Reputation: Bike Whisperer's Avatar
    As long as the seatpost has the minimum insertion length you should be fine. The Thompson is more than up to your 215lbs.
    You might think about a dropper seatpost for descents to get you off the saddle even more.
    Dec 2010
    Thank you for your reply Bike Whisperer. The shop I purchased the bike from also agrees with you. I知 happy to hear I have nothing to worry about. I probably will end up getting a dropper seatpost in the Spring.
    Given there is 17mm difference in reach or 20mm difference on TTH between the L and the XL, I'm surprised they felt that different, especially with a shorter stem on the bigger bike.
    However, that does look fine as it is.
    May 2005
    Looks good to me..
    Reputation: RossJamis's Avatar
    Aug 2013
    I think your pretty skinny to be calling yourself a Clydesdale...
    When you've seen someone rupture their scrotum on a bike you won't take the standards for top tube clearance lightly!
    Feb 2014
    r18k20,
    don't mean to change the subject, but how do you like your new bike? I am thinking about getting the same model.
    brandon
    Dec 2010
    Quote Originally Posted by beandogg View Post
    r18k20,
    brandon
    Unfortunately there has been snow and very cold weather in my part of the world since I bought it. I haven稚 had much time on the saddle to give an evaluation. The components will get the job done but are nothing special. I can稚 speak for the fork and shock as every time I go out the cold (-15 to -24 Celsius) makes them stiff and unresponsive.
    I will add that nothing appears to be flimsy or poorly built. Norco makes quality bikes. I believe you are best to find a Norco dealer and go for a test ride to determine if the bike is right for you.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Back on the subject: from your pic, your post is not inserted past the main top tube and seat tube junction, but only past the brace/seat tube junction. As a Clyde about your size, I prefer to have insertion past the top tube junction to lower the stress on the upper portion of the seat tube and welds. Sure, the Thomson will handle it but your frame may not.
    My Specialized XXL Stumpy FSR frame actually has an observation hole below that joint to verify the post is at least that deep. I would not be comfortable with a seat post minimum insertion line and would ignore it unless it got the post below that junction. YMMV
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Reputation: Nubster's Avatar
    Yeah...the frame will give before the Thomson will. Pretty sure you could attach a Thomson component to a nuke and it would survive the explosion.
  1. Norco Range LE Carbon
    By pupjohnson in forum Norco
    Last Post: 04-22-2014, 05:24 AM
  2. Norco Range
    By wcrrick in forum Norco
    Last Post: 10-30-2013, 11:36 PM
  3. Norco Range 650b
    By LeeL in forum 27.5
    Last Post: 10-03-2012, 01:53 PM
  4. norco range
    By xy9ine in forum 27.5
    Last Post: 07-30-2012, 04:20 PM
  5. 2011 Norco Range!
    By gregg in forum Norco
    Last Post: 06-28-2011, 04:55 PM
