    Red Rider
    Reputation: redrider_stx's Avatar
    Nov 2006
    Yakima Lock Core Removal
    Hello all,
    I just purchased a set of Q Towers for my car. I have a set of lock cores (6). I currently have 4 installed on the Lowrider on my SUV. I installed the 2 extra cores in the Q Towers and want to remove 2 cores from the Lowrider. I tried lightly tapping them on the rear and installing the key and pulling them out but that didn't work. Seems like the should be relatively easy to remove. I couldn't find anything on Yakima's website.
    If anyone has a method or solution for removing the cores, it would greatly appreciated if you could share.
    RIDE OR DIE...
    On MTBR hiatus :(
    Should I assume you've got the "blank" Yak installation / removal key?
    Unlock, remove key, insert "blank" key, wiggle, pull straight out. Might take a little prying with the tip of a scribe if it's been installed over a couple of winters.
    <img src="http://www.rackattack.com/dynamicimages/productimages/yakima-single-sks-lock-core.jpg">
    speedub.nate
    · MTBR Hiatus UFN ·
    Red Rider
    Nov 2006
    Ahhhhhh! So that's what that key was for... Good thing I kept it with the rest of the paperwork. It worked perfectly. So where do I send the six pack to Speedub. Nate? Thanks a million.
    RIDE OR DIE...
    On MTBR hiatus :(
    Quote Originally Posted by redrider_stx
    Just PM it to me. I'll get it.
    speedub.nate
    · MTBR Hiatus UFN ·
