Results 1 to 7 of 7
    Aug 2010
    Killed My 819 rear whats next?
    250+6'3 cracked the sidewall is the 823 really that heavy ? think it's next maybe 36 hole 4 cross?
    Reputation: bvibert's Avatar
    Mar 2006
    How did it break?
    Aug 2010
    How did you break it?
    What tyres are you running?
    What tyre pressure are you running?
    What style of riding?
    How old are the wheels and how active are you?
    Aug 2010
    Most likely from catching some air.
    Geax Sturdy 2.25
    35 psi
    XC,All Mountain,Urban,Street,Park
    The wheels are a few years old. I'm doing around 50 miles a week.
    Aug 2010
    Good job!
    hhhmmmmmmmmmmm
    Mavic EX823 36 or 32 hole
    Hope Pro 3 hubs
    Sapim CX-Ray spokes
    Brass nipples
    Hand built with a high spoke tension (not a factory build)
    Serviced every 6months by the wheel builder to ensure spokes are in good condition and rims are true
    These should last you a lifetime....
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    I am also 250lbs and 6'3". For UST on my do-it-all bike, I decided to build a rear wheel with a EX823 (with a sturdy also) instead of a XM819. If you are bashing and getting air occasionally, 823 will be more secure at your weight. I use 819 for the front, and for F/R on my XC hardtail.
    Yeah, fairly heavy, but, then, so are we.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    All the spokes in the world won't stop you from cracking a sidewall. I had some 717's do that. The fatal failure was the spoke bed splitting lengthwise between three spoke holes, but the sidewalls were cracked on both sides along most of the circumference of the rim where the sidewall meets the middle section of the rim.
    In my case it was me running too large of a tire at too high pressure. I was running Nevegal 2.5's over 40psi and weighed about 280 to 300lbs at the time.
    The 823's are 205g heavier than the 819's and the tire size recommendation for the 823's is 2.3" to 3.0".
    At your size and riding style, if you're determined to run a Mavic tubeless rim, I would go with the 823. Laced with 32 Sapim 13/14 spokes to a Hadley/CK/DT-Swiss rear hub, and I think you'll be good to go. 36h wouldn't hurt, but it doesn't seem like that is really your issue.
  1. I killed my rear shifter
    By Jarl in forum Beginner's Corner
    Last Post: 01-02-2007, 12:21 PM
  2. Whats your air pressure in rear?
    By prod in forum Specialized
    Last Post: 03-23-2006, 10:49 AM
  3. whats the best dh/fr rear shock...
    By ice_kha in forum Downhill - Freeride
    Last Post: 12-10-2004, 07:26 PM
