Page 2 of 2 FirstFirst 1 2
Results 26 to 29 of 29
  1. #26
    Oct 2012
    8 months on one chain is a record i'd be proud of.
  2. #27
    MaverickMotoMedia.com
    Reputation: Gigantic's Avatar
    Quote Originally Posted by Bike Whisperer View Post
    Just FYI-10 speed chains use the same thickness rollers and side plates as 9 speed chains. The are made to higher tolerances which makes them narrower and more expensive. For strait pin pull strength they are just as strong if not stronger than 9 speed chains. They however don't tolerate side loading as much so cross chaining is a big no-no.
    Regardless of the chain, big guys will break chains more often if they have poor shifting technique and cross chain a lot.
    For the record I have never broken a 10 speed chain, I did break a few SRAM 9 speed chains about a decade ago (and even then if was from bad shifts on my part) and have since used either Shimano or KMC chains with no issues.
    this.
    Maverick Moto Media Motorcycles, Mountain Biking & Social Media Mgt
    Facebook Twitter Instagram
  3. #28
    Ride On!
    Reputation: NorthSideOf50's Avatar
    Nov 2013
    Just FYI-10 speed chains use the same thickness rollers and side plates as 9 speed chains. The are made to higher tolerances which makes them narrower and more expensive. For strait pin pull strength they are just as strong if not stronger than 9 speed chains. They however don't tolerate side loading as much so cross chaining is a big no-no.....
    Just curious, if you go with a t 1x10 or 1x11 how do you avoid cross chaining ?
  4. #29
    Reputation: tigris99's Avatar
    I have a set of kmc x10. I bought 2 figuring id wear them out quickly as im 265 in my boxers now, was 285-290 when I went to 10s. I stand and mash when I need to etc. Both chains started use march last year, I switch from 1st to second chain end of season, 1st chain as 75% life left, can't see wear on a ruler on this chain yet. And at $25 a chain im a happy camper. I went through 8s chains 2 a season easily before.
    Mainly avoid light weight chains. Ti or fancy looking feather weight stuff, won't last u long. When it comes to being a Clyde, forget bling and feather weight unless u got really deep pockets and like replacing parts.
    Sent from my Nokia Stupidphone using Tapatalk
    Trek Marlin 29er
    Like It, Love It, Want Some More Of It!
  1. shimano hg94 10spd chain
    By mtbbenny1 in forum Shimano
    Last Post: 02-14-2013, 07:46 PM
  2. Sram 10spd chain on new shimano 10spd dynasys
    By mtnbiker67 in forum 29er Components
    Last Post: 05-20-2012, 06:45 AM
  3. 9sp crankset 10spd chain
    By hobiesmith in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-16-2011, 03:06 PM
  4. Can I use any 10spd chain with my XX drivetrain?
    By YacobCzech in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-06-2011, 05:19 AM
  5. Shimano 10spd cassettes with Sram 10spd
    By Ranger Pride in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-04-2011, 07:07 PM
