Results 1 to 2 of 2
    Another Noob Comparison
    Hey Guys, I have decided to start biking for some fitness and outdoor fun. I am currently looking to get a bike for mostly pavement riding as of right now but want to take it off road a little later (plenty of it near where I live). I have narrowed my selection down to two different bikes and was wanting some input on them. I am currently 6'3 and weigh 347 lbs (down 25 so far and looking to lose more!).
    I understand that feel is important and to try them both out to see which I like better. I plan on doing so this coming Thursday. I was just looking at the specs and was wondering if I like both is there a better buy (I plan on doing some upgrades later). They both are $700 at my local LBS (my current limit for a bike). I appreciate you guys taking the time to look at this for me.
    First bike is a Raleigh Talus Sport 29:
    http://www.raleighusa.com/bikes/moun...s-sport-29-11/
    Frame
    Atomic 13 SL Custom Butted Aluminum, Formed Downtube, CNC Machined Headtube
    Fork
    Suntour XCR 29 80mm w/Lockout, Aluminum Steer
    Cranks
    Shimano Alivo MC430 Octalink 22/32/44t
    BB
    Shimano Octalink ES25
    F.Derail
    Shimano Alivio
    R.Derail
    Shimano Alivio 9spd
    Shifter
    Shimano Alivio 9spd
    Br.Levers
    Promax XL86
    Brakes
    Promax DSK720 Mechanical Disc, 180/160mm Rotors
    Gear
    Shimano HG30 9spd (11-34t)
    Rims
    Weinmann XM260 Disc
    Tires
    Geax Saguaro 29x2.2
    Pedals
    Avenir ATB Resin Platform
    Handlebar
    Avenir 100 Series Alloy 15mm Riser, 31.8
    Stem
    Avenir 200 Series, 3D Forged, 31.8
    Seatpost
    Alloy Micro Adjust 27.2x400mm
    Seat
    Avenir 200 Series Mountain
    Headset
    Alloy Ahead 1-1/8"
    Colors
    Dark Silver/Silver/Blue
    Spokes
    14g Stainless Steel
    Grips
    Avenir Single File
    Second bike is a Hardrock Sport Disc 29er
    http://www.specialized.com/zz/en/bc/...cname=Mountain
    FRAME Specialized A1 Premium Aluminum, Trail 29" geometry, fully butted, formed TT, Double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable hanger, disc only
    FORK SR Suntour SF11-XCM-V3-29-DS-MLO, 80mm, 1pc. alloy lower, 30mm Hi-Ten stanchions, mechanical LO, coil/mcu spring w/ preload adj., spring assisted seals
    HEADSET 1-1/8" threadless, loose ball
    STEM 3D forged alloy, 4 bolt, 10 degree rise, 25.4mm clamp
    HANDLEBARS Alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
    GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
    FRONT BRAKE Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
    REAR BRAKE Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
    BRAKE LEVERS Alloy, linear pull
    FRONT DERAILLEUR Shimano Altus, 34.9mm clamp
    REAR DERAILLEUR SRAM X.4 8sp Midcage
    SHIFT LEVERS SRAM X.4 8sp trigger
    CASSETTE SRAM PG-820, 8-speed, 11-32t
    CHAIN KMC X8 w/ reuseable Missing Link
    CRANKSET SR SunTour, Octalink spline
    CHAINRINGS 42S x 32S x 22S replaceable
    BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
    PEDALS Composite platform, toe clip compatible, 9/16" w/ reflectors
    RIMS Alex RHD 29", alloy double wall, pinned w/eyelets, 32h
    FRONT HUB Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 32h
    REAR HUB Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 36h
    SPOKES 2mm (14g) stainless
    FRONT TIRE Specialized Fast Trak LK Sport, 29x2.0", 60TPI, wire bead
    REAR TIRE Specialized Fast Trak LK Sport, 29x2.0", 60TPI, wire bead
    INNER TUBES Schraeder valve
    SADDLE Specialized XC, Body Geometry, 143mm width, front and rear bumpers
    SEATPOST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
    SEAT BINDER Alloy QR, nylon washer
    Reputation: Joules's Avatar
    The Raleigh is 9s shimano, the Spec is 8s Sram, that's basically the only difference between the two. I'd probably go with the Spec, Shimano's lower-end stuff, I've found, can be hard to keep in adjustment, where Sram is usually more tolerant of crap. Also 8s wear items (chains, cassettes) are cheaper.
    If I were you, I'd also see what you can find in a 26" wheel in your price range. 29ers on pavement won't buy you much (even on dirt they aren't better than 26 for all riders all the time, regardless of what the zealots say), but they are often more expensive. 26" wheels are stronger with the same components and the same builder - yes 29ers can be built strong, but it's easier to build a 26" and with machine built wheels you're going to find in that price range, your odds are better.
