Results 1 to 24 of 24
    Clyde-worthy Rigid 29er Fork
    Any suggestions? It would be going on a Trek Mamba. I'm about 260 with gear.
    Criteria:
    Light weight(Carbon is not out of the question)
    Close to 490mm axle to crown
    9mm QR
    Disk brake
    Preferably 1.125 inch steerer(I could get a new headset to accommodate tapered if that would be better)
    Virtually unlimited budget
    Quote Originally Posted by danhasdrums View Post
    This place is like high school, except the morons here don't get automatically put in stupid kid classes...
    Would say Karate Monkey fork but not light and ? on A-C. Get a custom made steel forks to your specs and weight. You want a carbon fork for dirt riding?
    Making fat cool since '71
    Reputation: ImaKlyde's Avatar
    Sep 2004
    I used a Karate Monkey for one winter's worth of riding a few years ago. I was 280+ at the time. It was fine. I'm hard on stuff and ride very aggressively and while it's NOWHERE near as accurate for highspeed steering as my 36 or 66...it's at least as accurate as a Marz AM I have.
    I've ridden three different carpetfiber dirt forks (On-One, Ritchey, Niner) and have not been happy with their performance. I'm WAY over their target audience though (260lb).
    But if you do have a "virtually unlimited budget..." like leeboh said, have someone fab up your perfect fork. $300-500 later...it's exactly what you want.
    Brock...
    Are the wheels roundish? Ride it.
    Disciples Of Dirt, come ride with us.
    Sounds like I'll be staying away from CF. Any recommendations on builders?
    Sep 2004
    Quote Originally Posted by ssiegrist View Post
    The only builders I know personally and trust implicitly are Bronto and Vertigo here in Oregon. Todd at Bronto is the real deal. He's a rider, helps on trail work, fast as hell, ugly as hell, nice guy. There's lots of great builders out there though...there's gotta be one local to you if you root around.
    Brock...
    I ride a Niner CF fork. I am 280 geared up. Performs fine for me. No weight restrictions. No weird flexing...I have one season on the fork and love it. Max rotor size is 185 other than that there are no restrictions on the fork. The bike is a Kona King Kahuna.
    I'm curious what Klyde didn't like.
    Sep 2004
    Quote Originally Posted by Cincinnati Kid View Post
    I experienced some weird flexing in some situations, very little, but...it's was there. More brake chatter than I would like. I can't stand a 185 rotor up front and finally, not as much tire clearance as I would want if I'm paying for a fork.
    Brock...
    Quote Originally Posted by ImaKlyde View Post
    Brock...
    I ride a 2.4 up front and have more than enough room...how big of a tire do you need?
    It does flex a little but it it is designed to. I think it flexed less than my Surly fork, however.
    They aren't for everyone and to each his own.
    To the OP, give one a spin. Make up your own mind. I'm heavy and it lives under me...
    Reputation: Moonshine's Avatar
    Try a Kona P2; cheap and good quality - what else could you ask for?
    Former Bike Wrench
    Reputation: bomber495's Avatar
    I use a white brothers CF fork. No issues with flex or anything at 275lbs
    jct
    jct is offline
    Reputation: jct's Avatar
    cro moto grande has worked well for me. a little brake flex but nothing out of the ordinary.
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    Syncros Carbon FL is a SWEET fork. No weight limit or rotor size restrictions and it held up to everything I could throw at it.
    Chronic 1st-timer
    Dec 2005
    KM
    ...or if you can find an old-school Niner steel fork, they have 490a-c.
    Trailwrecker at large
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    KM is to short... although the newer one is supposed to be much smoother then the old one... although i'd splurge for a salsa fork over the KM if your actually buying a new one (KM comes with the frameset)
    from what I understand the Voodoo Zombie 500 Disc Fork is 500mm axle to crown... so might look into that... if QBP ever gets them back in stock lol
    - Surly Disc trucker
    - '82 trek 560 roadie
    Slave to the grind
    Reputation: cherrybomber's Avatar
    Soul cycles chromo- lovely!
    Let it flow, let yourself go, slow and low, that is the tempo.
    Feb 2012
    Kona P2 29er
    Tigers love pepper...
    Reputation: cobi's Avatar
    I'm sama size as you and run a One One Carbon. Love it. I'm actually getting ready to strip that bike and move the parts over to a Spearfish frame. I may consider selling it, but love that bike (Scandal) so much I will probably end up rebuilding it eventually.
    On-One Carbon Fork £149.99
    That On-One looks to be a rebadged Pro-Lite.
    http://www.pro-lite.net/index.php?op...=145&Itemid=45
    Any ideas on weight limits?
    Not a rebadged Prolite
    I believe there is no weight limit or it is like 300+ lbs, There is info on their website somewhere about the limit or lack of one.
    Quote Originally Posted by cobi View Post
    They look like they have exactly the same distinctive crown and dropouts.
    EDIT: Exhibit A:
    Attached Thumbnails Attached Thumbnails Clyde-worthy Rigid 29er Fork-forks.jpg
    HTFU and Ride
    Reputation: coachjon's Avatar
    Voodoo Zombie was HARSH as hell IMO.
    With an unlimited budget I say custom (ThruAxle if possible) from Quiring, Vicious, or something similar. That way you can get the exact measurements you want from the start.
    That said I am running the CroMoto Grande TA fork and love it so far.
    Winter is coming.
    Quote Originally Posted by R+P+K View Post
    EDIT: Exhibit A:
    Mine has a different crown (CIRCA 2008), so I was comparing mine to the prolite. Maybe they are they same now?
    Yeah, that would make sense :-)
