Results 1 to 3 of 3
    TRANCER
    Reputation: Biohazard74's Avatar
    215 lbs geared up and Kenda Excavator 26 x 2.1 pressure
    What pressure are you guys with similar weights running with these? Wet, rooty, loose rock etc etc?
    Ride
    TRANCER
    Bump
    Ride
    TRANCER
    Went ahead and field tested them myself. Let me say that these roll just a bit better than the Nevegals and are better in the sand than the Nevegals but that's it. I ran them at 38 psi, 35psi, and 32psi. At 32 they were a bit too soft for someone in my weight . At 35-38 they felt the same imo. On the wet roots they were not good at all. Fine on wet rock but not great. On the sand and hardpack they did roll very very well compared to the Nevegal. I'll probably put these back on when it dries up a bit down here. Not good for the wet. Washed out every time I touched a wet root. Not a bad tire. Just keep them dry.
    Ride
  1. 215 lbs geared up and Kenda Excavator 26 x 2.1 pressure
    By Biohazard74 in forum Wheels and Tires
    Last Post: 12-04-2013, 08:01 AM
  2. Kenda Excavator VS Nevegal
    By yohyat in forum All Mountain
    Last Post: 04-14-2013, 12:08 AM
  3. Replies: 19
    Last Post: 11-05-2012, 08:51 PM
  4. Kenda Excavator DTC
    By iammemares in forum Arizona
    Last Post: 05-01-2011, 09:21 PM
  5. Kenda excavator
    By fxr man in forum Wheels and Tires
    Last Post: 01-17-2011, 10:35 PM
