Results 1 to 12 of 12
    Nov 2006
    20 tooth grannies?
    Today I climbed up Mt. Tamalpais on my 3x9 Karate Monkey. I'm running a regular Shimano LX triple in front and a SRAM 11-32 in back*. The 22-32 worked on almost everything...
    So, who's running a 20 tooth granny?
    What kind is it? Where'd you get it?
    What kind would you rather have?
    What kind of crank do you run it on?
    edit 1:
    * I forgot to mention that I tried to run an 11-34 cassette on this frame, but found that there wasn't enough space between the 34 and the upper derailer pulley (on my shimano XT M750). The derailer hanger on a KM is not very far from the rear axle, and doesn't seem to offer as much space for large cogs...
    Former Bike Wrench
    20 tooth is available in the old 5 bolt compact 58/94 pattern. The newer 4 bolt 64/104 cannot go smaller than 22 tooth as the bolt pattern is too large for a 20 tooth.
    Have you considered going to a 11-34 in the back?
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    There are 4 bolt 20t chainrings available.
    The company is called action-tec.
    Check this out::
    Action Tec 20t Granny?
    and this:
    http://www.actiontec.us/index.htm
    http://www.actiontec.us/prices.htm
    R.I.P. DogFriend
    Quote Originally Posted by beanfink
    I am.
    What kind is it?
    Race Face 5 bolt steel
    Where'd you get it?
    Found it on a bargain table when Cambria briefly had a shop on PCH in Redondo Beach. Cost me $5.
    I don't know that I'd rather have another kind. This one is a lifesaver... er, lungsaver.... um, I mean legsaver
    Race Face Turbine - 5 bolt square taper
    There you have it.
    Former Bike Wrench
    So you either have to get a squarish 20 tooth (which seems like would defeat the purpose as the gear ratio would constantly be changing) or you have to break out the dremel to fit a round 20 tooth on a 4 bolt crankset.
    Not exactly a strait forward product...though doable
    Captain Underpants
    Reputation: Random Drivel's Avatar
    Quote Originally Posted by mtnbiker72
    Ha.
    I am running a 20t Ti ActionTec on an XT (104 bcd I think?) crankset. Works fine. Perfect for Tam. got it from Universal.
    You can order one from Boone as well, as long as you don't mind the 4 month wait.
    I take mine up Burdell all the time.
    All you naysayers and internet armchair theorists are SMOKING CRACK.
    RHRF!
    Reputation: titusbro's Avatar
    Not True...
    ...I've been running a Boone 20t Ti granny (no 'dremel' mods) on my RaceFace Deus 4-bolt crank for 2 years now. It's just as round as a 22t, only smaller...
    BTW...I'm a 230lb clyde and I use the 20t in conjunction with an 11-34 cassette without any rear derailleur (Sram X.9) pulley rubbing.
    "The secret of joy is the mastery of pain." (Anaïs Nin)
    Reputation: Rotmilky's Avatar
    Running 20t-30t on my RIP9 with an 11-34 cassette
    Salsa 5bolt 20t that I picked up from Cambria
    I like the 20t chainring. I'm going to add a 36t cog to the cassette in the spring. I'll drop the 11t cog and run 12-36.
    190mm Profile Racing
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    I read somewhere here on MTBR of someone using spacers on their XT crank instead of Dremeling the stand offs.
    Riding Fat and still just as fast as I never was.
    pedal pusher
    Reputation: f3rg's Avatar
    I run a 5-bolt 20T grannie on my Race Face LP. There's nothing too steep to climb with it. You can still buy them at JensonUSA, I believe.
    Reputation: Nater's Avatar
    Another option
    Replace the beta-adjustment screw on your derailleur with a longer one. It'll allow you to move the top pulley farther away from the bog cog allowing the use of your 11-34 tooth cassette. 2 teeth in the back is a bigger gear ratio change than 2 teeth in the front...it'll be much cheaper for you too.
    Quote Originally Posted by Nater
    By my math, 2 teeth in the front makes a bigger difference, and gives a lower ratio...
    22/34=.647
    20/34=.588
    Diff=.059
    22/34=.647
    22/36=.611
    Diff=.036
    A 22/38=.578 would be slightly lower than the 20/34=.588, but 4 teeth larger.
