Results 1 to 3 of 3
    Reputation: dragoon's Avatar
    Oct 2011
    Hollow-Pin strength vs Solid?
    I'm a 245 pounder, and have a hollow-pin KMC laying around that I'm considering using.
    Thoughts regarding the strength and longevity of a hollow-pin vs solid, for the bigger guys?
    Former Bike Wrench
    Quote Originally Posted by dragoon View Post
    Pin pull strength is the same, it would be the plates with the cut-outs that I'd be worried about twisting if you happen to force a shift under power.
    Reputation: mestapho's Avatar
    Hollow pin strength is a little less in this chainbreak test by Wipperman
    the starred * results are hollow pin chains.
    Link
  1. swapping axle (hollow QR with solid one) on HB-NX70 dynamo hub - possible?
    By bikeisbetter in forum Lights DIY - Do It Yourself
    Last Post: 09-29-2012, 11:50 PM
  2. Redline SS hub from solid to hollow
    By sheaminator in forum Wheels and Tires
    Last Post: 09-12-2006, 12:23 PM
  3. Pike 454 or 426 ? ALLOY vs. STEEL hollow crown or solid?
    By Znarf in forum Shocks and Suspension
    Last Post: 09-03-2006, 07:59 AM
  4. Stiffer? Reba solid crown or hollow crown?
    By sdmike in forum Shocks and Suspension
    Last Post: 12-17-2004, 05:45 PM
  5. Hollow or Solid Axle??
    By Warp in forum Wheels and Tires
    Last Post: 07-20-2004, 09:04 AM
