Results 1 to 12 of 12
    Looking for a fork
    So I had to take a hiatus from riding for a while but I need to get back at it and back into shape.
    So I'm back to my predicament....I NEED a new fork. I have a Giant Trance X4 XL. I'm 6'8" and about 240lbs. I am in the market for a new fork, I need lockout and a thick axle. I'm okay with spending about $400-$500. I have been researching for a while but honestly there are so many variations and what not that I just can't figure out what I should get. Thoughts....opinions...suggestions??? Thanks!!!!
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    What year is the Trance?
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Sorry, that would help. 2010
    Nothing? No suggestions?
    Nov 2008
    Manitou has some nice choices in the price range. Tower Pro is a great fork. For a mid range fork, the Manitou damper is just as good or better than anything out there.
    Jun 2013
    My 2014 Trance 3 came with the rockshox Sektor fork. It is air adjustable, has rebound adjust and lockout but that is it. I am at 250# and have been working it pretty hard and it is holding up. I don't have anything to compare it to as far as how good or bad it is, but I am satisfied with it.
    Manitou tower is the go-to fork for the bigger folks. Google Clyde fork for more answers
    Reputation: joe_bloe's Avatar
    Quote Originally Posted by Sasquatch1413 View Post
    I believe the Trance is a 26'er, if I'm not mistaken. So that would mean Minute, not Tower. I WOULD second that recommendation, in the form of the Minute Expert 130mm, if I could find one with a through axle. All of the ones out there are 9mm QR.
    Looks like your best combination of price, through axle, straight 1-1/8 steerer, and 120mm+ of travel is the Rockshox Sektor RL. Comes stock with 150mm of travel, but you can reduce that with spacers. ChainReaction and other places have them for about $450.
    It's a 26'er unfortunately. And mine came with a basic fork with no lockout and a weak spring...
    Thanks for the suggestions so far! I've been looking at the Sektor. Will the 15mm maxle still being a QR be rigid enough? Right now I get a bit of run when I pump hard.
    I was looking at this fork the Manitou and from my reading if you are heavy like 280 you need stiffer springs and they are harder to come by. What is the best option for a heavy rider if you do not want to fool with fork springs or are you better of changing springs no matter what you buy?
    On the Manitou how long is the stock steering stem and is the newer setups with the bigger bottom bearing on the stem better?
    Jun 2013
    Everything I have read and been told. For us heavier riders it is very difficult to get e spring that will work well and air is the way to go.
    I am 260+ and have been using a Fox Talas 36 (160mm) fork since 2007. You could probably find a more recent model year of this fork for your price range (used). The 20mm front through axle really stiffens up the trackin and it has on the fly travel adjustment. It will require a front hub conversion to 20mm or a wheel switch but it's worth it. My 2 cents
  1. OPINIONS: Aluminum rigid fork or suspension fork for 9yr old's bike?
    By dragbike in forum Families and Riding with Kids
    Last Post: 05-09-2013, 05:06 AM
  2. Replies: 21
    Last Post: 01-13-2013, 09:06 PM
  3. Replies: 0
    Last Post: 07-24-2012, 07:22 AM
  4. Replies: 5
    Last Post: 09-12-2011, 04:13 PM
  5. Salsa Cromoto 26" fork to replace 100mm travel fork
    By rth009 in forum Shocks and Suspension
    Last Post: 01-03-2011, 09:51 PM
