Results 1 to 11 of 11
    Moderator Moderator
    Broke my stumpjumper twice. What next.
    I've been putting about 1500miles per year on my 2011 Stumpy FSR. I've cracked the rear triangle twice. Since Specialized doesn't consider the rear triangle to be part of the frame I get to pay for this. I'm deciding its probably time to upgrade. I think the problem is is that trail bikes are just a little too lightly built. So I'm looking for an All mountain 29er. Preferably one with a really good warranty.
    Reputation: Bike Whisperer's Avatar
    Would help if you gave your weight and budget
    Mar 2013
    I met a guy who made me feel small (I'm 6'6" 240) at the local XC races who ran into the same issues (but he broke a lot more) and he got a Pivot Mach 5.7 and hasn't broken anything since.
    Depending what fork is on your SJ, you might be able to just get the frame and swap everything else over. You could even try to find the frame used and your out of pocket wouldn't be much at all once you sold the SJ frame.
    Moderator Moderator
    Quote Originally Posted by Bike Whisperer View Post
    250#. I know that's not huge, but apparently its more than a SJ can handle. The budget is as little as possible but I'm resigned to the idea that anything that meets spec is going be $3-4k.
    I'm interested in the SB95 but its rare enough you here few reports.
    I'll check out the Pivot.
    Mar 2013
    Quote Originally Posted by Metamorphic View Post
    How tall are you? L and XL sb95's below
    Yeti SB95-Enduro 2013 XL - Pinkbike
    Yeti SB95 Enduro-2013 Large - Pinkbike
    turtles make me hot
    Reputation: NYrr496's Avatar
    Niner WFO or maybe the Lenz Lunchbox or Behemoth.
    BTW, I'm 6'5", around 260. I broke the rear triangle on my original 2008 Army Green FSR Stumpjumper. While removing the broken chainstay, I found a crack on the main triangle. Specialized ended up waranteeing the frame with a silver 09.
    Been riding that one ever since and have not broken it, to my surprise.
    I like turtles
    Turner Sultan. Tough as you like and a well respected attitude to customer support.
    Reputation: Tillers_Rule's Avatar
    Sep 2004
    I had a similar dilemna a year or so ago. After 7 years I broke the shock stay, replaced under warranty. Well, 3 months later I broke it again. I took that as a sign (or excuse) to pick up a Niner RIP 9! The RIP 9 is definitely all that. I'm 6'4", ~225. The first month or so I had the bike I was unsure, as the handling and ride is much different than the SJ. Well, fast forward a year and half later, I haven't ridden the SJ once!
    Well not high on the bling factor, but the Trek Remedy 8 29 fits your budget. Trek is lifetime on main frame and five years on swingarms.
    Nov 2012
    Cannondale trigger seems to be a nice all mountain bike.
    Banshee prime. End thread!!
  1. 2007 Stumpjumper Expert or 2008 Stumpjumper Comp??
    By ParadiseRiding in forum All Mountain
    Last Post: 12-01-2013, 03:22 PM
  2. should i buy a 2007 stumpjumper fsr or a 2008 stumpjumper fsr expert?
    By bertrenolds in forum Bike and Frame discussion
    Last Post: 07-29-2013, 01:07 PM
  3. Replies: 10
    Last Post: 06-23-2013, 01:08 PM
  4. Replies: 1
    Last Post: 01-19-2012, 09:26 PM
  5. 07 stumpjumper headset screw broke off!
    By singletrkmind in forum Specialized
    Last Post: 03-02-2011, 09:41 AM
