Results 1 to 50 of 50
    Chris Bling
    Reputation: dustyduke22's Avatar
    Listen! Clydesdale approved rims. Please chime in
    Hey Guys,
    I was hoping that you would be able to help me out.
    I am building a wheelset for a repeat customer and he has some needs that I am sure that one or more of you have had to address. He does not have the budget for carbon rims, so we are stuck with aluminum.
    He wants a new wheelset that will hold up to his abuse on a hardtail. (Even of you have a full suspension, please chime in). He is north of 250 and pretty aggressive. That being said, he is quite smooth. He lives in Southern Utah which resemble Moab. Slickrock, chunk, aggressive conditions. His previous wheelset that he had on his Freeride bike were Mavic 729's and they have held up amazingly well.
    He wants to lighten things up a bit without sacrificing durability. He wants something equally as strong as the 729 and will hold up to whatever he throws at it. I was thinking something like a Sun-Ringle MTX 33 or a Velocity Blunt 35.
    I was thinking of doing a 36 spoke wheels as well.
    What rims do you guys use and find to hold up well?
    Thanks in advance!
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
    Reputation: Bike Whisperer's Avatar
    The Sun rims are very durable for a low price, if tubeless is not a concern I would seriously consider these. The Inferno rims only come in 32h which I think would be fine for a smooth 250lbs rider in Southern Utah (for the record I went to UNLV and took several trips to Gooseberry Mesa while there) with some nice 14/15 spokes.
    Chris Bling
    Thanks for your input.
    I am sure that you are not the only person that have rims on their bike Hopefully more will chime in.
    I've not damaged Halo rims or Stans Flow rims and I ride lardcore - which is usually slightly beyond my own ability but the bike is more capable than I am!
    turtles make me hot
    Reputation: NYrr496's Avatar
    Flows or MTX33's.
    I like turtles
    Quote Originally Posted by Bike Whisperer View Post
    thanks!
    Z
    roccowt.
    rocnbikemeld
    beater
    Reputation: evasive's Avatar
    Feb 2005
    I have had good luck with MTX-33s and Stan's FR (which are the rough equivalent of the Flow EX). I've also read good reports on some of the Pacenti offerings. I'd look there if tubeless is a consideration. If not, the Sun-Ringles.
    Im 235-240 without my gear. I've had good luck w/ American Classic Terrain wheels. They're the budget version of their more expensive wheels, but seem to be stronger than their more costly versions. Their website even says they're recommended for the bigger stronger rider, and they use standard components, so there are no odd spokes or hubs to deal with. I'm not so sure about rim availability, however.
    "Everybody relax, I'm here." - Jack Burton
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    I build using only Mavic 819 and 823. While very strong (even the 819), they are heavy rims for the size, especially the 823. Mavic now has the 821, which, if looking for UST, may be pretty good (at least I am interested).
    My favorite tube type is the Mavic 721. Decent weight and very strong. If too expensive, the 321 has a good rep.
    But these are not equally as strong as the 729. I doubt there is much out there as strong as the 729 and weighs less. It is, after all, a DH rim.
    Riding bikes since 1976
    Reputation: Gear Head's Avatar
    Nov 2013
    I weight 275 (currently) and ride aggressive. I am currently using the Sun MTX33s on a 32 spoke "street" bike and 36 spoke ones on a AM type HT. No problem with the rims at all. Not the lightest by any means but tough.
    Have used Halo Freedom Disc in 36 spoke. Very tough. Mis-timed a curb hop at 20 mph and broke the DMR rear hub axle, but only put small dent in the rim. Carefully smoothed it out and still use it as front wheel back up. But they are also heavy.
    Tried a Blunt 35 in 32 spoke built up by an LBS friend. So tension was uniform, and brass nips, etc. Bent rim within 3 rides. Not impressed with them and the lack of eyelet rings is strange to me.
    And I would forget about WTBs, whatever model. Have bent everyone I have ever had, even the "unbendium" models. The Alex DP20 I was given was stronger then the WTBs.
    Chris Bling
    Thanks for the input guys. Going to go with the MTX33. I got a hold of my Sun rep and they still had a few pairs of the winter camo!! Ordered up a pair and will post some pics when I get them built.
    Quote Originally Posted by dustyduke22 View Post
    what is your hub choice?
    roccowt.
    rocnbikemeld
    Chris Bling
    Quote Originally Posted by zarr View Post
    He has had good luck with Hopes in the past so we are going to stick with that.
    What hubs do you prefer?
    I just wondered if you used strong hubs...I hear hopes are good. I never used them though...I'm gonna use Shimano M529s on my upcoming 29er builds with Flows and Sun Inferno 27 and Sun EQ27 rims.
    roccowt.
    rocnbikemeld
    Nov 2008
    Shimano M529s
    Junk hubs for a clyde.
    Nov 2013
    M529...Junk Hubs for a Clyde
    Do tell, if in another thread/forum...
    Interested in reasons/experiences.
    I have Deores laced to MTX33s, and hub only related problems. Any major paw damage results on the "Made For 29er Torque" able hubs on your ends?
    Link if you got it.
    Nov 2008
    Well if you haven't had problems with Deore then you might be ok. Just not a durable hub for big guys. I've broken lots of XT freehubs and upgraded to 529 freehub and didn't really last any longer. Search around, lots of threads in clyde forum about shimano freehub destruction.
    Quote Originally Posted by Sasquatch1413 View Post
    Sorry-I need to remember to post details in my replies more specifically sometimes I guess.LOL
    I haven't heard or read any bad reports about the m529 until now...although I'm sure they may not be suitable for everyone. As for me, at 61 years old and an amputee,(I lost my foot), they'll probably be fine 99% sure. I'll try harder to be more specific next time. Wouldn't want to misinform anyone. Take care.
    Z
    roccowt.
    rocnbikemeld
    Nov 2013
    NO. I was feeling frustrated on my many key word combination searches. Maybe 15 hours worth... no Boolean searches on MTBR.
    I apologize to OP.
    Link me please.
    Nov 2008
    Not sure how I can search for "shimano freehub" but you can't.
    Here's one link
    I need a Clyde-proof rear hub/freewheel!
    Nov 2008
    I guess it comes down to how hard and what trails a person rides.
    I picked up some Diatech sealed bearing rear hubs listed on ebay for 15 bucks a pop a while back...
    They are heavy...I have no idea about their longevity, just took a chance cause they were cheap. There again...they're prolly good for me personally because I don't ride hard. I also have some Deore 525 rear hubs which are known to be weak especially for 29ers. I'm gonna use them on some 26er builds. Mainly, I wanted the OP to know not to use 525's when I replied on this thread. I'm gonna need a 12x142 hub for my GT Sanction 3.0 2009 build eventually...prolly just use whatever fits.LOL
    More avenues are open for weak old riders like myself.LOL
    My buds tell me I'm great regardless just to be out there riding period...and I agree. I'm just glad I know about our sport.
    -Z
    roccowt.
    rocnbikemeld
    Reputation: 0351's Avatar
    Nov 2013
    I got the WTB i23, they look pretty tough
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    In my opinion this will have more effect in rim stiffness and durability than the difference between a beefy rim from brand X compared to a beefy rim from brand Y. I'm sure your wheels will be just fine no matter what reputable rims you happen to choose.
    Quote Originally Posted by 0351 View Post
    mmmm...they started out good it seems, but according to some posts in this thread, problems developed on the 7000 series version of this rim/wheel.
    Read down from post #8 on this page. I may not have gotten the whole scoop, so read carefully. From what I heard, WTB will stand behind their products though.
    WTB Frequency i23 AM wheelset: alternative to Flow rims
    roccowt.
    rocnbikemeld
    Nov 2013
    Here's one link
    Thanks for the links... by the way "shimano freehub" combination of words alone gets results from 147 threads over at least 8 forums...
    Not that I couldnt or didnt look. Just asked someone to be nice and save me some time. So thanks.
    On the Sun MTX 33's does anybody feel they are slow wheels because of weight?
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    -Z
    If you ride as described, the M529 (and M629) should be fine for you.
    Quote Originally Posted by Gear Head View Post
    If you're smacking them into a curb, 36 spokes will likely transfer the force of the impact to the rim a little better than a 32 spoke wheel will ;~)
    If you're smacking rims on rocks (and damaging the rims), you have some choices to make. You can 1) add air pressure to your tire 2) run larger/beefier tires 3) alter your technique to reduce the impact as you slam into rocks and curbs 4) change nothing.
    If you choose option #4, all the spokes in the world won't keep a rim from being damaged from direct impacts on a rock or curb. Some rims will take a hit better than others, but I don't see why that has to happen when it can be prevented in many, if not most circumstances.
    If I wanted a rim that could possibly withstand being slammed into a rock or curb, the Mavic 729 would be somewhere near the top of my list. Yes, they are relatively heavy, but they will need mass to have a chance to survive abuse.
    beater
    Feb 2005
    Quote Originally Posted by Realslowww View Post
    Not really, but most of my rides are slow churns to the top for a downhill, rather than miles of rolling terrain. Or I take a trip to the desert SW, where I value durability, and again, I'm not riding lots of fast miles. If I had different needs, then I would probably find them overkill. But at that point, my frame and all the other parts on it probably are, too.
    Speaking of parts, in my experience, changing tires has a much bigger effect on perceived speed and effort than changing rims.
    Quote Originally Posted by evasive View Post
    So tire weight is more than rim weight, I ride 90% road but throw in a trail and jumps with curbs to make short cuts to get where I am going,
    I want good speed on the road. I am running 40 CM tires, do you think I may gain some MPH by going with a lighter rim or would I be asking for trouble with dents from doing curbs and small jumps at high speed?
    beater
    Feb 2005
    I was thinking mostly of rolling resistance.
    My riding is the opposite- nearly all on trail. I don't have enough experience with road/commuting rim and tire options to give you any useful advice, I'm afraid.
    Sun mtx 33s on all 3 of my bikes...two AM and one DH. The DH has hopes and has broken 3 spokes so far...am bikes have Hadley's and no broken spokes and no truing needed for like 3 yrs.
    I'm about 260 lbs and 7 ft...ride pretty aggressively...I highly recommend the Hadley's with the 33s...
    Crap...forgot one of my am's now has a velocity p35 rim on Hadley for rear (27.5 rear and 29 front)
    The velocity had been rock solid too...
    Nov 2013
    Next wheel build for Spring FS project myself.
    Will get back to the technique vs. component strength debate later, jeffp.
    some know me as mongo
    While I have heard the same I have ridden two sets of i23s now. The first ones on my nomad (ridden as a trail/am bike) and they were the 7000 series alloy and never had a problem with them for over 1000 miles and over a year. no cracking or anything and I do run higher than normal tension.
    My second set I have are on my XC/trail bike (a tallboy) and I have ridden that bike very hard. the i23's on there have the newer alloy on them and they are also holding up great. I really do rake this bike through the coals. I jump it and pin it on the dh's and seeing that it is a 4" bike the rims see alot of the impact.
    truth be told I most likely would have had problems with the i23s on my nomad because of the material, but only in time. As for my new set only time will tell but I expect them to have a very long well used life, which is actually a bit disappointing because I will love to get a set of the new WTB KOM i23s. those look like the idea trail rim to me.
    3000 mile goal for 2018
    3402.7 miles ridden in 2017
    3028.4 miles ridden in 2016
    Dec 2013
    I am 6'3 at 275 on a 29er hardtail. went through several combos before finding a problem free setup. I finally settled on halo freedomdisc wheels, 36 18 gauge spokes,chris king hubs. I went through 3 XT's the last one lasting only 22 miles. was breaking the pawls completely out, freewheel in both directions lol. they are pretty heavy but 1 year of abuse and they have never failed or had to be retrued.
    Nov 2013
    Quote Originally Posted by Mr. Lurker View Post
    Well spoken. Answered 4 of my questions.
    Chris Bling
    As Promised
    Here are a pic of the Winter Camo MTX 33's on Black Hope hubs. Turned out pretty sick. Headed to their new home in the mail as we speak
    36 hole laced 3 cross. It will probably come at no surprise to anyone, but these are crazy stiff!
    Reputation: Robg68's Avatar
    Oct 2013
Name:	MTX-33 Wheelset.jpg
    Those are some of the coolest looking wheels. I want some now!!! My son that's in the U.S. Army would love them too.
    Bikes I currently have. 2014 Trek Fuel EX 8 29er. 2013 Trek Mamba 29er.
    Reputation: johnD's Avatar
    Sweet ! What did they weigh ?
    Chris Bling
    I didnt weigh them before I shipped them off. But they were a little north of 2000g based on a rough calculation.
    The rims alone are about 1500g for the pair, probably much closer to 2500g for the set.
    But you don't buy the MTX33 rims if you're worried about weight.
    Chris Bling
    True that. So I went back and redid my math.
    Rims 660 g each
    Spokes ~377 grams for the lot
    Front Hub 174
    Rear Hub 310
    Nipples 20g
    So a rough estimate we are sitting around 2200
    Rims 660 g each
    Front Hub 174
    Rear Hub 310
    Nipples 20g
    Ah, I was thinking they were the 29" version for some reason which are 762g a hoop
    Chris Bling
    Holy cow...........that is nearly what both of my 26 in rims weigh put together!
    Nice wheels.
    I've had very good luck with Stan's Flow EX wheels on Hadley, Chris king, and I9 hubs. Only time I had an issue was when I nailed an edge on a drop--and that wasn't the wheel's fault. I'm 5'10, 235--and I'm grateful for strong FH/pawl engagement when I'm grinding uphill (especially when it gets rocky).
    I'm running a pair of Stan's Arch ex hoops and Chris King hubs, laced with DT swiss competition spokes. I am range from 285lbs to 300Lbs and I have trued them one time in 5 years. I ride mainly XC and occasionally make my way out to Sedona AZ and ride some rougher stuff there. Great combo IMO
    Quote Originally Posted by drewdoeboy View Post
    The Arch EX has only been around since 2012...I am sure they are strong, but the 5 years quote is a slight over-exaggeration.
  1. Hardtail or not to hardtail - thoughts and advice please
    By Velosprocket in forum Specialized
    Last Post: 02-15-2014, 07:57 PM
  2. To Clyde or not to Clyde. That is the Question.
    By friz in forum Clydesdales/Tall Riders
    Last Post: 11-01-2013, 08:29 AM
  3. Help choosing wheelset for my XC hardtail - Clyde
    By Verbeers in forum Clydesdales/Tall Riders
    Last Post: 04-06-2013, 08:01 AM
  4. Replies: 5
    Last Post: 10-02-2012, 02:27 PM
  5. Hardtail MTB frame choice
    By Mr.AllMountain in forum Bike and Frame discussion
    Last Post: 02-04-2011, 06:23 PM
