Results 1 to 22 of 22
    Reputation: pop_martian's Avatar
    My DIY Hitch Rack
    Pictures of my sort of homemade hitch rack. I welded some scrap metal together and used some existing Yakima mounts. Not including the Yakima parts (which I already had) the total cost was about $6.
    <a href="http://www.flickr.com/photos/30428607@N08/4323989002/" title="DSC08189 by Pop_martian, on Flickr"><img src="http://farm5.static.flickr.com/4034/4323989002_fa9cc38b0f.jpg" width="500" height="334" alt="DSC08189" /></a>
    <a href="http://www.flickr.com/photos/30428607@N08/4323990382/" title="DSC08190 by Pop_martian, on Flickr"><img src="http://farm5.static.flickr.com/4067/4323990382_8b91007e5d.jpg" width="500" height="334" alt="DSC08190" /></a>
    This will hopefully save a little gas on longer trips. If anything it will at least be easier to load and unload the bikes rather than using the roof rack.
    "Donuts. Is there anything they can't do?"
    ballbuster
    Reputation: pimpbot's Avatar
    Nice!!
    I might just suggest putting some kind of anti corrosion stuff inside so it doesn't rust itself from the inside out.
    Excellent work!!
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    Looks sweet! I've been looking at making somthing similar for my wifes 07Crv.
    The most important thing is what God thinks about it. He will have the final say.” – Joshua Stinebrink
    ____
    Kimo
    Reputation: GEARHEAD_ENG's Avatar
    Quote Originally Posted by pimpbot
    Excellent work!!
    Might be able to spray some under-body coating on the inside... usually works pretty good.
    Looks good!
    Reputation: kntr's Avatar
    Or just take it off when you are not using it and store it in the garage or out of the rain, since its only one bolt to remove.
    Quote Originally Posted by kntr
    Exactly. I don't plan on leaving it on all the time.
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    Quote Originally Posted by GEARHEAD_ENG
    Looks good!
    i agree this looks good....
    something i have seen here that some guys have done with their lumber and ladder racks, is to have them sprayed with a rhino lining, or line-x for pickup truck beds. it's super durable, easy to clean and seals moisture.
    just an idea, i'm sure you could probably find a guy that does that service in your area, and have him spray down the whole rack, ( minus the bike trays).
    Reputation: david8613's Avatar
    May 2005
    looks light, is it heavy?
    Quote Originally Posted by david8613
    It probably weighs 25 pounds or so.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    looks flexy
    Honestly... ahh I give up
    Quote Originally Posted by highdelll
    looks flexy
    Quite the opposite. It is made from welded 2" steel tubing. If memory serves, racks such as the Thule T2 are made of 1.25" aluminum. So it's thicker and heavier than a T2. The frame doesn't flex at all. I can stand on the ends and jump up and down. Holds just fine.
    I would wager that it could stand up to more abuse than an aluminum made rack.
    Edit: The receiver part on the T2 might be steel.
    ~Disc~Golf~
    ^^ aww man!
    joking
    Nice work, I like it!
    SpecRH
    that is EXACTLY what i am in the process of doing. looks great, i may steal a few tips from urs and implement them to myn!!!!!
    MTB : 2011 Specialized Epic Comp 29er
    MTB SS : 2010 Specialized RH
    ROAD: 2011 Specialized Tarmac Comp
    TOY: Trek 1000
    Aug 2010
    funy car
    Nice rack! (no pun intended... LOL)
    PopMartian
    I'm looking into DIYing something like this myself. Do you happen to have a tutorial (step by step guide with equipment selection) on hand?
    Thanks in advance.
    Quote Originally Posted by Kaizer
    PopMartian
    Thanks in advance.
    Not really. I just made it up as I went along. Just make sure you get your spacing just right between the bars so your bike doesn't hang over too far to one side.
    SpecRH
    my DIY rack looks similar to yours, except i have a piece of angle iron instead of the gutter channel. My only conflict is how to secure the bike besides just strapping the wheels down. Im thinking of a way to fabricate an arm that clinches the top tube. My only dilemna is making it look half decent and fold away.
    TOY: Trek 1000
    Quote Originally Posted by jeeper006
    I made it so I could use my Yakima mounts on it. I am using two King Cobra mounts which seem to do the trick nicely.
    Reputation: Snosaw's Avatar
    Is that a Snow Leopard or a blue merle aussie in the second photo?
    Ski Good or Eat Wood
    Quote Originally Posted by Snosaw
    Blue Merle Aussie.
    Nice rack and nice looking dog.
Members who have read this thread: 4
