FAT BIKES
WINTER APPAREL
TRAINERS
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 87
  1. #51
    Reputation: twowheelsdown2002's Avatar
    Quote Originally Posted by walangkatapat View Post
    LaceMine29 recommended a 36 spoke Hope hub built rear wheel for this over 240lb clyde.
    After breaking so many hubs, including one Sun Charger Pro, and one Sun Charger Expert, I got very leery about trusting the Sun Black Flag Pros on my R.I.P.-9 29er.
    I replaced my Black Flags, with a set of Hopes lace to Flow EX rims. This is also a better match, because I wanted to run the Ardent 2.4 tires, and a wider rim is better for tires this wide. I wanted the Ardent 2.4 tires, not just for the size, but because they have very thick sidewalls, which I hope will help my other problem which is ripping tire sidewalls.
    I like technical, rocky trails. Freewheels and tires take a beating on that terrain. Hopefully the Hopes hold up well.
  2. #52
    Reputation: Bike Whisperer's Avatar
    Bang for buck (keeping price, service, and freehub body material in mind) look at White Industries M16
    -Steel axle
    -Steel pawls (3) and 24 point ratchet
    -Steel freehub body
    -5 bearings
    All for about $250 for the rear hub
  3. #53
    Reputation: protsi's Avatar
    Dec 2010
    I need a Clyde-proof rear hub/freewheel!
    I have 3.30 hubs from stand and hold me really we'll No complain so far,
  4. #54
    Dec 2010
    Here is a pick
  5. #55
    Track Junkie
    Reputation: Octane's Avatar
    Quote Originally Posted by Bike Whisperer View Post
    -Steel axle
    -Steel freehub body
    -5 bearings
    I really appreciate the recommendation! Great choice!!!
    I'm on yet ANOTHER (different) wheelset now, and I am expected to ruin the rear wheel within the month.
    I'll get me one of these White Ind MI6 hubs on order ASAP for my wheelbuilder to put together.
    Thanks again!
    -Octane
    I get paid to ride shotgun.
  6. #56
    JDM
    JDM is offline
    Reputation: JDM's Avatar
    I'm on the third year with my white industries MI6 hubs after chewing through 2 to 3 shimano freehubs per year.
    In addition to the reliability, I like that the WIs are fairly quiet.
    Also, I called WI to order spare bearings, pawls, and springs, just to have rebuild parts on hand before I need them. The phone was immediately answered by a friendly, knowledgable human.
  7. #57
    ... grew up with a Sachs 3-speed as a kid
    ... downhill Zee hubs should be good, right ? still brezel broken free hubs
    ... back to 3-speed hub ,put shimano sg-3d55 on fat bike
    ... added a 1/8 track chain
    ... happy as a kid
    good IGH , Rohloff 14-speed
    , sachs cargo P5, sturmey archer 3's, shimano nexus 3
    figured I'd share
  8. #58
    Reputation: Gus69's Avatar
    Nov 2012
    I've just killed my second rear hub in 5 months. first it was a noname but today it was a XT 785. The cassette body and pawls first got loose and then stuck completely.
    And yes I am a clyde and I grind the bike uphill using just as much torque as pro riders, I just weigh 80% more than them.
    Since I live in Europe, I'll see if I have to save for a CK or someone told me to look at DT Swiss 540 Tandem if I can find it at a fair price.
  9. #59
    hi gus69, my buddy riding a dt-swiss, crashed due hub failure. still not riding again.
    some say chris-king, or trails-hubs, for the cassette hubs.
    otherwise, single-speed. on friend on fat bike went rohloff, I'am riding 3-speed.
    all these are 210-260lbs single track mashers .
  10. #60
    Nov 2008
    DT swiss 350 or 440 hub with 16T star ratchet. Bullet proof freehub mechanism.
  11. #61
    dt 350 on my tallboy lt. holding up great. i weigh 300#.
  12. #62
    Quote Originally Posted by Gus69 View Post
    XT M775 have been known to be troublesome, since the M785 is nothing more than the "10 speed" version I would expect the same. Look at the SLX M675 hubs. Stronger freehub body (32 poe) and steel axle (vs aluminum).
    Another option in Europe is HOPE, they are made in the UK and usually cheaper. So much that many US buyers buy directly from UK retailers. Add a steel freehub body for bomber durability.
  13. #63
    Oh, I've GOT bike money
    Reputation: JACKL's Avatar
    Quote Originally Posted by evasive View Post
    I've been riding Hope Pro 2 Evos for 15 months. After 5 months (last August) I destroyed the alloy freehub body. Hope offered me a stainless body as a warranty replacement, and were great to deal with. Two months ago, I exploded two of the cartridge bearings. For reference, I'm 230 lbs, riding a Banshee Prime with a 2x10 drivetrain. I'd say they're reasonably strong hubs, affordable and easy to work on. But not bombproof, in my experience. I'm not bailing on Hopes, but I'm going back to DT Swiss for my next rear wheel.
    I'm 225, very strong, ride technical terrain and get some air now and then. I had a very similar experience with my Stan's 3.30 (non HD) hub. I distorted the aluminum freehub where the pawls meet the hub...apparently just applied too much torque to it. I'm not aware of shocking the drivetrain, but I'm sure it has happened in the heat of battle. Stans was great about it and sent me a steel freehub. I've been through 2 sets of bearings in the last 1.5 years. I went to 1x10 6 months ago and have not had any issues since. That may not be related, but the peak torque I can put to the hub is reduced.
    No complaints about the Stan's hubs as I do beat on them very hard and they are easy to service, but my next bike will have a 142 rear so I can use the Stan's HD hubs.
    My friend has Hopes and personally they are just to loud for me, but he doesn't mind.
    Octane, good luck in your search for a bomb-proof hub.
  14. #64
    Nov 2012
    One very dead Shimano XT 785 freewheel. Broken into 12 pieces (that I found). 2 Pawls not broken, 1 partly broken, 2 completely missing.
    And plenty of balls and grease.
    From what I can see pawls have broken and got stuck so the complete body breaks into pieces....
  15. #65
    Old Fart
    Reputation: Scubapiper's Avatar
    Aug 2005
    I blew up at least 1 hub / year until Dave @ Dave's Speed Dream Wheels built me one with a hope hub. 5+ years, 1 rebuild to replace bearings, still going strong.
    If you say gullible slowly enough it sounds like "oranges"
  16. #66
    Jun 2013
    im 300lbs, got a DT Swiss 240 and its still alive.
  17. #67
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    On my 36er I first used a deore hub the cassette driver lasted 7 miles twice and I switched to Industry9 no problems since and thats thousand's of miles ago now O and Ihit the scale arround the 300# mark. On my other set of wheels I used CK but I had to switch the driver about 1500 miles in.
    PAYASO 36er.....Live the Circus
  18. #68
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Dec 1969
    Quote Originally Posted by schnee View Post
    Gotta say, if you're a big clyde and ride rough, avoid the Hope rear hub.
    I was 300lbs. at the time, and I literally ripped the freehub off of the shell of a Hope hub pedaling up a short, sharp hill in granny gear.
    I am also a destroyer of rear hubs and considering a 12x142 build. I am curious if you were standing at the time or sitting.
    Anytime I've killed a Shimano freehub body ... I've been in the standing position (at least for the initial "event" ... they tend to limp on for a while after before they die). I have a personal policy against standing climbing in the granny. There is just too MUCH torque there.
  19. #69
    Dec 2013
    I'm starting to wonder about the CK ISO's at this point. I have two CK wheel sets on two different bikes, one XC and another AM. I'm 222 standing in the shower and a fairly fast Clyde at that. I've had engagement issues on both of the CK's and they seem to love to skip on me at sub 50 degree temps more so then when warm. Already changed out the bearings in one of my CK's and still had it skipping on me today during my first two climbs. I run a 36th 1x10 with oneUp 40th conversion for my XT cassette which according to one old timer xc guy today looked at me and said "good for you big guy" when he saw the 36th up front haha I'm going to investigate a little further but I'm starting to think maybe giving an I9 hub a shot.
    BearGrease Bluto
    SB95c EnveAM Pike140
    ASRc RS-1 120 EnveM60 XTR 1x11
    ARCc RIP
    They don't make these things for big boys!
  20. #70
    yo whut up ya,ll ..............not sure if anyone has mentioned it yet but im usung a Hadley hub (ON ORGNAIL STAN FLOWS W/DT SPOKES ), DONT KNOW A WHOLE LOT ABOUT THIS MTB THANG BUT IM 335LB 6'5.5 RIDING A CARBON HT 29ER AND AFTER 2 RIDES SO FAR THIS THING IS SWEEEEEET ( OH I GOT IT USED ABOUT 400MILES GUY SAID), IT SOUNDS AWESOME TO ! ALL THO NOT AS LOUD AS SOME OTHER , I9, CK, ETC
    Ride hard everytime....or take up hiking...........lol
  21. #71
    Dec 2013
    Quote Originally Posted by DABIGSEAT View Post
    Hope your Carbon HT frame is A LOT tougher then the two I had,......cracked both of them under normal XC pedaling and I'm only 235ish geared up
    BearGrease Bluto
    ARCc RIP
  22. #72
    willtsmith_nwi
    Dec 1969
    Quote Originally Posted by some dude View Post
    I've had engagement issues on both of the CK's and they seem to love to skip on me at sub 50 degree temps more so then when warm. Already changed out the bearing in one of my CK's and still had it skipping on me today during my first two climbs. I run a 36th 1x10 with oneUp 40th conversion for my XT .
    3 thoughts ...
    1) once CK hubs engage ... they cannot slip.
    2) after break in ... you need to adjust the hub preload. Failure to do so can cause prevent the hubs from engaging properly.
    3) the CK manual specifically addresses cold weather maintenance. One needs to add a few drops of Tri Flow to keep their lube from jelling or freezing.
    I ride at 340#. I've had the hub briefly "skip" a few times. Then I adjusted the preload and it didn't happen again.
  23. #73
    Dec 2013
    already adjusted the pre-load a couple of times on both sets of CK Hubs and serviced them with fresh grease by LBS who's a CK snob/freak.
    BearGrease Bluto
    ARCc RIP
  24. #74
    Reputation: SeaHag's Avatar
    Fresh grease or not, the fact that you say it gets worse in the cooler temps leads me to believe the grease is a little too viscous. Though I don't have CK hubs, I've had similar problems with other freehubs and their ratcheting pawls that was resolved with a shot of penetrating lube spray then working the freehub by hand till the ratcheting mechanism consistently hooked up. Certainly wouldn't be a hub bearing problem.
  25. #75
    Jon
    Feb 2014
    Profile hubs take a huge beating, and are available in every configuration possible except fat. I beat the crap out of mine and never broke anything and when I say beat them I mean jumping on curbs with pegs and slamming into walls.
  1. Your clyde-proof 29er build
    By HelmutHerr in forum Clydesdales/Tall Riders
    Last Post: 04-21-2013, 08:02 AM
  2. Recommendations. Tough heavy duty rear mech for 7/8 speed old school freewheel
    By brumbrum in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2013, 07:02 PM
  3. Rear wheel- Cog vs freewheel?
    By Dr.Mushy in forum Singlespeed
    Last Post: 11-26-2012, 10:43 AM
  4. Any Freewheel 16" Rear Wheels?
    By BullSCit in forum Families and Riding with Kids
    Last Post: 05-26-2012, 10:19 PM
  5. What Type of Freewheel for Avenir 20" Rear Wheel?
    By ACHTUNG! in forum Families and Riding with Kids
    Last Post: 05-10-2012, 06:40 PM
Follow MTBR on Facebook
