Page 4 of 4 FirstFirst 1 2 3 4
Results 76 to 83 of 83
  1. #76
    Bigger is better!
    May 2005
    200mm crank ?s 38inch inseam am I really a candidate
    I also found that a 122,5 spindle gives a good chainline on the 200mm IRD cranks.
    Running 1x10 with the middle chainring only.
  2. #77
    Do you get better results driving with the 200's ?
  3. #78
    Bigger is better!
    May 2005
    I haven't done any tests as such, but the new cranks feel "right".
    With a 42" inseam, they should..
  4. #79
    I Am long legged but you are a definite Daddyo long legs.
  5. #80
    Quote Originally Posted by Realslowww View Post
    I can certainly notice a difference going up - climbs where I used to drop onto the inner I can now make on the middle chainring. Along the flats I would say that there is less of a noticeable difference - hard to tell.
    Is it worth going to 200's? I would say yes if you do a lot of climbing and can afford the decreased ground clearance... although you do get an equivalent increase in bar height.
    The IRD's are nicely polished but the casting is a bit rough in places. I also had to bend the chainring bolt tabs to get the rings to run flat. They're the cheapest way to try extra long cranks - if you already have chainrings to fit.
  6. #81
    Feb 2014
    Quote Originally Posted by 8iking VIIking View Post
    He climbs with 50-11 gearing, he doesn't need pictures
    LOL! That has the makings for a Chuck Norris joke. Or maybe the man from Dos XX.
  7. #82
    Quote Originally Posted by Freightlinerbob View Post
    Thanks for all the help, all the problems went away after I went to high quality 180mm cranks. My stride got all straightend out and my speed went up and I spin more. The stock cranks were flexing and messing me up.
    I need another bike for Mountain biking on the trail. I built this for a around town do it all beater and it is great but I need something in a 29 or 650 to take off road.
    I should by the 200mm, they would work great on my 26 XXl with 29's and 40 CM tires. It turned out real good and worth building.
  8. #83
    Reputation: davidfrench's Avatar
    Jan 2011
    For long legged riders over here: the DirtySixer campaign is about to end: https://www.kickstarter.com/projects...l-people-36-wh
    Ask me any questions. Cheers
    DirtySixer Bikes
    Santa Cruz, CA
    Big 36er bikes for tall riders
    DirtySixer
    Facebook
    Instagram
  1. Inseam just under 32 inches riding a 29er.....170mm crank??
    By vizsladog in forum XC Racing and Training
    Last Post: 12-12-2009, 08:47 AM
  2. Riders with 29" inseam...What size crank do you use?
    By nice_camel_toe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-28-2009, 01:17 PM
  3. Seatpost length? 34" inseam, 175mm crank...
    By SeanHoffman in forum General Discussion
    Last Post: 08-20-2007, 02:20 PM
  4. Yet again ... crank length for short inseam?
    By shapirob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2006, 05:34 AM
  5. Crank Length-29.5" Inseam
    By intheways in forum Women's Lounge
    Last Post: 05-26-2004, 11:41 AM
