Results 1 to 6 of 6
    Reputation: mitzikatzi's Avatar
    310lbs and a Coil Tora?
    A workmate is looking at getting a Giant Filter 1 (in Australia).
    It has a RockShox Tora 302 coil 100mm w/PopLoc Fork.
    The bike is going to be used mainly on bike paths not really off road.
    Would fitting a stiffer spring make the fork suitable for a 310lb rider?
    He is on a very tight budget. The Filter is on sale at a good price.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    I have a rock shock tora 302 coil on my Hardtail. I am also about 300 pounds. It is sufficiently stiff for me. I don't feel the need to upgrade the spring.
    Also if it is primarily being ridden on bike paths, then the fork can be locked out.
    thanks for the info Big B Murph
    Oct 2007
    Quote Originally Posted by Big_B_Murph View Post
    I weigh about 230 and I felt it necessary to install the x-tra firm spring in my tora coil. Just depends how you like it.
    Reputation: GTscoob's Avatar
    I'd go extra firm spring and swap the oil out for heavier weight to add a little static compression damping.
    Stock coil is for 160-180lb riders. Firm is for 180-200lb. X-firm is for 200-220lbs.
    Locked out shock all the time will kill the damper but at least Tora's are easy to work on. Throw an Argyle motion control unit it there and swap the damper fluid out for 7.5wt or 10wt over the stock 5wt and you'll be better off.
    Oct 2007
    Quote Originally Posted by GTscoob View Post
    X2 , the Argyle unit helps a lot.
  1. Help with new Tora 318 Coil
    By sonypete in forum Shocks and Suspension
    Last Post: 08-09-2010, 11:49 AM
  2. Tora 318 Solo Air (&) Tora 318 U-Turn Coil For Clydesdales
    By Hardtail Rider in forum Shocks and Suspension
    Last Post: 08-01-2010, 02:11 PM
  3. RS Tora 318 Coil U-Turn vs Tora 318 Solo Air
    By Frankie Figs in forum Shocks and Suspension
    Last Post: 03-04-2010, 08:10 PM
  4. Tora 318/302 Air Or Coil?
    By DannyBoy1 in forum All Mountain
    Last Post: 11-19-2009, 03:14 PM
  5. Tora 318 Solo Air (Or) Tora 318 U-Turn Coil For Clydesdales
    By Hardtail Rider in forum Clydesdales/Tall Riders
    Last Post: 08-10-2009, 05:11 PM
