Results 1 to 21 of 21
    Scottish Rogue
    Reputation: schmaged88's Avatar
    Clyde proof Wheelsets and Bars
    I am thinking about building a new wheel set for my Motobecane Fantom pro 29er. I need some big guys advice for a rookie. I am 300 pounds at 6'1"and want to build them with out killing the bank using quality materials. I also need some advice on a new set of bars, I want them to be around 27 inches or wider and I would like a rise of 1.5 to 3 inches I am running the stock stem but it can be changed to compensate the rise issue. I appreciate any help given.
    Justin
    Mouth-Breather / Huffer
    Reputation: dog.gone's Avatar
    Heavy Duty / Beefy / Bomb Proof Wheels for a Clyde / Clydesdale
    I am also in the market for a beefier wheelset. Here are a couple of threads that focus on wheels for us big boys:
    FAQ: Heavy Duty 29er Wheels
    Azonic Outlaws vs. Sun Rhyno Lite XL
    While there are widely varying opinions, I'm focused on the 36h Sun-Ringle Rhyno Lite XL with XT hubs. Cheap, strong, reliable... but a little on the heavy side. Now I'm just searching for the right deal from the right shop.
    the giant.
    Reputation: gbosbiker's Avatar
    for bars, go with something with a cross bar. its stronger and less prone to snap.
    http://www.billys.co.uk/english/grou...=hbgu-prison-r
    http://www.wiggle.co.uk/p/cycle/7/DM...ar/4000000734/
    each has plenty of rise for a big person, and can hold up to a lot of stress.
    Chronic 1st-timer
    Dec 2005
    36h front & rear
    Trailwrecker at large
    Former Bike Wrench
    Wheels-Look at XT Hubs with 14ga spokes, brass nipples, 36 hole Rims. Some economical rim suggestions include Sun Rhyno Lite 29, WTB SpeedDisc AM (only 32 hole though), Mavic A319
    Handlebars-Look for DH/FR models from Easton, Race Face, Titec, Truvativ...some good deals can be had online
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    dog's wheelset sounds about perfect... i'm planning on building a good but inexpensive wheelset here soon (me lacing it and everything)... plans are stright gauge spokes, brass nipples, new 36pt engagment XT hub out back, debating on hub up front (hope pro2 most likely due to it being able to switch from QR to 20mm ta and other options) and Kris holm rims... maybe the rhino lite rims... smidge cheaper and i'd save 200grams (haha)
    - Surly Disc trucker
    - '82 trek 560 roadie
    for bars... anything "AM" or all mountain will take care of you and never have an issue...
    http://www.cambriabike.com/shopexd.asp?id=65108
    These are the rims you are talking about, correct?
    Scottish Rogue
    I need a 29er those are for the 26 and 24. Or do those come in 29 also??
    Quote Originally Posted by schmaged88
    The Rhyno Lite XL and Rhyno Lite are very similar; I believe the key difference is that the XL is welded whereas the Lite is pinned - which probably doesn't make a big difference to most users. I can't seem to find the XL in 29", however, just the pinned Rhyno Lite
    Here's a link to the Sun-Ringle website:
    http://www.sun-ringle.com/contentpag...lmountain.php5
    While I haven't looked too terribly hard just yet, the best price I've found on the Rhyno Lite / XT 29er wheelset combo is $236 from UniversalCycles.com. I'm *sure* someone has them at a lower cost, but I just haven't stumble upon them yet.
    Re-friggin'-Lax!!!
    Reputation: WEBERTIME's Avatar
    I'm a wee bit smaller than you and ride a HT 29er built with these...
    http://www.speedgoat.com/product.asp...=40&brand=1055
    You'd be nuts not to think about them. I've had Rhyno Lites as well and they are nice, but not as stiff.
    If necessity is the mother of invention, laziness is the deadbeat dad that knocked her up.
    Reputation: bvibert's Avatar
    Mar 2006
    Quote Originally Posted by dog.gone
    The Rhyno's do come in a 29" version. The Rhyno Lite XL and Rhyno Lite are very similar; I believe the key difference is that the XL is welded whereas the Lite is pinned - which probably doesn't make a big difference to most users.
    The XL's are a little wider too.
    Quote Originally Posted by donalson
    er OK i missed a number while looking...
    Kris holm rims are 38mm... the rhyno lites are 27.5... i want that extra 10.5mm width for a rigid toy ... hopefully fathers day brings some fun stuff
    Scottish Rogue
    what is 700 30c?
    Whoa, Mark! So much for our PG-13 rating!
    Kris Holm 29r Unicycle Rim? Giving up MTBing and going to MT unicycling?
    what is 700 30c?
    700c appears to be considered interchangeable with 29". I'm not sure where the 30 comes in. I'm sure someone more knowledgeable will have the answer here soon...
    RHYNO LITE XL (Welded) v. RHYNO LITE (Pinned)
    Quote Originally Posted by bvibert
    Right on. Thanks for the clarification!
    Here are the specs for both wheels:
    USE:
    DOWNHILL, MTN. CROSS RIDING AND RACING
    SIZES:
    507mm, 559mm
    E.R.D.:
    493, 548
    WEIGHT:
    512g, 550g
    HOLE COUNTS:
    32, 36
    COLORS:
    BLACK
    WIDTH:
    29.2mm
    RHYNO LITE (Pinned)
    USE:
    ALL MOUNTAIN
    SIZES:
    559mm
    E.R.D.:
    548
    WEIGHT:
    550g
    HOLE COUNTS:
    32, 36
    COLORS:
    BLACK, SILVER
    WIDTH:
    27.5mm
    While the Sun-Ringle website doesn't seem to show that either wheel comes as a 29er, Universal Cycles has the Rhyno Lite (not XL) in the 29" diameter. Hmmm...
    yes unicycle rims ... think salsa gordo's... except it's 3mm wider, 7grams heavier... and 1/3 the price ;-) oh and you can use rim brakes if you're inclinded...
    the wider rim will give a wider footprint on the tire... and let me run lower pressure... good things when you're rolling rigid...
    32h vs 36h?
    Is there an advantage with going 32Hole?
    Mar 2006
    Quote Originally Posted by DKeeney
    32h vs 36h?
    The only one that I know of is less weight.
    less weight, less rigidity, less strength
