Results 1 to 17 of 17
    Kahuna VS. Mahuna
    im 350lbs 6ft, Im looking into the Kona Kahuna and Mahuna. Cant really tell the differences other then the price. and some of the specs. Had a rigid frame Diamondback (1990)a prevous bike. Local bike shop carries Kona but nothing in stock, but will order what model i want. I know nothing about the newest bike tech, Some help me make a decision.
    Tkx
    Ben
    Reputation: crossracer's Avatar
    Kahuna VS. Mahuna
    The biggest thing is the fork. At your weight you are going to need an air fork. The mahuna does not have an air fork, I can't remember if the kahuna has one.
    I'll be at the shop tommrrow and we have both in stock I'll check it out and see what I can find out. I'll check back thur and let you know.
    Bill
    thank you, I did spend some time at the local Kona shop, one guy said get the Kahuna, with all the bells, the other said Mahuna and have some $ for upgrades. We talked about tubeless wheels, and tires, because of my weight and how i plan to ride. So for the present time im leaning towards Mahuna then some upgrades as i ride. But the problem, they dont seem to be getting any Mahunas in anytime soon, but they can get the pricer Kahuna
    Kahuna VS. Mahuna
    Tires and tubes arnt as important as a good shock that can handle your weight. If the fork doesn't work, the rest of the bike won't work well either.
    I'll look them over side by side tommrrow. I'll also call kona and see what the aviability is. Maybe the mahuna isn't an option right now. I'll
    Let ya know
    Bill
    Kahuna VS. Mahuna
    Yea, checked both bikes and both forks are not air. So if you go mahuna then spend the extra money on a good fork with air settings. That's just my opinion, but at 350 lbs I'm really thinking you need a great fork up front.
    Good luck. Bill
    Good deal Mahuna it is. Time to plan some upgrades. So should i just ride as is, till it fails? What forks with air do you recommend?
    If your on a budget, try asking the shop what shocks they can get you with a discount since you are buying a bike. If not, check review sections here, figure your budget, and chceck out the online retailers.
    At your weight, any good shock within your price range that can be aired up to handle it will ride better for you. Then put the old shock on craigslist, someone might give you some money for it.
    BIll
    Kahuna VS. Mahuna
    Hey, I just saw the thread over in suspention forum called upgrade your suntour shock. They have a program where they will upgrade the shock on the mahuna to a air one for not to bad of a price.
    Check it out
    Hope this helps
    Bill
    thank you very much
    is this the thread you speak of?
    If you want to upgrade your Suntour fork
    Kahuna VS. Mahuna
    Yepper. Good luck. Keep us posted
    Bill
    and to think my current bike has a rigid suspension
    can rule out the 26" ones
    "Forks currently available through this program include the following SR Suntour models
    Raidon LO R Air Disc Blk 26 $150.00
    Raidon LO R Air Disc Blk 29 $175.00
    Epicon TAD 15Qlc 150-110 Disc Blk/White 26 $250.00
    Epicon LO R 15Qlc White 29 $275.00
    Axon RL 15Qlc Blk/White 26 $300.00"
    Raidon's only 9mm axle?
    man all this new stuff to research
    well i got a response from Suntour rep. he recommends the Raidon series
    Kahuna VS. Mahuna
    Awesome. Is this still keeping you in your budget? If so sounds like a good plan.
    Bill
    budget haha, only budget i have atm is to get my fam Dr off my back at the next visit, so im pulling alot of my hair out, jk, everything is within reason to meet goals....
    Not impressed wit the LBS i ordered the Mahuna, but now i have a bike. Need to get some seat time to adjust seat rearward. So far FUN.
    Ok time for me to do some up grades, DMR Vault pedals, OEM arent wide enough for my 12EEE, Wasnt too impressed with the OEM seat, so a ISM Adamo Road saddle is enroute also
    Loving these DMR vault pedals, and took some getting used to ISM seat. Put some time riding, looking forward to put alot more as soon i get the bike mount on my pickup done.
    Loving every ride i take on it...
  1. 2013 Big Kahuna vs the Kahuna DL
    By wldcat2 in forum Kona
    Last Post: 08-15-2012, 07:26 PM
  2. 2011 Kona Big Kahuna versus 2012 Kona Big Kahuna
    By andyczerwonka in forum 29er Bikes
    Last Post: 06-26-2012, 10:38 AM
  3. Kona Kahuna or King Kahuna frame weight
    By Triaxtremec in forum Kona
    Last Post: 04-05-2012, 11:11 AM
  4. mahuna
    By Richard_ in forum Kona
    Last Post: 01-25-2012, 07:43 PM
  5. Kona Kahuna vs Big Kahuna
    By nathan_b in forum Bike and Frame discussion
    Last Post: 07-24-2011, 11:44 AM
