Results 1 to 5 of 5
    For a Clyde, HT vs shock RS ?
    You guy's who know and are large do they make a really good set up for a shock RE that works for 300 pound people and if they do who makes the best bikes with it.
    Are the Zinn products made more stout for heavier people?
    Thanks for help.
    Reputation: Gerth's Avatar
    Aug 2013
    Well as far as the shock goes , from my research your shit out of luck. Trek mountain pikes are rated to 300 pounds and I know Lenz makes bikes stout enough for guys our size.
    Chances are .. You're full of !$@&?
    No talent hack
    Good god man.... there is an entire thread dedicated to 300+ on full suspension.
    Gerth is a bit misleading. The DRCV shocks from Trek require high pressures to fit a 300+. The non-DRCV shocks on the Fuel (the Superfly has a craptastic leverage ratio) work fine. Look to a Fuel EX6 26er or EX5 29er.
    When I weighed this morning (that means not suited to ride), I hit 306. I personally ride a 2013 Specialized Camber Comp aluminum frame and love the bike. The max psi on the Monarch is 275. I run ~255 in it. Autosag does wonders. That said, I could not get away with an Epic and did not like the way the SJ-FSR felt.
    Other bikes that work well.... Niner RIP9... Pivot 429... to name a couple.
    The moral of the story.... full suspension is worth more than its weight in gold. You can ride one north of 300. You will need to spend some time shopping and find the bike that fits you though. test rides are key. As a big-un, you will need a good relationship with your LBS, they should take care of you and any warranty issues regardless of what you read.
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (commuter, gravel, fun))
    Aug 2013
    Quote Originally Posted by Knight511 View Post
    I don't think I was misleading at all. Go ahead and call RS or Cane Creek and ask them. They are not rated for a 300+ guy. Yes you can get away with a DRCV shock as long as your leverage ratio is 2 to 1. But as Knight said test rides are the key
    Thanks for the help, Sasquatch said going full suspension can open some cans of worms compared to a good HT? I mostly ride street but jump stuff and make my own trails.
  1. SB66 rear shock for a CLYDE
    By WRX-Rob in forum Yeti
    Last Post: 05-09-2014, 01:20 PM
  2. super clyde looking for the right rear shock
    By tmhar28 in forum Shocks and Suspension
    Last Post: 09-05-2012, 02:22 PM
  3. Clyde rear shock dilemma
    By TitanofChaos in forum Clydesdales/Tall Riders
    Last Post: 08-10-2012, 08:24 AM
  4. Jet 9 and a Clyde?
    By Apexpredator65 in forum Niner Bikes
    Last Post: 03-11-2012, 09:09 AM
  5. Best "out of the box" 29er shock for a clyde
    By PoisonDartFrog in forum Clydesdales/Tall Riders
    Last Post: 03-22-2011, 10:52 PM
