Results 1 to 7 of 7
    I need a 80mm or 100mm fork
    currently riding an 03 Kikapu with the stock MX Comp ETA fork 80mm of travel. i think i can go up to 100mm at most as 130mm would be way too much travel for the frame.
    what do you recommend i try and look into, i would like to try and keep it under 350.00 if possible and i don't care if it is air/coil or just coil
    2003 Kona Kikapu
    would a 115mm Rock Shox Reba w/ 115mm travel be too much for the frame? pricepoint has them for decent price and everyone seems to be raving about them here
    2003 Kona Kikapu
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    You're pushing it at 115
    I think that's a bit much, but I would check the A/C height on your current fork and measure that against the reba and see just how much effect it will have on geometry. In general, it's a huge jump, IMO. It's almost a 50% increase in travel. That's definitely on the high side.
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    reba is adjustable from 85-115 from what i can figure out. so that would work if i dropped it down a bit.
    i think i am going to order one unless it would not be a good fork for me
    2003 Kona Kikapu
    I have the 115 version of the Reba and it came with spacers to reduce it to 100. Unfortunatly that requires disassembly of the fork so I would try order one in your desired configuration. It is a great fork though. Very stiff and adjustable.
    Chris
    ordering the SL U-turn now or the Race, i can't decide
    2003 Kona Kikapu
    Got my Reba SL U-turn today, much nicer fork than the MX Comp ETA i have now, can't wait to get it installed
    2003 Kona Kikapu
