Results 1 to 5 of 5
    bigger than you.
    Reputation: Gigantic's Avatar
    Dropper Seat Posts: Strong Enough for Clydes?
    the downhill sections freak me the @ out do to my high center of gravity- I'm 6'8 & 263 #s. Are dropper posts strudy enough to handle clydesdale weight and abuse? Anyone here using them? What brands are best?
    Reputation: Joules's Avatar
    I'm about 240, and have had pretty good luck with a Reverb. The bike I had it on, the seat tube failed, but the post was fine.
    Had a Joplin before that, which... was a crank bros product, that is to say had a bunch of problems. But none were structural.
    I have nothing negative to say about my reverb, but with Thomson entering the game next spring, I'm waiting for that before I get another.
    Reputation: fishrising's Avatar
    Mar 2012
    Riding a 2011 Specialized Command Post. I'm 6'7" 230ish pounds. Have never felt nor seen evidence of failure with the post itself. I do need to tweak cable management for my post though. As sometimes it will not stay in the lowest of the 3 positions due to how the cable twists. You can actually see how/why it happens and it has to do with how the cable is routed. I need to change that just haven't gotten around to it.
    Reputation: Nate3510's Avatar
    I did a lot of research and I ended up going with a Gravity Dropper Turbo. What I like about it is that it's 100% U.S. made and it can be completly disassembled and rebuilt and put back together in less than 20 minutes. Plus since its all mechanical there is no bleeding to worry about. I have been using mine for about two years and all I have had to do was pull it apart and put a little bit of grease on it. I have to mention that the customer service at Gravity Dropper is top notch. When I was doing my research I always got replys to my emails in a few hours.
    Quote Originally Posted by Nate3510 View Post
    This is what I came with in my research. I wanted something simple and relatively maintenance free. My Turbo should be here Monday or Tuesday from BikeBob.
    Check out this thread for more info. There are also a bunch of GD threads on MTBR with clyde info peppered in.
    How are Gravity Droppers holding up under Clydesdales?
    https://www.google.com/search?q=site...hrome&ie=UTF-8
    2011 Dawes Deadeye | 2011 Niner EMD9 | 2014 Santa Cruz Tallboy AL| 2016 Raleigh Merit 3| 2017 Salsa Timberjack 27.5+ GX
