Results 1 to 6 of 6
    Reputation: Gerth's Avatar
    Aug 2013
    Choice help: Trek Fuel vs Salsa Spearfish VS Specialized Stumpy
    I am thinking of getting a full suspension bike next year and being a Clyde at 6 ft 295 I'm trying to figure out the best bang for the buck between these 3. I mostly ride single track and trail and very little downhill or big drop stuff. Any suggestions from my Clyde brothers?
    Chances are .. You're full of !$@&?
    No talent hack
    I didn't try the Spearfish, but I did try the Fuel (with DRCV) and the SJ-FSR. Both bikes were FAR too squishy with my weight (310) and the shocks were maxed out to the mfg's max pressure. That said, the Fuel without a DRCV did just fine, but I liked the Specialized Camber quite a bit more.... and that is what I bought and ride, a 2013 Spec Camber Comp.
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
    Reputation: Bigb2000's Avatar
    May 2013
    All three are great. I own the stumpy evo comp 29er and have experience with the spearfish. I run about 90psi in the fork for about 30% sag. The less air pressure it has, the better the bike gets. I've never maxed out the fork and I ride fairly hard. I use the autosag on the rear. The evo has wider rims and wider tires. I think the spearfish is also a great bike. The stumpy just seems a little better to me.
    Jul 2013
    Re: Choice help: Trek Fuel vs Salsa Spearfish VS Specialized Stumpy
    Watching this thread. Looking at fuel or stumpy too.
    Nov 2008
    Whatever you do, buy a new bike with a warranty. At 295 there is a good chance you may have problems. Also, you can run the shock at higher than recomended pressures. I've run a fox RP23 at 305-310 psi for at least 6 months with no issues. You may have to replace air can seals more often though.
    Aug 2013
    Thanks for the replies! I've been doing some research and I think that maybe an Enduro might be better built to take the weight. So I'm thinking maybe a 14 enduro 29 comp SE . I won't be buying until the end of next year and I should be able to find a good deal on one
  1. Replies: 8
    Last Post: 12-16-2013, 06:41 PM
  2. Replies: 4
    Last Post: 08-29-2013, 10:41 AM
  3. Replies: 4
    Last Post: 08-11-2013, 10:56 AM
  4. Specialized Stumpjumper FSR vs Trek Fuel EX
    By guitarman2011 in forum Bike and Frame discussion
    Last Post: 10-15-2012, 10:54 AM
  5. Trek fuel ex7 or specialized camber elite
    By Frogfuel7 in forum Trek
    Last Post: 11-04-2011, 10:50 AM
