Results 1 to 6 of 6
    Mar 2006
    DHX 5.0 coil spring rate for SC heckler..
    Just curious, whats the spring rate that you guys used?
    Today i test a kona coiler deelux with dhx 4.0 coil and i bottomed up the rear on the store's floor!! even after i lock the shock. I believe the writing in the coil springs is 500 lbs.
    The guy from my LBS said that Heckler use 450 lbs spring rate.
    Kona Coiler is a 6 inch travel bike while heckler is 5.75 inch, do you think i need to upgrade the coil spring for Heckler size Large?
    Btw, i'm 260lbs and my height is about 6 feet.
    thanks.
    err, 27.5+
    Reputation: AL29er's Avatar
    I am about 240 with camelbak. Riding an xl dhx combo I used a 500 or a 550 spring. I liked the 500 for plush, but the 550 was better for pedaling (especially if I wanted to stand and pedal).
    it tied the room together
    Reputation: TrumbullCT's Avatar
    May 2005
    I'm 265 or so and run a 600# spring on my XL Heckler. It is more on the firm size but I like it.
    Im 330
    running an 800# in my heckler
    Mar 2006
    I think i'll use the 600 lbs spring. hopefully it will be fine.
    shame i need to wait 3 weeks until its ready.
    Now what about the forks?
    My LBS offered me talas 130 rlc. I like the travel adjustability and the weight of it.
    i can lower the fork and use it as a trail bike, and when i want to use it as an all mountain i can set it at 130.
    btw, What's the minimum and maximum fork travel for heckler?
    can i use it at 100 for trail riding and climbing? or is it better to use the pike instead with 110-140 travel?
    any suggestion for other fork? mainly my lbs got fox and rockshox, not too much marzocchi, but i believe they can order it for me.
    thanks again.
    May 2005
    Check out the RockShox Pike. Like the Talas it is available in an Air model with on the fly adjustable travel while saving you some coin I believe (must have 20mm thru-axel though). The 2005 and 2006 models have been getting really great reveiws from riders, so much so that I was going to upgrade to a Fox but now I'm solely looking at the Pike line. Coil or Air is what I'm fighting with now.... I'll have to get new wheels too!
    I asked SC about fork travel for the Heckler here is their response:
    The 2006 Heckler frame is designed for forks from 100mm to 160mm.
    *100-105mm is good for those that want a quicker feeling XC ride.
    *125-130mm is for average use and all around trail riding.
    *150-160mm is for those that ride aggressive terrain, and want all the
    travel possible
    Fork use over 160mm travel is not compatible.
