View Poll Results: What rear hub have you destroyed, OR what hub has refused to die
Voters
67. You may not vote on this poll
  • Killed a Chris King
    5 7.46%
  • Chris King has refused to die
    24 35.82%
  • Killed a Hope
    11 16.42%
  • Hope has refused to die
    10 14.93%
  • Killed a DT Swiss
    11 16.42%
  • DT Swiss refused to die
    10 14.93%
  • Killed a Phil Wood
    3 4.48%
  • Phil Wood refused to die
    4 5.97%
  • Killed a Hadley
    3 4.48%
  • Hadley refused to die
    4 5.97%
  • Killed a White Industries
    5 7.46%
  • White refused to die
    3 4.48%
  • Killed a True Precision
    0 0%
  • True Precision refused to die
    1 1.49%
  • Killed an Industry9
    4 5.97%
  • Industry9 refused to die
    4 5.97%
  • Killed an unlisted number
    18 26.87%
  • My hub refused to die. I will post the brand
    4 5.97%
Multiple Choice Poll.
Page 2 of 2 FirstFirst 1 2
Results 26 to 32 of 32
  1. #26
    Nov 2008
    Just found that I cracked the freehub shell on a 170mm hope fatsno rear hub. It was aluminum. Good news is that Hope quickly sent a free steel upgrade. We'll see how that lasts.
  2. #27
    wanna be
    Reputation: bigmariow's Avatar
    While trying to clean a rock problem a few years ago, I stripped the threads out of a Hugi 240 freehub/shell interface. I sent it back to DT/Swiss, and they replaced it no problem, even though it was over 5 years old. The person I talked to said they had never seen that failure before. I was on that wheel that day because I was waiting for a replacement axle for my King. I have turned the pawls on multiple other shimano/mavic/oem hubs to dust. 10 plus years on my current Chris Kings with minimal maintenance
    mario
  3. #28
    Tires
    Reputation: Gritter's Avatar
    Dec 2010
    Killed a Shimano Alfine 11, because it was such a piece of sh*t. (This forum shouldn't censor my mild words)
    Soma, Surly, Salsa, Schwalbe, SRAM, Sun-Ringlé
  4. #29
    Reputation: Bigb2000's Avatar
    May 2013
    I exploded a new Hope Evo 40t on a climb. Toasted the outer bearing, inner axle, and 3 of the pawls. Quickly replaced by Hope.
  5. #30
    If your experience is similar to mine, you will be in contact with Hope's customer service fairly often. Good thing is their CS is top notch.
  6. #31
    Feb 2010
    Blew through about 6 Shimano hubs. Got a Chris king and it hasn't given me a bit of trouble in 4 years. 325lbs + gear
  7. #32
    K&K
    Reputation: ki5ka's Avatar
    That seems to be the consensus.
  1. The Ultimate Destruction Thread!
    By Hawg in forum Off Camber (off topic)
    Last Post: 11-16-2013, 09:00 AM
  2. complete rotor destruction!
    By aizu1 in forum Brake Time
    Last Post: 11-20-2012, 07:49 AM
  3. Destruction Derby
    By Shytie in forum Off Camber (off topic)
    Last Post: 10-10-2012, 08:14 AM
  4. Epic destruction?
    By airdonut41 in forum Specialized
    Last Post: 07-26-2011, 08:11 AM
