Page 1 of 2 12 LastLast
Results 1 to 25 of 43
    Slave to the grind
    Reputation: cherrybomber's Avatar
    how many fingers do you use for braking?
    hey fellow Clydes!
    as i sat upon my ummm throne reading back issues of MBA i saw an article on how you should position your brakes. ideal set up is to use just the index finger on the end of your brake levers
    really?
    i grew up on canti's even before Vbrakes came in. levers were built for 4 finger braking. even then you wished you had more fingers.
    with the arrival of V brakes and later on mechanical discs, levers were then built for two finger squeezing. sadly when doing downhills i still ended up in the bushes during sweeping turns. hehehe.
    aanyway here's my question- since we are stopping more mass and inertia, are your bikes adjusted for 1 finger braking or do you stick with 2?
    personally im perfectly happy with two fingers.
    Let it flow, let yourself go, slow and low, that is the tempo.
    Oct 2010
    2 fingers...unless I'm about to blow a turn and then it's 4 lol
    Reputation: 4nbstd's Avatar
    Unless I have to come to a sudden stop from a high speed, I use 1 finger. 220 lb on rigid with BB7.
    Ghisallo Wheels
    I'm really good looking.
    Two fingers, Index and middle after all they are the strongest fingers..
    To prevent any mistakes and optimize power and control I always set my levers about 40mm from the grip.
    Sometimes a little less if the bend of the bars does not let me.
    I started out a 290 now down to 265. I used/use 1 finger for my ElixerCRs, 1 and 2 with the Elixer3s, and finally back to 1 with my SLX M666s.
    I stick with 1 finger other than emergency braking.
    2011 Dawes Deadeye | 2011 Niner EMD9 | 2012 Santa Cruz Tallboy AL
    Reputation: Joules's Avatar
    Quote Originally Posted by cherrybomber View Post
    hey fellow Clydes!
    really?
    yes, really. I consider disc brakes incorrectly setup if you would ever think you needed more than your index finger.
    True, it wasn't possible to set up cantlivers to work that way, which is one of the big reasons no one uses them anymore. It's probably time to stop comparing modern bikes to the crap we had to live with 20 years ago, except in a "remember how bad things used to suck?" sense.
    Rep power- More than Hawg
    Reputation: Tone's's Avatar
    Only one finger should ever be used to stop a bike and theres a very good reason that the DH pros n gun riders use one finger.
    If you use two or more(using more than two is ridiculous n dangerous for you) is that if you have less than 4 fingers holding onto your bike its not enough to control the bike safely under load.
    Breaks have come a long way, i use hydros and you only need 1 finger to be enough to throw you over the bar at speed.
    V breaks are basically a stone age breaking system and are compared to the other systems we have, they will be phased out on mountain bikes in the very near future, in fact they have been on middle to high end models as you all ready know.
    Mechanical disk breaks will also be phased out in the near future too, i still have them on a few bikes but they do not rival hydros for stopping power, but still should only need 1 finger.
    If you need more than one finger to stop on a dime its time to think about new breaks.
    Your breaks should be set up so that your wrist is straight in the attack position, this is different for a few people but generally 1/3 of the way towards the ground, i have mine lower than that as i like a small cockpit/top tube on my bikes ..
    Im not a clyde but im not small either, but regardless of size the same rules apply, in fact the bigger you are the more you wanna be using 1 finger due to the fact you have more weight to support and you need all the fingers wrapped tight around those grips you can
    cheers
    They actual lever should be moved toward the stem far enough that you can only put one finger on the end of the lever whilst holding the grip.
    If you break with 2 fingers it only leaves 2 fingers and a thumb to take your weight and control your bike under load if you are doing hard riding or DH.
    thats fine for riding a flat trail or riding round the park but not for any serious or challenging riding.
    PARRAMATTA EELS R.L.C Life member- BLUE AND GOLD NEVER FOLDS..
    'Lifes not about winning or losing, lifes about choosing'
    Quote Originally Posted by patineto View Post
    On the top pic, im not sure how you use those breaks efficiently with the levers being so far away from the grips??
    But nice bike, love the flat black mate, just how i like em
    Quote Originally Posted by Tone's View Post
    Oh they work awesome, just give them a try, You still have the leverage of a full size handlebar since you hands are at the very end of the grips..
    Oh man that was a lot of work, but yes end up looking pretty nice.
    Reputation: freighttrain48's Avatar
    I have shimano XT brakes and I use one finger guess which one
    Large and In Charge
    Reputation: RideEagleCO's Avatar
    Nov 2012
    One
    Nov 2012
    Juicy fives, two fingers
    I do all my bikes the same way because it works.
    I also tend to stick with certain brands (like the Hope brakes) and stay with them because the work really well plus they are really easy to work on..
    But sometimes is fun to try something very different like this "STI" shifters.
    Reputation: NYrr496's Avatar
    I brake only with my index fingers. My brakes are set up with the levers mounted inside of the shifters.
    Works great for me.
    So far, every time I set up a bike like this for someone else, they take to it and leave it that way.
    I like turtles
    Dec 2004
    1 finger on Elixir CRs. Sometimes go to 2 fingers on Hayes Sole.
    some know me as mongo
    I would say that I setup my brakes for 1.5 finger braking. 90+% of the time I only use 1 finger but I have it setup so that I can also comfortable get a second finger on for those LONG downhills that require LONG periods of braking. I don't have it setup this way for more power but for fatigue reasons. your rotor size should give you the power you need. If you are putting more than one figure on most properly setup disc brakes you will be over heating the rotors. That is the reason I run a 200mm rotor on the front and a 180mm on the back.
    Just some food for though.
    All 4 I'm using old fashion levers with V brakes and grip shifts no problems so far even with a touring load. V brakes are stiff springs they could be stiffened more for heavier riders.
    "Dish is illogical." Spoke of Vulcan.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    1 finger. You really don't have to pull that hard on quality modern hydraulics. And the difference in grip on the bar between 2 finger and 1 finger braking is significant. Try holding onto something with your ring and pinky fingers versus middle, ring and pinky. Yeah, the middle finger is one of the strongest. That's why I want it around the bar.
    "Back off, man. I'm a scientist."
    - Dr. Peter Venkman
    Reputation: Fourtango's Avatar
    Mar 2012
    1 finger since I switched to XT's. they're amazing
    inexperienced at large
    XTR trail brakes, one finger is all I need for them.
    Sent from my Desire HD using Tapatalk 2
    Feb 2010
    New hope x2 with goodridge hoses gives me all the power I need in one finger...
    My Rides:
    Mountain Cycle San Andreas VPS
    Mountain Cycle Rumble Ltd.
    Mountain Cycle Battery
    GT STS-2 Carbon
    GT LTS
    Reputation: Bsin80's Avatar
    One
    Ski N Bike Tech
    Reputation: SkiNBike's Avatar
    I'm 325 and use two fingers with Avid SD7 levers attached to BB7 calipers. I also use compresionless housing with teflon coated cables. Stops my fat ass on a dime.
    Nov 2012
    I just started riding but I use two fingers, it just feels right.
    Climbs = necessary evil
    Reputation: rogerfromco's Avatar
    Just one. 225 lbs with XT brakes on a RIP9 and Avid Juicy Sevens on SC Nomad.
Hot Deals
Contests
Latest Mountain Bike Articles
