Results 1 to 51 of 51
    Super Clyde
    Reputation: askibum02's Avatar
    What are those with trucks using for racks?
    I'd like to get a rack for my '16 Ram 2500, I'm tired of just throwing my bike in the back. Eventually I'm going to damage the bike, it's only a matter of time. I don't want a tailgate pad, because I use my backup camera, and I don't want a hitch mount because it will cover up my plate when not in use. Ideally a low profile crossbar system that I can leave on with my tonneau cover in place. Any ideas?
    I wouldn't **** you, you're my favorite turd.
    I set up a system above the tonneau cover on my 1500.
    Works great, carries 4 bikes. It is a bit of a pain to roll up the cover with the rack on though.
    Super Clyde
    Quote Originally Posted by Lic-Niner View Post
    Is it of your own design, or did you buy it somewhere?
    Itís a non-standard combination of Yakima parts. Itís not available as a kit, but I didnít have to fabricate any of it. The tracks on the bed rails are designed for being installed on a topper or fiberglass Jeep roof, and I used skyline tower feet for the quick release feature. The aero bars are a longer size than the kits include. I had to drill a bunch of holes in the bed rails to bolt down the tracks.
    It got pretty expensive, but it works so well I donít mind. I have enough space to carry 4 riders, bikes and a weeks worth of gear (the truck is a crew cab)
    Reputation: Cuyuna's Avatar
    May 2017
    I just used some good old PVC. Cost me about $15. I prefer to load the bikes in the bed. Waving in the breeze makes me nervous. I didnít want to drill any holes, wanted it easily removable, an wanted to be able to close the tonneau cover when not in use. I didnít want a tailgate pad, and didnít want a hitch mount. This PVC rack thing is held in with some bungies, and the bikes are held upright with some bungies in the back if Iím going to be driving any distance.
    Reputation: drag_slick's Avatar
    Sep 2004
    I made a dropped one so I could get in and out of the garage with the bike on the rack. Tonneau cover will close over the racks when not in use.
    What are those with trucks using for racks?-img_20160927_192658321_hdr-small-.jpg
    Iíve used multiple methods.
    Hitch mounted rack - simple, easy to take off when not in use, and doesnít interfere with bed space, but adds length and somewhat expensive for a good one
    Tailgate pad - inexpensive, easy to use, less secure (requires separate cable lock or similar), possible rub/wear on frame, fork, and tailgate over time
    Bed rail mounted fork rack (Yakima Bedhead/Blockhead or similar) - simple, fairly inexpensive, holds bikes securely, works with all forks (with an adapter), requires separate lock system for through axle forks (cable, etc.), takes up some bed space, requires front wheel removal
    I use the tailgate pad more than anything else. Ease of use/laziness
    Deviant
    Reputation: Weaponized's Avatar
    Oct 2017
    I just ordered one of these tailgate pads. My problem is that I have a Raptor with a truck box in the back and I need what little bed space I have for other things when not being used for bikes. I'd also prefer not to drill holes in my truck if I can avoid it. I tried hanging my bike over the tailgate today before I ordered and was surprised how stable the bike was just sitting there over a towel.
    https://www.evocusa.com/collections/...lgate-pad-2015
    Deviant
    Oct 2017
    Quote Originally Posted by Cuyuna View Post
    Super Genius! I like that but my box is far to short and I'd have to leave my tailgate down.
    Reputation: mpress's Avatar
    I've been researching this exact same thing. I'm looking for a way to transport my bikes while still keeping items in the bed dry and secure. The Ridgelander by Undercover looks like a pretty slick setup. Bonus that I get to reuse my existing roof trays...
    https://www.undercoverinfo.com/p-371...dgelander.html
    Iíve got a rolling, hard tonneau cover from Pace Edwards, the Ultragroove. The side rails are slotted to accept Yakima or Thule towers and crossbars. All accessories that would work on rooftop applications will work over the bed, and donít interfere with bed space or cover function. The cover also locks closed with my locking tailgate, securing and waterproofing bed contents. Not cheap, but awesome.
    May 2017
    I looked at the Pace Edwards, but those Ultragroove systems were $1200, not to mention the mildly breathtaking cost of the Yakimaís and Thule systems. I certainly donít doubt their quality, but thatís just way more money than Iíd spend on a method to transport my bikes, especially given the fact that getting them on the rack is awkward. Itís been far easier for me to just pull the bike up into the bed, put a bungee over the rear wheel and drive on. Getting them down is even easier. That would be my choice even if it meant leaving the tailgate down.
    As to tailgate pads...many of them do have cutouts so that the tailgate latch and the backup camera arenít covered.
    Google ride88, looks pretty interesting to me.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by mpress View Post
    The overlanding manufacturers offer a TON of similar sorts of products. I went to the overland expo (east) recently and saw several. Pretty sure this was one of them. Bonus that they work with Rhino Rack bits. I've got a Rhino Rack Foxwing awning that's pretty killer. They make good stuff.
    This was another cool product that can do similar, but uses the truck's stake pockets. Compatible with Yakima bars.
    Marquette Mounts Truck Rack - Base Rack for Trucks
    I have also used the Yakima bedhead as well as the pvc mount. My pvc mount now lives in my garage, as I don't have a pickup atm. I intend my next vehicle to be a pickup, though. I am personally leaning towards a camper shell with fork mounts inside, possibly on slide-out trays (that can easily be removed from the truck). Depends on how much height I have to work with. I already have a hitch rack that I can use, but I want a solid in-bed option for when I'm taking the camper out, esp for longer trips.
    I have used a tailgate pad in the past, and it's a system I'm not a fan of. ONE shuttle with one, and my bike got several notable scratches. No way would I rely on one of those for frequent bike transport.
    The Ride88 does look pretty good, though, for refinement over the classic pvc rack.
    https://www.ride88usa.com/
    May 2017
    Quote Originally Posted by frints View Post
    That looks like a great rack. I like that you can buy a rack per bike needed. Very clever.
    I can't really tell, but it looks like their KickStarter campaign failed as of about 3 months ago. The needed $130,000 to begin production and raised $25,284. Are these things even available?
    Reputation: sdsyver's Avatar
    May 2013
    Quote Originally Posted by askibum02 View Post
    But a set of Thule T Tracks and bolt them to your rails. Then use feet and load bars. Iíve done it as well. But it is a pain with tonneau cover unless you have the retractable type.
    Sent from my iPad using Tapatalk Pro
    since 4/10/2009
    According to the website I linked, they're hand-building them to order in the USA, instead of doing larger scale production.
    I joined their mailing list and about 2 week ago they said they were ready to order but the 1st production run will take about 2-3 months.
    I've been using a Pipeline rack for a long time but this looks like a better design, the pipeline holds my bikes but they tend to sway back on forth on turns, this looks like it will hold much better.
    There was a post by the guy who created this rack several month ago when he launched the kickstarter campaign.
    I designed the MultiTaskR, by Exodux, a couple of years ago and have been extensively testing and has been excellently received everywhere we have shown the rack. The MultiTaskR went into production a couple of weeks ago and we should start shipping in Late February/ March 2018.
    I started a company called Hurricane Components back in 1995 and sold the company in 2003, we already were deeply involved in bike transport with the product we called the "ForkUp" which is still produced and is currently being marketing by Thule and Yakima as well as Hurricane. We also made cranks, stems, seat posts and other items, so we have extensive knowledge of bikes and the industry.
    With the MultiTaskR, we first designed it as a bike rack, then afterwards thought of all the other uses and users that it could have, such as having other mounting fixtures to carry things like kayaks, lumber, surfboards, SUP, ladders, pipe, etc, without using tie downs, bungie cords or rope.
    The main purpose of this design was to keep what your carrying off of your tailgate so no damage will be caused to either the truck, bikes or whatever you carry. We believe we did just that, as everything can be securely locked to boot.
    I have used tailgate pads in the past, and while cheap and easy, they have potential to cause damage to your bike and your truck.
    The MultiTakR uses all high grade materials such as aircraft grade aluminum and stainless steel. No plastic is used except for the Delrin collets used for inside the bikes steerer tube.
    Attached Thumbnails Attached Thumbnails What are those with trucks using for racks?-fullsizeoutput_f75.jpg
    EXODUX Jeff
    Aug 2013
    I have zero complaints about the Thule Tailgater I've been using for 3+ years now. It's so quick and simple.
    Anthem Advanced
    ECR
    Reputation: mLeier's Avatar
    Oct 2017
    Would you happen to have the parts numbers? I desperately need something like this for our truck.
    Quote Originally Posted by mLeier View Post
    I found my order confirmation email, and I have a parts list but not the actual part numbers.
    2 packs of Yakima landing pad 1
    Yakima 54Ē tracks with bolts
    4 piece set of skyline towers
    70Ē Yakima jetstream bars
    4 pack Yakima sks lock cores
    My everyday setup is two rocky mounts brass knuckles trays, but I have a couple others that I use for bigger groups.
    If you have a longer bed than my 5.5í then you may be able to use longer tracks.
    Hope that helps
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    Seen this last Weds on a ride with a buddy...... simple clamp set-up and very sturdy.
    In the Middle Ages, the biggest mistake was not putting on your armor because you were 'just going down to the corner.'
    Moderator Moderator
    Reputation: 2melow's Avatar
    I had (have) a tonneau cover but ended up getting a Leer topper back in the spring. We just had too many bikes and I was tired of taking our Saris Superclamp in and out of the hitch all the time. Accessing the bed of my truck was priority.
    Thought I would share my setup, 2013 Ram Megacab. My wife and I own a small bike company so we are shuttling bikes and boxes all over the place.
    Topper Roof Rack - Rocky Mounts Tomahawk roof trays (5 of them) on a Leer reinforced topper using Yakima towers and crossbars. This is the fast racking setup, though we need a 5 foot stepladder as itís almost 7í from the ground to the tray. Tray#3 in the middle is hard to access and needs bars turned sideways, but it works.
    Bed (covered) storage and transport: In the bed I have a piece of carpet glued to a 1/16 in. x 4 ft. x 8 ft. plastic panel cut down to 6'5" in length which is bed length in our Ram 2500. This allows for three things:
    1. Our complete bike boxes to slide in way easierĖ bedliner rubber is not box sliding friendly.
    2. Plastic panel + carpet covers the channels in truck bed, my son and I sleep in the bed sometimes for quick riding trips instead of pulling the toy hauler (#RamMegaCabEnve) and the thermarest Tandem LE is super comfy.
    3. We have a carpeted glider board made out of birch ĺ ply cut down which can hold all of the bikes on the roof Ė or 5 more bikes if we are going to a demo for a total of 10 bikes. The fork mounts are staggered, so if we have just 2 or 3 bikes then bars might not need to be rotated depending on width. If we are putting all 5 in the back, then we remove pedals and twist bars.
    If we are somewhere super sketchy, we have a 12x15 canvas painters tarp always behind the back seats of the truck we can throw over the bikes and gear in the back. The tinted windows deters most, and we are not plastered with MTB related stickers which is basically like a roach coach pulling up at a construction site saying ďcome and get it..Ē Though if I ever wrap this truck then all I will need to move to plan B.
    Attached Thumbnails Attached Thumbnails What are those with trucks using for racks?-20171029_140512.jpg
    Front Range Forum Moderator
    Super Clyde
    That's a lot of bikes!
    I ended up with a Thule Insta-Gator. It came today, and new bike comes on Wednesday, so I'll post my impressions then.
    Oct 2017
    Got in touch with the multitaskR folks today. Probably gonna pull the trigger on it. Just so cool and my TLD pad was stolen off my truck so want something thats not gonna get ripped off plus have superior holding ability. Ive got a north shore 6 and a kuatnv for my excursion and travel trailer but the multitaskR just looks so perfect for the truck. Cant wait
    Sent from my iPhone using Tapatalk Pro
    Reputation: ScottW's Avatar
    I had a couple insta-gators, worked ok on the street but off road the bikes would sway so badly that they would work the clamping bar loose. Just keep an eye on it it you drive dirt roads often. I ended up giving mine away and use my One-up in the hitch.
    Super Clyde
    Quote Originally Posted by ScottW View Post
    I don't drive off road much with my bike, so hopefully I'll be okay. I don't that I can use a hitch rack, I have a 2.5" receiver. Having to use a 2" adapter limits my choices.
    Reputation: d365's Avatar
    I would've looked at the SeaSucker products, if you have a hard shell bed cover. Just suction cup it on there.
    I just throw my bikes over the tailgate with a towel, piece of foam under the down tube, and a bungee cord.... I'm a cheap ass.
    Reputation: C.A.S.H.'s Avatar
    Jun 2010
    My Nissan has a five foot bed and my bikes are too long with the tail gate up so I bought a 1upUSA rack. They're expensive but solid. I love it.
    I know you don't want to cover your tag, with these rack they can be left in the carry position and the tag is clear.
    Attached Thumbnails Attached Thumbnails What are those with trucks using for racks?-img_5731.jpg
    The more Marines I have around, the better I like it.
    -Wesley Clark
    Super Clyde
    I loved my 1Up, but I had the 1.25" version, and they didn't make an adapter from 1.25" to 2.5." I think the Insta-gators I bought will work fine. My bikes fit lengthwise with about an inch to spare.
    Jan 2015
    do you want to sell the one-up?
    Super Clyde
    Quote Originally Posted by notso View Post
    I already did.
    Professional Crastinator
    Reputation: Fleas's Avatar
    Despite my initial review, I finally got this one sorted out to where I like it. It is somewhat less flexible in arrangement than I had hoped, but I made it work. And I did get the 2 racks set up close together without the bikes interfering (one forward, one backward). It requires crossbars - mine is Sport-Rak, with a roll-up tonneau cover.
    Swagman Race Ready Roof Rack Review (includes fatbikes)
    -F
    It's never easier - you just go faster.
    Jun 2017
    Thule instagater works great
    2017 Ibis Ripley LS Factory X01
    Super Clyde
    This is the final product today. It worked out well, it carried the bikes securely, they are easy to go in and out.
    Untitled by Brett Valentine, on Flickr
    Nov 2017
    Just ordered an Undercover Ridgelander tonneau cover also. In this way, I can use the hitch of my truck to tow a camper.
    Reputation: Betarad's Avatar
    Made this for my 2015 Ram 2500
    anyone seen anything similar to the undercover rdigelander that also works with a toolbox??
    What goes up must come down.
    2015 YT Capra AL2
    2014 Chromag Aperture
    2008 Pinarello FP2
    Aug 2013
    Sweet. For peace of mind, I made a leash with some 550 cord and a carabiner, that I tied to the front in-bed connection point. I just wrap once around the rear rim and clip on itself with the carabiner, for in case of an accident or some other malfunction.
    Anthem Advanced
    ECR
    Gigantic Hawk
    Reputation: dubthang's Avatar
    Jan 2016
    Bachman1961- Do you have info on that picture you posted. That is exactly what I need for my truck. I would totally appreciate any information. I don't even know what they are called. Thanks
    Mar 2012
    Quote Originally Posted by drag_slick View Post
Name:	IMG_20160927_192658321_HDR (Small).jpg
    This is exactly what I am looking for! Any more pictures or insight into how you made them would be much apperciated! I have a Silverado and looking for a under the cover mount.
    --------- __o
    ------- _`\<,_
    2016 Cannondale Habit
    2014 Surly Pugsley Custom
    Oct 2017
    I just built this. Slips right into the stake pockets so it is easy to remove when not being used. I wanted something where we could still roll up the tonneau cover underneath and my husband wanted something that wouldnít permanently alter the truck. My husband has no vision and didnít want to spend any money so I just built it out of 2x4s to show him how great it would be. Thankfully he agrees, and we will rebuild it out of aluminum next year.
    What are those with trucks using for racks?-f6ef691c-858d-419d-9ee9-e5f4870626bb.jpg
    Apr 2018
    Looking into getting a tail gate pad. But I have a Ram 1500 and wondering how the bikes would sit over the thicker lip of the tailgate. Anyone that has a ram or truck with similar thicker tailgate able to weigh in on how they like a tailgate pad bike carrier?
    Just worried about if it will damage forks on bikes or dent the lip of tailgate.
    Jan 2015
    I have a buddy with a newer F150 that has a very thick tailgate. He uses a pad and it works great.
    Apr 2018
    notso, do you know what one your friend has?
    Jan 2015
    I know it's a Dakine, but I don't know a specific model.
    Sep 2004
    Quote Originally Posted by SRock24 View Post
    SRock24,
    So I bought some Thule square bars then took one to a local steel supplier and had them bend some 3/16's steel into a U channel to fit the load bar. Then cut the U channel into sections and welded it to some 3/16" flat steel as mounting bracket. Drilled a hole sideways in the U to pass a bolt through to secure the bar into the U, then drilled through the inside lip of the truck bed to mount.
    The backing plate the U channel was welded to was sized to get the drop i was looking for to be able to cover the racks with the tonneau cover and get in and out of the garage with the bikes on. So you could make a taller plate or shorter depending on how much drop you want.
    I can get some close ups of something if you want.
    Reputation: plummet's Avatar
    What are those with trucks using for racks?-img_20180218_145244.jpgWhat are those with trucks using for racks?-img_20180218_145305.jpg
    Oct 2016
    What are those with trucks using for racks?-img_0304.jpgWhat are those with trucks using for racks?-img_0305.jpg
    Wolf Racks. Enough for 5 bikes and the John Boat still fits under it.
  1. Replies: 7
    Last Post: 04-29-2018, 01:07 PM
  2. Wheel Wally works great for those with trucks!!
    By curly1 in forum Cars and Bike Racks
    Last Post: 05-18-2016, 11:48 PM
  3. question about fork mounts and fork mount racks (trucks)
    By hazardousmtb in forum Cars and Bike Racks
    Last Post: 01-04-2012, 01:19 PM
  4. How do you feel about yellow fire trucks?
    By garboui in forum The ReCycle Bin
    Last Post: 10-20-2011, 10:06 PM
  5. Specialized demo trucks in Littleton, NH Monday, 10/10
    By radair in forum Vermont, New Hampshire, Maine
    Last Post: 10-06-2011, 06:13 AM
Members who have read this thread: 159
