Results 1 to 35 of 35
    Reputation: big_mountain_biker's Avatar
    340 lbs Clyde looking to upgrade to FS
    Hi Guys, this my first post but I have been lurking around the forums and getting some good info.
    I'm 6'2, 340 lbs and looking to upgrade from my 2000 Rockhopper Comp to a full suspension bike that won't break the moment I hop on it. I live/ride in the SF Bay area so I am partial to Santa Cruz bikes.
    I'm looking to spend about $2000, I don't do anything crazy 1'-1.5' drops at most and want something that won't make it any more difficult to climb than it already is lugging my 340 lbs butt up the hill.
    At this moment I'm leaning towards a Heckler D AM for $1800. I emailed Santa Cruz asking what they thought about a rider my size on a Heckler and they said that they don't have an official weight limit for the Heckler but they would recommend a Bullit over the Heckler for someone my size.
    Although the Bullit R FR is not too far out of my price range at $2300 I am not sure that it would be my best bet for a bike that can climb up a hill with relative efficiency. I am not as concerned with the 40 lbs weight as I am with the freeride geometry and possibility of very squishy climbing.
    Any comments from people that have some experience with either being a big rider on a Heckler or climbing with a Bullit are greatly appreciated.
    Quote Originally Posted by big_mountain_biker
    My buddy has your physical stats and rides a Heckler. Believe he runs a 750lb. coil on a DHX.
    Good to hear that the Heckler is standing up to some heavy weight punishment. The stock 07 Hecklers come with a Fox R shock in the rear, do I need to swap this out for a DHX coil shock?
    That's 300 bucks I'd rather not spend initially.
    Aug 2005
    YES..sorry I"m a little under you (330-ish) but started heavier at 6'2" (I don't know why I always put my height..Maybe it makes me feel less fat
    I upgraded from a hardtail to a fs last year and went with the bullit. If you want to email me or call me i can go into a lot more in depth with my research....
    The bullit is a great climber.. We are not "normal" riders we/you need freeride based stuff If you are doing any kind of aggressive singletrack small jumps and stuff. I run a JR T up front and a 750lb spring on my coil. The JR T was a cost decision.. at some point i will get a stronger single crown fork (Magaru wotan?)
    there isn't a air shock That I think would hold up to you for any long time period. I use to run the azonic outlaws until I just toasted my freehub. I just got a mavic deetracks so.. we will see. But, I have gone thru 3 cheaper rear wheels in 2 seasons.. and I don't think it cool to break stuff.. IT just happens.. I ride at least 3 times a week...
    Maybe the heckler will "hold" up to you If you are really just doing light stuff. But you and I doing a 1 foot jump is like a 180lb guy doing a 15ft drop
    Becuase we are such a minority in cycling there isn't a manufacterer that really has a clue to what there stuff will do with us on it.
    Like i said pm me and i'll check in the morning and we can talk....
    long standing member
    Reputation: PCinSC's Avatar
    No experience on either a Heckler or Bullit, but they both seem like they could be good choices depending on your intended use. And since you said you want to retain climbing efficiency the Heckler is probably the better choice. I would recommend that you look into upgrading the rear shock to a coil, and making sure beforehand that there is a coil spring available in the spring rate you will require. Also think about getting the shock custom-tuned by Push Industries. Most likely any shock that the frame comes with will be valved for someone over 150lbs lighter than you. A custom re-valve will probably go a long way towards giving you optimum suspension performance.
    Aug 2005
    The problem is unless someone is really up at our weight "probably " won't cut it.
    The heckler is a great bike bu the rear triangle is not strong/stiff enough for our weight. It will flex way too much.
    I run the stock 5th element/ as well as I picked up a blow out manitou 6 way from SC. I got the 750 pound spring from phattire.com for $20.
    The biggest thing noone has mentioned is the way the shock's stroke is. Different shocks have different stroke lengths that effect the spring rate. On the bullit the 750 is almost too much for my weight vs. another bike with a fox I needed a 1000lb spring..
    Quote Originally Posted by tonyl11
    Agreed. I'm a bit lighter at 275lbs geared up and given the issues that I've had with suspension tuning and frame flex I sympathize with a rider that's 50lbs+ heavier than me. An in depth discussion with the key players (the frame and shock manufacturer and/or Push Industries) would clear up some of these questions of what will and won't work.
    I think you've described pretty much every full suspension bike. I agree again, but I don't think the best answer is to ride a freeride frame when it's overkill in terms of amount of suspension travel and the geometry may be wrong for the rider's intended use.
    Another frame possibility is the Knolly Endorphin. Some of the purported features of Knolly's suspension design include a fairly low leverage ratio and a laterally stiff swingarm. Knolly owner Noel is very accessible and likely could answer any questions regarding a heavier ride and his frames. The downside to the Knolly, of course, is price. A complete Heckler (with upgraded shock) could probably be had for less than just the Endorphin frame.
    Several models from Ventana would probably fit the bill as well. The Ventana's frame designs are customizable and can be built to suit the rider's needs. Again, the frame price is pretty high.
    I have that issue with my Turner RFX. I can't run it at 6" travel because I would need a 900lb spring, which no one makes in the size required. So I'm running 5" travel with a 750lb spring, which works out fine.
    IIRC the '07 Heckler has a 2.25" shock stroke which should give a decently low leverage ratio. What spring rate will be required, I don't know. If the shock valving will work well, I don't know. Confirming this info with SC, Fox and a shock tuning specialist should give better answers.
    Thanks for the input Tony, I'll PM you in a little bit. I'd really like to get the opinions of someone that has gone through the same process as I am.
    I was at the same place you are up until about a month ago. I am 300lbs and 6'4" tall and I was looking at the Heckler and I finally found one to test drive. I found the Heckler much to flexy at my weight. Actually the bike flexed so much as to pop the chain off the crank and land me on my knee. I actually have always had a problem with flexy bikes. I currently am riding a stumpjumper that is beginning to fail in the rear end. I ended up ordering a semicustom ventana that would match my weight and riding style better. I should receive it begining of August hopefully.
    The Ventana's are pricey but I have found nothing else that matches them in strength and rigidity yet. That is my $.02 worth.
    I'll look into the Knolly and the Ventanas. Although the wife may not be too receptive to a 4k+ bike, I can always give it a shot.
    I'm hoping to lose some of my girth by the time I receive my bike, I hope to be sub 300 by that time. (At least that's the deal I made with the wife for budgeting a pricey new bike).
    I've been trying to ride the Rockhopper quite a bit over the past few weeks to drop as much as possible already down 10 lb I've got a couple bent wheels and a broken bottom bracket to prove it.
    Fat guy on a bike
    Reputation: Mordy's Avatar
    Throw away those rockhopper wheels and buy something tougher! That will help. I'm about your weight and my stock wheels on my Comp Disc were totally not up to the job. So far some Rhynolites tied to some XT hubs with fat spokes has held up really well on some decent drops and rough rock garden downhills.
    A couple frames to look no one has mentioned yet would be Chumba XCL and Transition Covert. Both are overbuilt frames and almost all the feedback i've read is very positive.
    The XCL frame cost is about $1300 and the Covert is around $1000, so some of the better deals for clyde friendly frames.
    Are you using the 32 or 36 spoke version of the Rhyno Lite? I think I'll pick up a pair, use them with the Rockhopper with V-brakes for now and use them with disc brakes on my next bike once I get it.
    Are you happy with the XT hubs?
    Chilling out
    Reputation: bear's Avatar
    Another possibility is to find a not-quite-latest model Titus that uses the fsr-style and has their "freeride" lowers. SwitchBlade can do it, Hammerhead 100x, and of course both the Quasi-Moto and the Super-Moto.
    The Super-Moto in particuarly can be setup with a wide variety of shocks (air or coil), travel, are pretty stiff, and is not a bank-breaker (sub 2k frameset for sure). Put some 36-spoke wheels on it (could be Shimano XT to start with and save $), and you could get away w/o breaking 2k by TOO much (or go a bit better on some parts and still keep it below 3k).
    Fat guy on a bike
    XT hubs are holding up so far, at least a lot better than the Specialized and Deore hubs that came on the rockhopper did. They probably aren't as nice in the long run as Mavic, or Hope, or Funn, but they seem a-ok.
    I bought mine from wheelworld.com (actually from the wooldand hills store). Another supplier may not have the same durable spokes on their builds.
    I've decided to continue riding my Rockhopper for now since the frame is still doing well and is a good fit, I'd rather not deal with the hassles & expenses of FS for a 300+ pounder.
    I'm gonna try to drop a good amount of weight by next season and get a Heckler or maybe a Nomad if I'm extra nice to the wife.
    Captain Underpants
    Reputation: Random Drivel's Avatar
    I would avoid XT hubs at your weight. I do have a set on a pair of wheels and really don't like them. Perhaps it's a personal thing though, I'm sure someone will chime in and say they are ok.
    I am running a set of RhynoLites (36 h) on some Hope pro II hubs, the Rhynos have held up really well, considering my weight of around 250-260. I'd rather drop some extra money on some good hubs like Hadleys or Hopes laced to a good set of rims (Rhynos or WTB Dual Dutys) with DT champs, rather than lace them to a set of hubs that will probably be trashed a year from now. If I was going the handbuilt route, that is. Don't even think 32h. Oh, and there are lots of rim choices out there, and you might even consider some prebuilts from Azonic, AtomLabs or others . . .
    SC makes some great bikes, can't go wrong there.
    Just my .02 . . . .
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    My two cents....
    You've got me beat by about 100 pounds but I've ridden Hecklers and owned a Bullit. With the advancements in stable platform for rear shocks, I think either of these two bikes will climb the same. They're basically the same bike but the Bullit is beefier.
    You'll want to ensure that whatever shock/spring combination you go with is right for your weight. My advice here is to over-spec the spring. I've ridden a bunch of FS bikes with a spring spec'd for "my weight". In all cases, the "correct" spring was inadequate for my size and riding style. A stiffer spring doesn't really hurt big fellas. So if there's a doubt, upsize. Even if you drop weight, you'll still want a robust rear shock.
    Good luck, have fun and welcome to the madness.
    Reputation: knollybikes.com's Avatar
    Hey Big_Mountain_Biker:
    I know that you're going to continue riding your current bike for now, but if you're looking at FS in the future, here are some things to consider (and are applicable to any larger rider).
    I think the other people who have contributed to this thread have got most of the information that you require. Since our brand (Knolly) was mentioned, I'll throw out my $0.02 as well:
    As others have said, you're weight is going to basically mandate that you buy a more "burly" frame that what a 160 pound rider will need. As a manufacturer we deal with this all the time: we have customers that range in weight from 100 pounds to 300+ pounds and the difference in stress on a frame and the components is obviously massively different. So, the lightweight riders get the short end of the stick because the frames and components that they want are all designed for someone twice their weight (imagine you pedaling a 100 pound bike up hill). They end up with a bike that's proportionally (to their body weight) much heavier than what us bigger guys have to deal with.
    The flip side is that if you're a heavier rider, you'll find that you may break components designed for "regular" riders or that components flex too much which negatively affects their performance. Or you might just not be able to set up the suspension properly (mainly forks) because springs aren't available for your body weight.
    We have some customers in particular who while not the heaviest guys out there (around 200-230 pounds), are very tall (6'5") and very strong - think Bruce Lee - only a foot taller
    These guys pretty much HAVE to upgrade to more durable, stronger, heavier, components. We had one that bought a Totem fork and sold it after 3 weeks because it flexed too much for him - a 1.5" Totem!!! He's now running an 888SL ATA fork and while he really wanted a single crown fork for his big bike, he was pretty much forced into getting dual crown fork because of his strength and his size.
    So, as most of the others have said, I would err on the side of "burlier". Even if you really only do very small drops and can get by with a lighter frame from a "strength" perspective, you might find that the frame flexes so much that the benefits of steeper climbing geometry and less travel are offset by poor shifting performance, reduced durability and poor rear wheel tracking. Of course, being a manufacturer, I'm going to be biased and err on the side of "stronger" just as Santa Cruz suggested.
    Fox air shocks on pretty much any frame aren't going to work - they have a maximum recommended static pressure of 300 PSI. Our frames have some of the lowest leverage ratios in the bicycle industry (the Endorphin has a 2.4:1 leverage ratio) and are also highly progressive and I can say that you'll exceed the recommended pressure of either the Fox RP23 or the Fox DHX air. The one exception would be the new Marzocchi Roco air shocks - they run MUCH lower pressure than the Fox shocks and that might be an option if you want to save the weight of a coil spring. However, a coil shock is really the most simple way to ensure that you get a shock that works for you.
    Finally, one last thing: if you can find a frame with a progressive suspension set up, it might save a few headaches. As PCinSC mentioned, stock shocks that are set up for regressively designed suspension bikes might not have enough high speed compression damping to resist bottoming out. A progressively designed suspension bike might save you having to have your shock re-tuned by an aftermarket shock tuner. That being said, the additional performance benefits of custom tuning are well established, so it's something to consider independently on its own merit.
    Cheers,
    Noel Buckley
    www.knollybikes.com
    Instead of PMs, please contact me here.
    Reputation: wormvine's Avatar
    Get an 07' 7point. It can take some serious abuse!
    Reputation: RobHoss's Avatar
    wow someone in practically the same position i am in.
    Im 330ish (last time i checked but i think im heavier now) and was planning on getting a heckler, but after reading this thread im kinda put off.
    what about a Yeti AS-X with a DHX Coil?
    Kona Hoss '06 - Stone chipped allready!
    http://www.pinkbike.com/photo/1047276/
    I have a 2000 Specialized Enduro that at the time of purchased I was in 380ish range and to this day its still holding up to every type of riding I do. Although I'm much lighter now, but no nimble reed. It still has its original suspension components, Fox coil over in the rear and Rock Shox Judy XC up front. The only thing that has broken over the years is a tooth on the chainring other than that just regular maintenace stuff. I don't have any problems with too much flexing or bounciness on climbs although I did have to set the preload on the rear shock quite bit to remove the flex and bounce. Right now I'm in the 280ish range and only ride the Enduro on longer trail rides (probably for the gears) and ride my '05 SS Rockhopper daily.
    Reputation: Slipper's Avatar
    Here is my 2 pennies worth
    All,
    I am 320 and 6' 4" and have been riding for many a year....
    I had 2005 Mongoose Black Diamond triple that I bought new for @ $2000...I rode the bike hard, weekly in New England over rock piles,drop offs and roots on my local trails and also on the downhill at Mt Snow and Killington throughout two summers....
    The frame bearings have finally worn out and I am on my second set of wheels....
    Here is the thing:
    I am building a new ride with the parts..why?...because....I found that several of the parts are invaluable to the big guy:
    1.Boxxer Ride- I bought the stiffest springs available . Great shock because it has U turn..With the shock in 5" setting there is hardly any bob when climbing ..riding local trails in 5" or 6" and ski resorts at 7" is perfect...
    2. Fox DHX 4.0- Propedal platform- 1000 Lb spring and propedal 200 psi setting on multi adjustable frame ( Mongoose 6" or 7") allows set up for different trails or the ski resorts.
    Just with these two options alone you should be able to find the right set up as a clyde.
    3. Juicy 7's on 8" discs- big guys best friend...you gotta stop
    4. Avoid 32 spoke, stick with 36 spoke+ on good free ride rim and you should have a wheelset that will last a couple of years
    5.Stick with xt /sram x9 level components and you are good to go
    Try riding different frames at your LBS and then try to get a package that works for you..
    Remember:
    bicycle weight weenie + Clyde = busted bike
    Buy a solid bike for you, have fun and ride it!!
    Cheers
    Gravity is a big man's friend
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I weighed 299lbs at the beginning of June, but have recently dropped about 15lbs. I ride a Giant Reign with a Manitou Swinger 3-Way Air. On the Reign it only requires 190psi.
    I previously had a Manitou 4-Way Swinger Air on a Cannondale Super V that required 280psi to 300psi (rode it for 3 years at that pressure with no problems) because of the leverage ratio. I previously used a Fox Vanilla shock with the largest spring available (an #850 or someything close to that) and it was never firm enough.
    My point is that I don't know if you can get a coil spring strong enough, but it will vary with the bikes available and I personally have been very satisfied with the air shocks I've had on my last two bikes. I think you should at least look at the Giant FS bikes (and lots of other while you're at it) as the leverage ratio of the Maestro suspension is favorable to us bigguns.
    I have never tried air so I can only comment my experience with coil....I could not get a coil from Fox...I believe I ended up getting it aftermarket....I think that people looking for a good new bike should go to all the LBS and try stuff out....It is the only way to go....
    Reputation: jorda's Avatar
    I bought a 07 Stumpjumper Comp FSR that cost $2k a couple of months ago.
    My weight at the time of purchase was 330 and now its under 300 and I have
    not had any trouble with this bike. This thing is built like a tank and the only thing
    I might forsee having trouble with is the wheels depending on how rough you ride it.
    I wanted a FS bike as my back simply won't tolerate my HT any longer.
    I must say that this was the best money that I have spent in a while and I couldn't
    be any happier! It's an absolutely awesome bike!! Yes, there are bikes that are
    lighter, have nicer parts, more travel and cost more $$$... but for a bike that cost
    me $2k. I felt this was the best bike, that I had looked at, for this amount of money.
    Sorry to steal the thread, but what about cranks and BB for us big boys.
    I blew through an ISIS set up and am starting to get some wear and noise from my 5 month old X Drive with XT cranks!
    Keep the rubber side down!
    Wreckon a Transition Preston FR with a DHX 5 (2.0 stroke, 5" travel) would cope with 340/ish lb clyde?
    Reputation: KFOG Big Rick's Avatar
    Hope me too
    Big_Mountain_Biker I'm right here with you.
    I need to upgrade an old GT LTS 3000. Had it since new, loved it, replaced stuff on it, still works. But sometimes ya gotta upgrade. We are close to the same size. If it says "one size fits all" it won't. If it "can't be broken" I will.
    Cursed that I love to ride mtb and would love to have a small sports car. So the Doc says "why don't you ride more" and that's the reason for my new ride fever I guess.
    I know better than to buy an XC bike for my XC style riding, but also know better than to get a burly downhill bike and think it will hold up to me riding DH.
    So I want a bike that will pedal uphill, and hold up for another 10 years with me on it, ending up a little lighter at the end of course.
    The doctor also said "you never see old fat people."
    Dang Doc, that's some serious words. So I am in a SERIOUS search for a bike (frame).
    So I think I am down to 3 choices all built from the frame up with heavy stuff.
    1) Heckler
    I thought this might be it until I read this thread. Strong for a 220 lb guy is one thing, add 100 more and I'm not sure. Now it still might be but my choice but hmmm I'm not sure.
    2) Knolly Delirium T
    Wow they look great on the web. Do they really pedal up as well as people say? I've never seen one, not even a frame in person. There is a dealer in SF, they don't have these in stock right now. I've emailed back and forth and gotten some good tips from Knolly about the bikes. I like that. And I like that they told me it could be built to hold up to me in the low 30# range.
    3) Zinn custom Gigabike
    Maybe. No real reviews I can find. I emailed them today asking lots of questions. The pivot on the bb looks like a good idea, but what do I know.
    Out but looked into include Cannondale. I emailed them about my size and their bikes and got a reply that basically said "no."
    Cost? Well if the right mtb means I sell my KTM dirt bike, so be it. I need to ride pedal power more.
    Anyway thanks for starting the thread and thanks to all the replies. I'm thinking hard about this as well.
    Big Rick Stuart
    I am a KFOG DJ.
    I am what I play.
    http://www.facebook.com/bigrick
    Yep, it's tuff dealing with bike stuff at our size.
    I'll say that I've been pleasantly surprised by how well the Ibex Atlas Pro has been handling me. I was even able to get the suspension setup for my weight with going anywhere near the maximum air pressure.
    At first my theory was that I would get an "All Mountain" bike and use it for XC style riding, and I'll be okay. I wanted a bike with a free ride specific crank/bb, coil shock, 8" rotors and 36 spoke wheels. However almost any bike I was able to find that meet these specs was usually a 7"+ free ride bike, that would be a bear to pedal up hill. I decided to give Ibex a shot thinking I would replace things as they broke since it was a whole lot cheaper than my other options.
    Now I am finding that I am becoming more of an AM rider on an AM bike, I'm doing drops and rocky drop-ins now and have not done the least bit of damage to this thing.
    The Atlas is very similar to a SC Heckler, so I would say that if you are going to be building the bike from the frame up that is an excellent choice.
    From what I hear the Versus Blitz II is a super burly AM bike. Though I'm not too sure about the leverage ratio.
    Another Stumpy FSR Comp rider here. It handles my 290 pounds easily, and I would say give it a try. If you're interested I know a place that knocked $500 off MSRP for an 07 when I bought mine in the Bay Area.
    Hey Big Rick...I've been listening to you since the 80's .
    Scandalous
    Reputation: bearonbike's Avatar
    Feb 2007
    ... and if we just ... hope you get what you want.
    I am a "bigger" rider that has been riding for years on bikes that worked as best as possible for me. I had a LTS with a heavy spring, an AC with a heavy spring, another AC witha heavy spring. The point is as a larger rider we can't expect to be able to walk into a shop and walk out with a bike that works for us same day, like clothes shopping. With that said your budget may be low but it is doable. I just bought a Ventana X-5 with the best thing ever... a "heavy duty swing arm" and a "Quad bearing set". This made the biggest difference in the world for me, the biggest thing is its torsionally stiff. Ventana, ie Sherwood and Theresa, do a great job with their product. Though it can be pricey, you won't be disappointed. Plus they offer a thing to think about at this time... frame trade in program. So if in the future you end up a 215lb super Clyde, you can trade up...or not.
    Also if you want to, PUSH industries does customized shock tuning on the COIL DHX not the Air though. So between a valving that works for your frame and body style, and a stiffer spring you'll get what you want. There are spring shops that will also do custom spring rates and sizes depending on stroke and weight. I have a buddy that is 275 and he has his RP3 "Pushed" and a high volume air canister added and has been happy as a clam. So that is another thing to think about.
    You can do it, you can build a bike that works for you. It will take time and money, with most people those are both in short supply. Be patient and take your time. If you want to know what else I went with just e-mail me and I'll give you suggestions, I am not going to list every part I have, as no one really cares. PS all my suggestions have blown you budget out of the water. SORRY
    Scandalous
    Feb 2007
    I shoulsd have read all your replies. I see you got a bike already. good luck and have fun.
    Captain Underpants
    Quote Originally Posted by KFOG Big Rick
    Rick, I don't know your riding style but I know where you ride. One bike to consider is the Turner Spot, might be more $$ than you want to pony but it would more than likely do the trick. Nice, all round trail bike that will work with a number of forks. I have seen +300 # guys on these. If you build a set of burly wheels (Rhynos or KH, Azonic or AtomLabs), TA fork and rear, you should be in good shape. You want burly parts, and the best way to do this is go semi--custom. If you want to get a feel for how Turner's ride you could demo my Sultan next time I am in the Ebay visitng the 'rents. At 260 nekkid I have not busted a Turner yet, and I started at 280#.
    Feel free to PM me with questions.
    Captain Underpants
    Quote Originally Posted by Random Drivel
    Just my .02 . . . .
    EDIT: Forget Hadleys. DT 440's all the way.
    Good job! Gigabike holds up to North shore abuse
    I can relate to broken hubs, bottom brakets, trashed rims, cracked frames. I spent a lot of years, trying to adapt bikes to hold up to my dimensions. I'm 6'9" 275 lbs (300 geared up)and my Gigabike has been holding up to my weight well. I don't leap off tall buildings (2 -4' drops max), and nose down most everything, but the money I spent on this thing has been the best I've ever spent. Zinn has nailed the leverage ratio for us heavier riders, and the bottom bracket pivot has been maintenance free. Look at the custom cranks if your anywhere over 6'3"(you can never go back again)
    I ride 29" 36 hole Kris Holm mountian unicycle Rims, with a heavy spoke, and for a heavy clyde i'd suggest no less. Used to thrash Rhinos regularly, and these haven't even needed more than a tweak here and there in a year and a half.
    On the back a Vanilla R is all it needs to hold your weight since the leverage is set up differently, and with the propedal it climbs like a dream.
    Avid Juicy 7's do the job well, but with for Clydes the biggest difference is the much larger contact patch of the 29ers. Great brakes only work when the tires can hook up. Steeps used to scare the crap out of me because the tires just could grab enough to slow me down. I've a fair number of stiches from corners I couldn't make when following my 170 lb friends down the hill. They blasted around the corner at the bottom, I took out a stand of saplings. Nothing scarier than accellerating down a hill with your brakes on full.
    For me it was money well spent for a really great All Mountain bike that has stood up to lots of abuse. I won't be looking for another bike anytime soon.
