Results 1 to 51 of 51
    S-Mart's Top of the Line
    Reputation: H3LlIoN's Avatar
    Bonking ... not feelin' well I just pancaked another wheel, need advice...
    Alright...firstly, I'm looking for advice from urban, park or downhill riders. While all advice is appreciated, if you ride XC and trails, your experience probably doesn't apply. No offense meant, just please specify what style of riding you do so I can weigh your experiences in context.
    Here we go! First ride of the year (unfortunately)...it was 65 today and I had wrassled my bike out of the shed last weekend, so I figured I'd finally get to clocking some miles. I ride a lot of urban...staircases and what not, and we also have a pretty sick woods park here. Anyway, I'm back on the bike to lose some more weight (last year was slow for me on the bike, and I put some weight back on.) Anyway, last year it was an Alex wheelset....met it's match when I dropped a staircase. My LBS hooked me up with what's labeled #MACH 1 XC-TYPE 2.10, and I was riding....flew down a hill and messed my timing up on a bunny hop...curbed the hell out of it, and it's got a REALLY nice flat spot. Normally I'd cruise over to my LBS.....but they closed last week and I don't like either of the other two shops. It will be this weekend before I can get to another shop I like (20 miles away.) I was wondering if anyone here abuses the hell out of their equipment and, if so, what holds up? I don't care about the weight....I'm already 250, so another 5 pounds isn't even going to matter. I just don't want to have to keep blowing money on wheels.
    Are you riding a 32 spoke wheel?
    turtles make me hot
    Reputation: NYrr496's Avatar
    I weigh 260 and ride trails. I'm chiming in because I'm also pretty hard on equipment. Like XL29er said, if you're on 32 spoke wheels, you're gonna need to go to 36. I just went to 36 spoke Salsa Gordos and was able to back off on the spoke guage a little. My last set of 32 spoke wheels looked like motorcycle wheels, the spokes were so fat.
    I like turtles
    TBH I don't know. I'll count them when i get home and get back to you.
    I do a lot of urban riding, stairs, and big drops to flat, rocky landings. Also, being in Central Texas, our trails have rocks out the wazoo, so my wheels take a beating, especially given that I run with 22 PSI, so the rims do occasionally meet rock. I've slammed right into granite walls & dropped onto limestone boulders with my Mavic 823, 36 hole rims without any issues. Not the cheapest or the lightest, but it doesn't sound like you need light rims anyway. They are very solid rims, and I highly recommend them. Also, look into getting a high-volume tire so that they'll soak up some of the impact. I've found the 2.4 DMR Moto's make a great urban tire with lots of volume, and run 2.4 Maxxis ADvantages on the trail, which have a ton of grip & higher volume than most 2.5's & 2.6's. Be sure to also make sure your spoke tension isn't too high. I generally build my own wheels, and had the opportunity to sit in with a very good, experienced professional wheel builder during my last build, and he said he favors going with a little less tension on big-hit builds because they will give a little more before denting or flattening. I was skeptical at first as he built my 823's up with much less tension than I had used on my XC set, but the ride is amazing & the wheels have held up to some bad landings very well. Good luck. Hope this helps.
    And FWIW, I have a buddy who also launches big stuff, and he loves his Azonic Outlaws. I can't personally vouch for them like I would for the 823's because I haven't ridden them, but they seem to have a reputation for bombing.
    I don't think casing curbs is agressive riding it's poor riding. Nothing is going to hold up to poor technique resulting in plowing into things. Throw your weight into the equasion and stuffs going to break.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    If you don't run enough pressure in a tire, you can find a way to ruin most rims. Slamming into a curb is one of those ways, one of the best ways.
    That said, I don't think (at least from the info I could about the Mach 1 XC Type 2.10 or whatever your ill fated rim was) that rim was meant for that level of abuse. If it has "XC" in the name, it's likely meant to be an XC rim for XC level use. Dropping stairs and slamming curbs is not XC type riding.
    And I don't think 36 spokes instead of 32 wouldn't have made a difference either. It would be stronger, but won't suddenly become immune to that sort of input.
    Grab a Mavic EX 729 or an EX 325 and see what you can do to them, but run an appropriate tire with appropriate pressure so the rim stands a fighting chance.
    I'd be thrilled to weigh 250lbs and I can ride into curbs with my EN 321 wheels by just pulling up a little on the bars on a full suspension AM bike with a 6" travel fork. This leads into my next point:
    Your profile says your bike is a Hardrock (an entry level XC bike). If so, that is not a bike designed for dropping stairs and slamming curbs. My guess is that after buying beefy enough wheels, you're going to find the next weakest link, and then the next weakest link until you snap the frame.
    If I may offer my $0.02,: Get a dirt jumper or another type of beefy bike that is meant for the type of riding that you do.
    Quote Originally Posted by DekerfTeamST
    While I agree, wouldn't you rather have a larger margin for error by having a burly rim? Even the best riders occasionally case something. $h!+ happens even on familiar trails & routes, like when a rock on a tranny has been kicked up or wasn't there before pops into the equation. Technique plays a huge roll in keeping parts intact--don't get me wrong--but I'd rather have the confidence of a solid wheel than plan on everything being smooth as butter and end up in the middle of a trail with a tacoed rim because of something I didn't see or expect. Not saying any rim is invincible either, because they're not. But a little room to make mistakes seems better to me than hoping my technique never fails me.
    I have a old set of ryno lite dh rims with 14 gauge spokes put on phil wood 36 hole tandem hubs. not light in weight, nor is the rider....plus I seem too like at least a 2.4-2.5 width tire. a bit more cushion. gravity really works aginst me but ya gawta have good wheeles too hold ya up.
    My technique isn't 100% on all the time. If yours is, good for you...have a cookie. It was my first ride of the year and I was sloppy. Dick.
    I checked spoke count, sure enough 32. My tire is only 2.0, so I'll definitely check in to getting something with more volume. I run the pressure between 50 and 60 psi, as I used to pinch flat all the time. I'll also have to check in to the spoke tension and the wheels listed...I appreciate all the constructive advice. I'm hoping to get down to the shop tomorrow so I can see what they have available and meet the tech there. I'm hoping to start building my own stuff so that I don't need to rely on the shop so much.
    Quote Originally Posted by jeffj
    I do indeed still ride the hardrock comp. It's hardtail....I don't like full suspension. I will eventually buy a new bike, but I have a lot of expensive hobbies (guns, cars, scuba, skydiving, snowboarding, etc) so a $2000 bike is tough to fit in. I am saving up for it though. I don't even know if I can find a hardtail bike build for big abuse. I'd like to stay specialized, but all their big bikes go to FS.
    Reputation: Supple1's Avatar
    Quote Originally Posted by H3LlIoN
    My technique isn't 100% on all the time. If yours is, good for you...have a cookie. It was my first ride of the year and I was sloppy. Dick..
    I don't think he was trying to be a dick, but just say you can only expect so much out of your gear. You can build a bike stronger, but at some point things will break if they are abused.
    Going to a 36 spoke wheel will increase strength, and look for a rim that is made for DH/freeride. Azonic outlaw is probably a good bet at a lower price point. Bigger tires will help a lot, definitely a must.
    There are a number of hardtails that can take plenty abuse, use the search to look for all mountain or downhill/freeride hardtail. The frame you are on is definitely on limited time with the way you ride (not trying to be offensive, it is just not the right tool for the job).
    And don't buy anything with an XC label on it
    Hope that helps
    R.I.P. DogFriend
    Here are a few to look at:
    http://www.specialized.com/us/en/bc/...FPark%2FStreet
    http://www.specialized.com/us/en/bc/...Park%2FStreet\
    http://www.konaworld.com/bike.cfm?content=stuff
    http://www.konaworld.com/bike.cfm?content=cowan
    http://wheelworld.com/product/kona-2...frame-7472.htm
    http://www.gtbicycles.com/bikes/moun...a-bomba-orange
    http://www.gtbicycles.com/bikes/moun...ckus-dj-yellow
    http://www.redlinebicycles.com/bikes...vice-d26-frame
    Thanks for the links...most of those are urban/DJs which tend to be really small in my experience. I've been on the kona and the specialized and they are nice, but just tiny. I'll check that Five-O out though, that looks solid. Might be time to give somebody else a try. Thanks!
    I'm going to check out the mavic posted and the outlaws for this bike, and ride it like that until I can get something else built or bought. I know it's not the best tool for the job, but she's held up well this far, and hopefully will until I can get something else.
    Mar 2005
    Go custom. You could maybe find a DH wheel that will fit your frame, but I've seen 100 lb kids case some burly stock Halo wheelsets (he had a set of 8 foot elevated skinnies in the back yard, so... yeah).
    For maximized flatspot resistance, what you really want is to eliminate dish (as much as possible), use a lot of butted spokes at high tension, and pick a rim that is as vertically stiff as possible (meaning its tall, more than wide). To eliminate dish, you want to go with a single speed or internally geared hub, meaning you have to change some other hardware too. You can maybe use multiple cogs on a single speed freehub (I think you can run 5 using 10 speed shifting, or 4 with 9 speed).
    Turns out frame won't take more than the 2.1 that I have on there now. It's looking like I might just build up another, heavier duty bike. Pity though....this frame has handled close to 1500 miles of my abuse without complaint.
    May 2005
    How many wheels have you pancaked ?
    All same brand on same bike ?
    2. different brands. First was stock Alex wheel that came on the bike...second was whatever XC thing I listed above. Will try and identify it better when I get home. Same bike. Different ordeals. First one I flattened jumping down a set of stairs. Second one I cased a curb. Both times I was running 2.1 dred tred @ max PSI.
    As far as high volume tires go, does anyone have any experience with the Maxxis hookworm? 26 x 2.5....thinking about putting a set on the beach cruiser since I don't like the white walls.
    Hi H3lloN, here's my two cents:
    First, I weigh from 185 - 200 lbs. in my riding gear. Yes, I do consider myself an urban rider. I've ridden light bikes with narrow rims, and my current bike is a heavy bike with wide rims. The lightest I've ridden was my under-21 lbs. KHS Alite aluminum hardtail, single-speed, front suspended, with Sun CR-17 rims that were low 400 grams. My current bike is a 31 lb. Giant STP dirtjumper with Sun MTX rims that are 660 gram rims.
    I've tacoed rims, I've dinged rims, and I've flatspotted rims.
    Here you go:
    1. YOU can only determine how burly you need to go by YOU breaking stuff. Other people's opinions are helpful, but your particular needs are unique. I am not an abusive rider and can get away with lighter stuff than many "hack" riders, who indiscriminately plow through stuff and have lazy, lousy technique.
    2. If breaking stuff is how you learn, then money and affordability is key. Talk is cheap, but very few people actually do grams-per-dollar-saved analyses and spec spreadsheets like I do. Rims by Mavic and DT Swiss are not cost-effective IMO.
    3. The rim is where it's at. 36 versus 32 spokes is a non-issue where strength is concerned. Look at all the high-dollar all-mountain wheelsets like Specialized's Roval, Bontrager's Rhythym, and Easton's Haven: They're using 28 and even less spokes. Most downhill wheelsets are using 32 and less spokes. Crankbrother's wheels are a testament to this. The rim plays the most significant factor when it comes to strength.
    4. The conclusion to all this is that if you learn by busting rims, then the best way to proceed is to buy inexpensive rims that you can swap out, yourself. Go light and move up the ladder. Two key considerations: 1. Stay with the 32-spoke format. The majority of hubs and rims are 32-spoke. Going to other formats will limit you, immediately. 2. Pay attention to ERD (Effective Rim Diameter) dimensions. If you stay near a certain ERD number, you can swap different rims without needing to buy different length spokes.
    Additional points:
    - Is the gram-counting worth it? When it comes to wheels, you'd better believe it. A heavy wheelset will seriously limit your range and airborne activity. Carrying unnecessary rotational weight is a great way to anchor you down, and it's actually very easy to do: heavy innertubes and tires abound. Those Hookworms you're thinking of? 1,150 grams, each. That's about 3/4 lb. heavier than something like a Kenda K-Rad or Kiniption. Are you sure you need to add 1.5 lbs. to your wheels? The MTX rims on my STP? If they're overkill for me, then what was the 140 lb. teen I bought the bike from thinking when he threw $400 down for what his buddies probably told him was cool and the norm for "serious riding?"
    - Weight specs are very tricky. Even manufacturer's specs are sometimes off. Online stores aren't always so accurate, either. Universalcycles.com is a big offender when it comes to accurate rim weights.
    - Your Hardrock frame? Bummer about the poor tire clearance, but IMO, depending on the year those frames are very trick and burly looking. I'd ride it till it breaks, if it actually does.
    - Here's a link for Mach 1's rims: http://www.mach1.fr/uk_composants/index.html
    - One thing is for sure about the MTX rims I have: I can ride them with full confidence. They are very heavy, and I could easily get by with RhynoLites, which are a full 120 grams lighter, but the MTX's are unbreakable for my ability level.
    - If you truly want burly without having to really think about it, Alex's DM rims are a real value.
    Thanks for the post! Couple things...the hookworms are for the beach cruiser, which doesn't get airborne (often.) Not sure why I posted that here, but that's still worth considering when it comes to rotational mass. I'm going to have to decide what I plan on doing with that bike before I choose a tire. Also, you mentioned the Alex wheels...the bike came stock with Alex DM20's, and that was what I bent the first go around. Is there something better from them? I've been looking at the outlaws which, for the most part, are 32 hole, but I knew nothing about ERD...I'll check that out. Luckily most of this stuff is on closeout cheap on Ebay...my LBS closed and the two that are left I don't like spending my money there. I agree on the hardrock frame...it's been a great frame, and it's not going anywhere any time soon.
    If you're going to use Hookworms on your beach cruiser, they supposedly get incredible traction and roll quite nice.
    Just looked up the DM20's: they came stock on the 2004 Rockhopper (I guess that's what you have?) and are 535 gram rims. I'm not sure what the ERD is on them, because they're not listed on Alex's site, but I'm sure it'd be close to some of Alex's other offerings:
    - DM 18, 600 grams
    - DM 24, 660 grams
    The Mach 2.30 Disc rims (can't find anything on the 2.10) are 500 gram rims. Not super burly by any means.
    DM 18's will cost you $20, each, plus shipping from Universalcycles. DM 24's are $24. You could simply mail-order these rims and probably lace them right over to your existing hubs and spokes, assuming your spoke lengths weren't changed when you went with the Mach 1 rims. Universal also has a sale on Sun Singletracks, which are pretty burly. They're 590 grams, but they're arguably a stronger rim than a DM 18. The ERD is about the same, too. The next step up in substantial strength, IMO, would be MTX's at $39. However, because they are so triangulated the ERD is a lot smaller, and you'd have to get shorter spokes.
    Some points, here:
    - At 32mm wide, the DM 24 rims will float your tire sidewalls out, enough, that clearance might start to become an issue. An MTX is 34mm wide.
    - Just making a vague observation, but the DM 20 and the Mach 1 rim seem to be out of the proper category for any 250 lb. person doing jumping. They'd definitely be doable for lighter people, or if you weren't jumping, but for you it seems they're in an unsuitable category.
    - Azonic Outlaws are pretty highly rated wheels, but they are a wheelset, not just a rim (I'm sure you can get just the rims, but haven't heard of it). AND, they typically come for 20mm thru-axle forks. They have adapters available for use with standard qr forks, but if you get these wheels make sure they come with the adapters and will work with your fork and frame. Somebody on either here or Pinkbike or Ridemonkey is selling a set of Performance Loco (same thing) wheels for low $200, I believe. Pretty good price.
    I think your biggest problem right now is one of clearance. I'm surprised you don't think your frame can handle more than a 2.1 tire. You might want to search other threads and ask Rockhopper owners what they're running, because if clearance is an issue that will be a problem for getting a wider, stronger rim. If you do have the clearance, the simplest thing for you would be to buy DM 18 or Singletrack rims and go from there.
    Let us know what kind of stairs you're going off, too. How many steps are able to do? Are you doing flat to flat, too?
    Mine's an '04 hardrock comp. That's a great price...I might look in to that! Thanks again for the tips. I still have the old DM, so I have the spokes from it that I can use. I don't really think the guy that sold me teh mach1 was listening, since I explained what I was looking for clearly but, at the time, I didn't really know any better. I'll take a look at the frame...but it really doesn't look like I could fit something bigger. I'll google though and see what's up.
    Yes on flat to flat and jumping "up" too. As far as what kind of steps, I'm not sure what you mean. If it take it literally, then brick stairs, concrete stairs, and exposed aggregate. My normal ride involves a set of 5 steps. Sometimes there is a triple set of 6 I like to hit. I could probably do more, but I don't want to push the bike and have it end catastrophically. I also need to get a better helmet before I get more crazy.
    Oh boy, 6 steps is about 3 1/2 feet, and if you're doing that regularly I really think your time on that Hardrock is limited. I do think that your biggest problem, right now, is that your frame won't be able to handle the rolling gear you should be running. Well, the simple route is to just get a replacement rim and see how long that lasts you....
    Yeah, when I was asking about the type of stairs I meant how many steps.
    yeah. In the time I've had it, it's had three rear cassettes, a crank set, and the new rear wheel. As it sits right now, it needs another cassette, another rear wheel, brakes, and another crank. That's kinda why I'm leaning towards building a five-o to be bulletproof. Care to weigh in on that one?
    R.I.P. DogFriend
    I watched a friend of mine fold up a two week old Outlaw wheel on a small nothing type jump. Not really impressed with them TBH. He's been on Mavic 729's and Sun Doubletracks ever since with no problems.
    You can get the Doubletrack rims for about $40 and the MTX 33 for $30 at Cambria Bike Outfitters right now.
    http://www.cambriabike.com/shopexd.asp?Item=100049822
    If you need spokes, the cheapest place I know of right now is danscomp
    Sapim straight gauge 14g spokes are $.25 and double butted are $.40 each. If you're wanting to use 12mm long nipples though you'll need to get them somewhere else (if you get the MTX 33 rims at Cambria, just get the nipples from them) as Dans only stock 14mm and 16mm length nipples.
    If you can get the MTX33 for $30, and your spokes for $.25 each, that will be a cheap strong wheel you can beat the snot out of for about $43 worth of parts (plus rim tape).
    If you're going to be thrashing wheels, you may as well learn to build your own wheels sooner rather than later. It's more about being disciplined than it is voodoo. Give it a try.
    Check out these links:
    Wheelbuilding resources
    http://miketechinfo.com/new-tech-wheels-tires.htm
    Jeffj,
    Have you verified that you can actually get mtb length spokes from Danscomp.com? You know that's a BMX shop, right? That's an incredible price for spokes, but if it's only BMX length spokes then....
    Also, 729 rims weigh 675 grams, and DoubleTracks weigh 850 grams! I don't mean to come across as a weight weenie (I have suffered from grammitis, please be merciful to me), but I'm not even sure Josh Bender could bend a DoubleTrack?
    H3Lllon, sorry, I don't know anything about the Five-o. You mentioned that dirtjumpers were too small for you? I don't know your height, but I'm 5'11", and my Giant STP is big enough for me and could probably fit someone up to 6'1". The biggest issue is the seattube is low, so getting enough seatpost extension is the problem. With my 400mm seatpost at max extension it's just adequate. For urban riding I run it a good 3 - 4" lower than that, though. However, if you do urban, dirtjumper frames are very hard to beat. My STP is supposed to be pretty unbreakable. Also, the geometry will hands-down whip anything with normal length chainstays (16.7" and longer). It's solid, it's nimble and maneuverable, and it's not twitchy. Want to buy the frame?!!!
    Nov 2008
    My brother lives close to Dans Comp and has purchased spokes for 26" and 29" wheels he's built up. I think Dans stocks uncut spokes and they cut and thread them as needed.
    R.I.P. DogFriend
    Quote Originally Posted by Tim Blabbing
    Jeffj,
    I have bought spokes from danscomp for a 26" wheelset I built for a friend last June and just a week or so ago, I directed a friend there for spokes for a 29" wheel I then rebuilt for him. Just that you'll need to get the nipples eleswhere if you want 12mm nips. He had to order them over the phone, but it was no problem.
    Wow! Great news about those spokes. Those really are impressive prices.
    Jeffj, the Sapim spokes supposedly come with nipples; are they just not 12mm nipples?
    R.I.P. DogFriend
    They did when I purchased spokes back in June 2010. When I had a friend order from them a couple weeks ago, I told him about the nipple dilemma (is there such a thing? he asked when he called and they still only carried 14mm and 16mm nipples, so he told them not to worry about sending nipples. I am not positive they were going to include them for free as they did when I ordered from them previously.
    Maybe it's just the geometry I don't like on the urban bikes...The ones I've been on have all seemed squirly to me. Seat height isn't an issue, I slam the seat on mine anyway, almost always riding with it all the way down unless I'm on a long road ride (30+ miles). In the woods, it's always slammed.
    Quick question...the Five-O has an integrated headset....Can I easily swap that out for a conventional bearing assembly, or will I be stuck with it? Thanks
    That sounds like the way to go for me...I'm going to try that. The fact that I have discs is only pertinent when considering hubs, right? That matters not for the actual rim, correct?
    Just looked up the 2011 Kona Five-O. That headset is a Zero-Stack type. You cannot swap it out for a traditional headset. The thing is, most headsets worth having and keeping start around $40, anyways (there are a few exceptions, like FSA's Pig, which really is heavy), and the cheapest, most available Zero-Stack headset you'll find on the main mail-order sites is the Cane Creek ZS-3, which goes for $40. Zero-Stack has not been popular, but there's always been frames with them and headsets for them. They are more popular in Europe. You can find quite a few Zero-Stack headsets on Chainreactioncycles.com.
    Concerning the rims, you are practically correct. Because disc rims don't need to deal with rim pads squeezing the sidewalls in, they can redistribute the material to make it stronger, elsewhere. There are "disc-specific" rims, but for the most part any rim can be used on a bike with disc brakes. For you, any rim sturdy enough is what you need.
    My Jamis has a zero stack headset and I really like it. No worries or problems with it in the last 3 years.
    I noticed you looked up the '11....the frame I'm considering is an '09. Same thing?
    Also, concerning integrated, I've read that they require more maintenance and are a "weak link." True?
    R.I.P. DogFriend
    Zero stack is not the same as 'integrated', it is referred to as 'semi-integrated' and they are different from each other. My Giant Reign (as well as many other Giant bikes) has a semi-integrated headset as does my current Access 29er frame.
    The cheapest zero stack (semi-integrated) headset I know of is this one:
    cane creek vp a41ac
    http://cgi.ebay.com/VP-Cane-Creek-A4...item33657382cd
    They go for about $10+/- plus shipping.
    I have read a lot of complaints about these, but I have been beating the crap out of mine several times a week for a year and a half. If you can spare a few more bucks (about $40), go for the Cane Creek ZS-3.
    As for durability, my son has been beating on his Reign for almost five years with no headset issues. . . . .
    Or, Woodman makes this one for about $32:
    http://bike.com/woodman-axis-sicr-comp-headset-headsets
    Granny Gear Abuser
    Reputation: bentcog's Avatar
    Aug 2010
    SunRingle MTX 33! I am 250. My bike (with said rims) is another 38 and I ride with a pack of goodies. I ride, DH, AM, XC and rails to trails. I had them made for me last year mid-season and you cant kill them! The are really nice for the coin. I am thinking I will never have to replace one so there is my $0.02 for you and your quest.
    I am not worn out, I am just taking my bike for a walk!
    Just bought the double track. It's heavy, but it had a ton of great reviews, and it's welded, as opposed to the 33 which is sleeved. I figure I'll ride it on the rear until I lose some of this damn weight, then switch to something lighter, and keep the doubetrack as backup. I need to order spokes, but I have to do some reading first, because I have no idea what I'm going. Plan is to string it to the cannondale delta hub that the mach1 is currently wrapped around, unless there is something terribly wrong with that. The other choice is the joytech aluminum from the Alex, but I'm guessing the cannondale is better. Is there any reason I would want to replace the hub?
    Also, since I'm going to be building this thing anyway, I wanna replace my rear gears since 4 out of 8 are stripped. Do I want a cassette though, or a freewheel? Also, does anyone have a suggestion for a durable set? I spend a lot of time off the seat, and I like to use my legs as opposed to my gears, so I chew the teeth off of the gears pretty quickly. Thanks dudes.
    R.I.P. DogFriend
    You want a freehub (used with a cassette), not a freewheel.
    I have issues with some cassettes (ruined three XT cassettes) and prefer some cheaper cassettes that have proven more durable for me. My cassette of choice is the Shimano CS-M580. If I wanted/needed a cassette with an aluminum spider (for use on rear hubs that use an aluminum freehub body), I use a SRAM PG-990, which have been using for the past year with success.
    As for the hub, I am always a concerned about rear hubs for clydes and since you even have cassette issues, I have to wonder if your freehub is not long for this world. The downside is that hubs that are known to have at least pretty good durability for clydes are pricey and pricier.
    mtnbiker 72 found some Transition rear hubs on sale for $40 (regularly $99) and says they have been reported to have decent durability. There are two different models on sale, but both are 36h, not 32h, so that depends on whether or not your Double Tracks are also 36h.
    Another rear hub I have heard good things about is the Shimano Saint. The M810 is available in 32h or 36h, 10mm axle or 12mm axle (yours likely would use the 110mm axle) and will work with a standard rear derailleur (unlike some earlier Saint rear bubs). They are made for centerlock rotors, so you would need to use centerlock rotors or use an adapter. I saw an FH-M810 in the 10mm axle 32h configuration on ebay for $65.
    For more popular choices for durable rear hubs, the most budget friendly one that comes to mind is the Hope Pro II that can be found for less than $200 and then maybe the DT-Swiss 350 (the cheapest DT Swiss hub with the start ratchet freehub) that can be found for less than $250. Those both come standard with aluminum freehub bodies, but I know the Hope Pro II can be had with a stainless steel freehub body and it will cost another $75 or so for that option.
    There you go, clear as mud, simple as pie ;~)
    honestly both the joytech and the delta have held up great so far. I've never had a complaint about either one, and they've held up great to the abuse. Cassettes, like I said, I go through because of my particular technique.
    So I would want something like this, correct?
    http://www.cambriabike.com/shopexd.asp?id=91011
    Thanks for all your help too.
    Mar 2011
    I would vouch for the Hope Pro II option with the stainless steel free-hub.
    BUT I would also suggest you get the Saint compatible version of the Hope Pro II which is essentially a 10mm hollow axled 135 width hub. Use this with any 10 mm solid steel bolt on through-axle. Avoid quick release. The solid steel axle keeps everything tight and prevents Hope's aluminum hub axle from flexing under stress. It also removes the need for double rows of bearings that you see in some hubs which are essentially there to compensate for excessive axle flexing in the first place. The weight penalty is less than 100g. The bolt through axle I use is the Fire Eye rear 10mm. Info from :
    http://www.chainreactioncycles.com/M...?ModelID=39200
    or any other 10mm bolt through axle.
    With regards rims - I would also go with 36 spokes if possible and you should be looking at 700g + rims : for example
    http://www.alexrims.com/product_deta...3&cat=3&id=191
    or Halo SAS :
    http://www.chainreactioncycles.com/M...?ModelID=12317
    ride safe...
    P.S. the double track rims are also very good
    P.P.S. I f you want to stay with a hardtail the strongest jump/ freeride bike I know is the Chromag Stylus :
    http://www.chromagbikes.com/frames/stylus
    Alright. I guess it got missed. I already ordered a wheel...it's the 854g Doubletrack in a 32h welded design. I'll be using the cannondale delta hub that I already have, since it works fine and holds up great to my abuse. I just need to know what I'm looking for if I need to replace the cassette. I've never done it. Thanks.
    Mar 2011
    Nothing wrong with the Doubletrack rim.
    I'm unfamiliar with "Cannondale Delta" hubs - to be honest, I didn't even know that Cannondale made hubs.
    It might be made by somebody else...
    Either way it appears you are looking for an 8 speed cassette - for 8 speed gearing. Unfortunately, since 9 speed systems are now the most common the only 8 speed cassettes left on the market are low priced, mid to entry level models. I have no idea which is the strongest amongst them. The one you mention would work.
    Best of luck
    Bummer.
    Anyway, thanks for the input. I reckon I'll give that one a try and see how it holds up.
    According to UPS, wheel will be here Friday. I've already talked to the LBS and have an appt for wheel truing after I build it. (I don't have a stand yet) They are cool enough to let me watch too though, so I can see how to do it. Can't wait to be back on the spec'd....this single speed crap is kicking my ass, and the $100 beach cruiser isn't fairing too well.
    package was sitting on my steps this morning....friggin dwarfs my mach1. Now I gotta figure out spokes. Thanks for the help guys.
    local jackass
    Reputation: biggoofy1's Avatar
    Im 6'8 285 and ride aggressive i was constantly bending rims so I picked up a set of Mavic DeeTracks and I love them been on them for over a year now and havent even needed to get them trued. I highly recommend them!
    His
    2010 FSR XC
    2010 ALLEZ
    Hers
    2012 Myka 29'r
    2009 Cannondale Synapse 5
    Down East Cyclists
    H3LIIon,
    Don't say I didn't warn you about clearance issues!!!
    We'll see. Right now I'm going through the trials and tribulations of trying to figure out how to build a wheel. I have the general process down, but I can't find measurements on the cannondale delta hub, so I have to measure the thing myself.
