Results 1 to 30 of 30
    Mar 2013
    Any clydes with a CTD fork? Question for you...
    I am 240lbs geared up and I'm running 100psi with rebound 2 clicks away from fastest in my 2013 Fox Float 32 EVO w/CTD.
    I simply can't use the descend mode... it's so squirrely and I've even come close to crashing a few times because the bike behaved so strangely. The Trek website offers suspension settings at my weight so I can't imagine I'm too big for it.
    Also--I set the bike up with 20% sag and I'm only getting 50-60% travel out of the fork. This could just be how I ride (mostly XC) but if I use any less air in the air chamber the bike bobs like crazy up hills (unless I put it in climb mode but sometimes don't have time).
    The bike performs how I want it to but I'm just wondering if I could like it even more with additional tweaking.
    I have a Float 34 F29 that I purchased from http://www.mtbsuspensionexperts.com/
    The did a custom valve job on it to suit my 340lbs. I run 105psi and have full travel. I also leave the fork on descend all the time for a sweet smooth ride with minimal bob.
    Im sure they can get you set up right.
    Mar 2013
    Quote Originally Posted by desmo944 View Post
    No bob even when standing up to mash up a hill? Mine only bobs in that situation in "trail" mode... standing/mashing up a hill in climb mode, or climbing while seated in "trail" are fine. I think I'll just set a 25% sag instead of 20% and go from there.
    Anyone have tips for getting to exact pressure you want? If I pump up the shock, disconnect it, reconnect it, I'm always 5-10psi less than where I left it. So I'll usually pump to 105 for the fork and 250 for the shock but especially with the shock I won't know how much I lost disconnecting the pump unless I reconnect it again.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I'm over 250lbs before gearing up and ride a 2013 Stache 8 frame with a 120mm F29 Evo CTD. I run about 90psi (IIRC) which puts me at about 30% sag and I prefer that to less sag. I am also only a couple clicks from full fast on the rebound setting. I rarely (if ever) run recommended pressures in air forks, always lower.
    Mar 2013
    Quote Originally Posted by jeffj View Post
    The Trek website says 7 clicks out for the fork. I'm assuming this means clicks out from fully turned in clockwise. This is about halfway in between full fast and full slow (I think I counted about 14 total clicks). This is odd to me because the recommended for the rear is 2 clicks out from full fast.
    How do you properly measure fork stag, stand up on the pedals? How should you be leaning? Because my fork sags about 2% when I sit on the saddle so I'm assuming that can't be right.
    R.I.P. DogFriend
    Quote Originally Posted by Alias530 View Post
    Just sit on the bike in a normal pedaling position, and get off the bike, and see where the o-ring is.
    If you're riding full suspension, you want to the front and back to work together, and rebound at about the same speed. If the back rebounds faster than the front, it will try to buck you over the bars on a jump.
    I like a somewhat fast rebound speed for good small bump compliance. If you descend aggressively, and the speeds are set too slow, the fork (or shock) will 'pack up' after repeated hits. I ride with the CTD on the fork in descend ("D") most all the time. On the rear shock, I usually like the "T" (trail) setting for climbing, and go to "D" (descend) on the way down. If it's a mixed bag of a trail, I can hang in either "T" or "D". I rarely use "C", but YMMV.
    I like 30% sag on this Fox fork because I usually get close to full travel during my average ride (I descend fairly hard on an average ride), and the fork works well for me this way. I would try it at 30%, and then see how much travel you use on an average ride, and then adjust from there so you're using the travel you paid for (or at least 90% of it). Then get your front and rear rebound speeds sync'd so it acts right in the air.
    That's what works for me.
    Mar 2013
    Sitting on the bike really only works the rear shock. I have to be standing for the front shock to move.
    Thanks a lot for the other suggestions.
    R.I.P. DogFriend
    It should work for the front too.
    How much air pressure do you have in the front fork's air spring?
    Mar 2013
    It moves it a few mm. 100psi. Haven't tried lowering it to see if it goes down while sitting.
    R.I.P. DogFriend
    I use right around 90psi and I'm closer to 260 before I get dressed. I'd let some air out until the static sag gets to 30% on that fork, and give it a try. See how much of the travel you use.
    Makes me curious about the air pressure in your tires. I see loads of people (that have bikes with way too much pressure in their tires) that tell me their LBS set them up like that.
    Mar 2013
    How are you supposed to test fork sag? At 100psi and sitting in the saddle, the fork really doesn't even move. If I'm standing on the pedals I'll get about 15% sag at 100psi.
    I'm set up tubeless with 29x2.2 Conti X-King Protection model and I run 30-32psi. Wouldn't too high of pressure force the bike to use MORE travel?
    R.I.P. DogFriend
    Just sit on it in the same position you would pedal down the street in. Carefully climb on, sit in the riding position without bouncing, and then carefully climb off. If you don't have an o-ring on the stanchion, you could put a zip-tie on there as an indicator.
    In my estimation, going by your description, you have quite a bit more air pressure in there than I would recommend.
    Sep 2013
    This is probably a stupid question but are you setting up your sag in Descend mode?
    Mar 2013
    Quote Originally Posted by jaholbro20 View Post
    No, should I be? Always in trail mode for sag
    Sep 2013
    Yea you should be setting both sag and rebound in descend mode
    Sep 2013
    also not sure how you are setting your rebound, but after you set your sag in descend mode, start the rebound at full open (slow or more damping) and go from there. when you get to high you'll notice the fork top out on rebound and you'll hear a distinct sound, you don't want it to top out. Then you can adjust from there for personal preference.
    Mar 2013
    Seems like it would be even worse if I set sag in descend...
    25% sag in D might only be 20% in T
    Sep 2013
    Well the way your doing it now isn't really setting "sag".
    Mar 2013
    Still won't make it any better. If it takes 240psi to get me to 25% sag now it might take 260psi if I start doing it in descend mode and I'll use even less travel. Real world circumstance is more important than the manufacturer telling me how I should do something when what they're saying will clearly make it worse.
    Sep 2013
    Call me crazy for saying to set the sag and rebound as suggested, which apparently you haven't done yet... Plus Standing on the pedals and transferring weight to the front is not how you set sag.
    Mar 2013
    Call me crazy for skipping a process I already know the end result of. If I'm not using as much travel as I want now, how is adding MORE air pressure going to help?
    I get what you're saying, but it simply won't help. I'll paypal you $100 if you can convincingly describe to me how doing what you are suggesting will do me any good with my goals (using more travel) in mind.
    Sep 2013
    Why is it that you think you need MORE pressure???
    "How are you supposed to test fork sag? At 100psi and sitting in the saddle, the fork really doesn't even move. If I'm standing on the pedals I'll get about 15% sag at 100psi."
    "How do you properly measure fork stag, stand up on the pedals? How should you be leaning? Because my fork sags about 2% when I sit on the saddle so I'm assuming that can't be right."
    "Sitting on the bike really only works the rear shock. I have to be standing for the front shock to move."
    "It moves it a few mm. 100psi. Haven't tried lowering it to see if it goes down while sitting."
    And it was already suggested that: "In my estimation, going by your description, you have quite a bit more air pressure in there than I would recommend."
    I'll go double or nothing that if you put the bike in descend, and just sit in the saddle like your supposed to, no standing up, no bouncing that you still won't get enough sag, you have too much pressure.
    Mar 2013
    I'm only using 50-60% of travel both front and rear. That's with 20-25% sag in the back and I don't know what amount of sag in the front because I'm getting conflicting answers as to the appropriate method of measuring.
    If I change to D mode in the rear my sag will only increase, meaning I wouldn't be taking any air out and might even have to add to get back to 25%
    My point was that whatever sag I'm at in T is going to be a lower number than in D, so I'm either already there or might have to add.
    Sep 2013
    Keep arguing and doing it your way. You came in here asking about your front fork, which you've been told multiple times that your running too much pressure in your front fork, and I'm also going to say that your not running enough damping for that high of pressure.
    I'm running 105 psi, and have to be 2 clicks from full damping as to not top out. And I weigh more. I'm not going to comment again but when you figure it out you can PM me for my paypal address.
    Mar 2013
    My point was that I'm already at the suggested sag level (at least in the rear) so if I go into D mode it'll say I have more sag than I should, so at least for my riding style and trails, sag is not a guideline to bet your life on.
    unpossibles
    Reputation: Josh_SL2's Avatar
    Mar 2012
    You're losing pressure when you reconnect, not when you disconnect. The pump is not pressurized before you connect it, so upon connection air leaves the fork until pressure in the fork and pump are equal.
    Mar 2013
    Quote Originally Posted by Josh_SL2 View Post
    I see. So the noise it makes when I disconnect is just air in the pump line and exactly where I left it is where it'll be after disconnecting? Good to know. Much easier to duplicate settings! Thanks.
    unpossibles
    Mar 2012
    Yep! When you start unscrewing it from the valve, the valve closes after just a few turns, but the pressure remains in the pump until it's unscrewed nearly all the way. By the time the pressure escapes from the pump, the valve has already been closed and no air escapes the fork.
    R.I.P. DogFriend
    When you connect your shock pump, only connect it about half a turn past the point where the pressure finally reads on the gauge. That way, when you unscrew it, you can give a good, quick full turn so it only gives a quick "pft". And, yes it is normal to read 5psi to maybe 10psi less because of the air going into the pump when you reconnect it (as explained above).
    If you're running 20% to 25% sag, I can all but guarantee you're not going to get full travel. And, yes, set it in descend ("D") mode. Try 30% to 32% as you're sitting on the bike. You don't have to stand, just sit as you would when pedaling along on flat ground. I have my rebound four clicks out from full fast. Then, after you finish riding, check the o-ring and see how much travel you used. If you rode fairly hard, you should have used all but maybe a half inch of the travel. If you took a really big hit, it should be showing close to full travel. If it isn't, reduce the air pressure until you are getting close to full travel (sag be damned). Once you get to where you're using close to full travel, check the sag and the air pressure. That is now your benchmark for that fork/shock on that bike.
    Sag is only a reference point so you can get the pressure set before you ride. 20%, 25%, 30%, whatever. They don't mean squat other than being a way to benchmark your setting so the fork or shock performs properly on the trail so it can be repeated as needed.
    Avid Fun-Junkie
    Reputation: Ricky_J's Avatar
    Sep 2013
    OK... I'll muddy the waters further (though I am hoping not to). First... Fox CTD has BOTH Hi and Low speed compression dampening. You're looking for that extra knob aren't you? Fork or Shock.... doesn't matter, it's got it. The little lever is for the low speed stuff... i.e pedal lunges, g-outs (very low frequency hits). In normal people terms - makes the first part of the down stroke (compression) slower. Sag is always set in full-open compression (descend mode) with nothing to interfere with the travel. Crazy as it may sound... ride science teaches us a rider does actually need a good amount of sag (25% being a base point). Us monsters (I'm 230) can put a beating on suspension for a 180 lb rider because we'd too often be "bottomed out." The first part of this thread talked of "squirrley" handleing. Not a term one would use if the suspension was under-sprung.
    "Rides low... clunks on even small hits... makes it very hard to get lift for a jump..." Those describe soft suspension. "Squirrley" is a term riders use when the suspension jumps back fast... "mule kicks", "punches back." That... is controlled by the rebound knob and has nothing to do with the little red lever for CTD. CTD... is down only. Rebound is up (extended suspension). And... CTD is for when things are to change from "lazy" to "active." We could argue fine points and numbers for days. There is no SET PSI... only an average (or ball park) guess. Once the bike is just barely using ALL the suspension on your hardest (repeated) hits AND you are not getting punched or mule-kicked as the suspension unloads.... you are set-up. Oh yea... one final tid-bit... all suspension has to parts, Force and Speed. As in - How hard is the hit and how much time before the next hit. There..... My 2 cetns on the subject.
  1. Do clydes consider tall clydes sandbaggers?
    By Lets Try Science in forum Clydesdales/Tall Riders
    Last Post: 02-04-2017, 07:59 PM
  2. mtb shorts for clydes
    By big terry in forum Clydesdales/Tall Riders
    Last Post: 07-14-2012, 07:36 PM
  3. Clydes - recommend an upgrade 100mm fork!
    By ProfGumby in forum Clydesdales/Tall Riders
    Last Post: 06-20-2012, 06:32 PM
  4. question about fork mounts and fork mount racks (trucks)
    By hazardousmtb in forum Cars and Bike Racks
    Last Post: 01-04-2012, 01:19 PM
  5. Replies: 5
    Last Post: 11-27-2011, 05:18 PM
