Results 1 to 11 of 11
    Reputation: Van G's Avatar
    Minimal Bob XC FS for Clyde?
    6'3", 225 lbs, 34 inseam, current is '03 SP SJ FSR Pro, ride with rear locked out most of the time.
    Been parking lot testing several bikes for the Toronto and SE Ontario trails in both 650b and 29 flavours. Haven't been on many XL frams as we're in between right now but I've been on the following FS bikes:
    '14 SC Solo 650b
    '13 Giant Trance 29
    Rode both of them in the stiffest rear setting and I couldn't believe how much bob (plush) these things had. Giving up that much energy on climbs will suck the life out of me.
    A good number of the guys at the shop have said 29 hardtail is the way to go for SE Ontario but I'm looking for rear to take the sting out of going fast over roots, rocks, and small air.
    Can larger guys get this out of a FS ride?
    Van G - Rider of The Don
    '14 Anthem 27.5 1
    Reputation: joe_bloe's Avatar
    See if you can find a GT Sensor. The I-Drive system isn't pretty or sexy, but it works.
    Freelance Whatever
    Reputation: chowdownca's Avatar
    Spec Epic would work too. You can stiffen up the rear so that only that it would take more of a shot to open up.
    What I do for a living doesn't define me....
    I'll check out the GT. Epic has the 'brain' I assume which seems like a good solution if it works all the time.
    Anthem/Maestro accomplish same sort of setup? Stiff climb, suck up the bumps at speed?
    '14 Anthem 27.5 1
    Freelance Whatever
    Not quite...from my simple understanding of it, they use "anti-squat", similar to DW Link designs to sit you a little down in the travel and use that to counter any pedaling forces that would usually cause pedal bob. It's a short link design that Giant mimic'd...if you google "DW Link" there will probably be info overload...they work pretty well too...if you get a test on the GT, I would be interested in your opinion as we don't have a dealer around here. Heard that it's a pretty good set up
    Got a chance to ride Anthem 27.5 1 in a large. Although being cramped I was impressed with the suspension. Nothing like the Solo.
    Given the Anthem is a XC setup with only 100mm of travel, I'm assuming I can still take small drops and jumps without issue?
    '14 Anthem 27.5 1
    Are you sitting and spinning or up out of the seat and mashing on the climbs?
    When I can, sit and spin but a good chunk of the short climbs makes more sense to stand and mash to keep the section going. Also find I need to stand in the tighter switch backs.
    '14 Anthem 27.5 1
    Then you'll get bob no matter what you ride. Given the energy you expend standing and mashing you are not wasting that much through the rear suspension. A short travel FS tends to work best for the racers who are sitting down as much as possible as it enables them to remain sitting whilst pedalling, so making them faster over the ground. I ride a Turner Sultan and the DW rear seems to cope well and not bob too much.
    Nice ride. Also considering Trance 27.5 to get a little more travel and slightly more upright position.
    '14 Anthem 27.5 1
    Here, diagonally!
    Reputation: JACKL's Avatar
    Quote Originally Posted by Van G View Post
    Definitely demo the I-drive. I personally find it quite amazing that even with a loose rear shock, I can stand and hammer it on the street and it just flat goes with no noticeable bob or lost energy. I had to pass on the Stumpjumper because of the pedal bob. I don't want to flip a shock lever on the trail, I don't want to maintain a brain, and I still want my rear suspension to work while pedaling up a hill.
    Anything that you demo, take note of how much compression damping the rear shock has and how plush it rides. Increased compression damping will make a bike pedal better, but it of course makes the bike less plush on the trail.
  1. Minimal drivetrain options
    By HelmutHerr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-17-2012, 04:45 PM
  2. Why do cyclists like insoles with minimal padding?
    By beanbag in forum Apparel and Protection
    Last Post: 05-16-2012, 10:16 PM
  3. Flash Carbon . Seatpost minimal insertion.
    By Yustas in forum Cannondale
    Last Post: 12-08-2011, 01:01 PM
  4. Most minimal shin guards for brush
    By IPA Rider in forum Apparel and Protection
    Last Post: 08-04-2011, 02:18 PM
  5. Which brakes for minimal dead band and big power?
    By edgerat in forum Brake Time
    Last Post: 01-21-2011, 10:13 PM
