Results 1 to 5 of 5
    do i need heavy duty bike?
    im 6ft and weight fluctuates between 220 and 235 lbs, last time i was shopping around for a mtb i weighed 190 and decided to go with the cdale rush (hated to sell it), this time around i had it down to 3 bikes- ibex ignition pro, giant trance x3, and giant anthem x3, then i realized durability could be an issue since i weigh more now and wanted to see what you guys think about my 3 choices for someone my size.
    thanks...
    i should add that i dont do any drops and im pretty light on my bikes, just normal trail riding.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    You're kind of on the boney side of things for a Clyde
    The Trance X3 and Anthem X3 will hold up just fine. If the fork is a coil fork, you might want to look into a firmer spring. If it's an air sprung fork, you're good to go.
    I have no hands on experience with the IBEX.
    haha thanks. yeah, never considered myself a clyde but it seems the board consensus is anything over 200 lbs, so i thought id ask.
    Reputation: anavrinIV's Avatar
    Nov 2008
    board consensus is for 5'9 racers. 200 is about as light as I'll ever get...currently 260 and riding a much lower end bike than what you're looking at and having no problems with the frame. components may need to be just a bit beefier for you but nothing over the top, and any of those bikes will work just fine for you.
