Results 1 to 3 of 3
    Feb 2012
    Noob Needs Help with Brakes
    Just hoping someone can help here:
    Getting a Kona Explosif 20" Frame and a P2 29er Fork
    Just curious if the frame and forks can support a 203mm hydraulic disc brake both front and rear.
    FRONT Hydraulic - 203mm - Elixir R/X7
    REAR Hydraulic - 203mm - Elixir R/X7
    Not familiar... is it a Carbon fork? Also, Ive been told the power of the brakes has a lot to do with it too, not just rotor size. I have a S-Works Stumpy with Carbon Fork, and recently upgraded to Magura MAG SL Brakes, and was told by LBS to not do a 203, that it was too much for my fork. I went 180 and it still stops hard enough to rip my head off.
    Feb 2012
    its a CrMo rigid fork.
