Results 1 to 14 of 14
    Hollywood HR1400 platforum 2/4 bike rack
    I'll begin with what I needed:
    Something sturdy enough, and large enough to handle my XL framed 26x2.5" tire wearing bullit. I also wanted something absolutely stable and built solidly. I did not care about weight. I also wanted something that could fold up tidy when not in use.
    I know the thread title is for the rack I ended up with, but I'll begin with a comparison to my buddies Thule 990xt-
    https://www.thule.com/en-us/us/produ...90xt-_-5776509
    I tried my friends thule 2 bike platform rack -
    pro's:
    -Easy to fold up and down once the top bar was out of the way
    -Quick and easy to load the bikes once the wheelbase is set on the cups, easy to adjust the wheelbase
    -Easy to lockdown the arms and lock them - however the locks they use are extremely cheap and look stupid easy to defeat
    cons:
    -The tires on my bike -BARELY- fit inside the retaining *plastic* ratchet straps - in fact the first time we used his rack with my bike, about a block from my house my bike's front wheel jumped out of the rack and my bike ended up dragging on the ground for about 1/2 block before we realized it happened So now I have a flat spot on the end of the handlebar/grip and a gnarly flat spot on the front tire...but alas Santa Cruz bikes are tough as hell so nothing really got hurt
    -Rotating the top retainer bar from verticle to horizontal cannot be done 1 handed despite there being a nice plastic lever there, the bolt that locks into a slot to hold it in each spot gets totally wedged and stuck in place wherever it was left, really poor design IMO.
    -The rack uses a 1.25" hitch to 2" adapter to fit in most hitches, and the adapter is way too small, and even with the "threaded hitch pin lock" the whole bike rack can sway side to side what looks like a foot from the drivers seat but is probably 3-6" in either direction at the edge of the rack...really sketchy looking!
    So onto something different, but still on a similar budget, I picked up the HR1400 for $390 from amazon, 2 day prime shipped for free.
    It arrived today so I went home for lunch and slapped it together, here's some pictures -
    My bike fits quite easily and I threw it into what I felt would be the most difficult to load spot and I still had everything tightened up and ready to drive away in under a minute.
    -Rather than cheap plastic ratchet straps to retain the wheels/tires this rack uses a simple and effective velcro strap - I feel much more confident that my wheels won't be popping out of this rack!
    -I still have some adjustment to play with as I want to have the top hold down bar hitting near the seat tube so it's on a flat bar of the bike, but it felt really secure even like it is pictured here.
    The rack is so stable and secure because of this system pictured - It uses a standard hitch lock at the hitch, but there's a rod that the pin goes through in the middle which is grabbed by this crank pictured, once the pin is in you turn the crank to add tension to it and that's it, locked down tight solidly mounted to the truck!
    The 4 bike add-on portion of the rack attached to the front 2 bike portion in a similar fashion with a hitch pin and tensioned rod on a crank so it too is very tight, I did notice this section does feel not quite as solid as the first 2 bike part, but still tight. Of note this portion inserts with what looks like a 1.5" hitch size as it's too small to put directly into a 2" hitch (I tried throwing this part on the hitch of my other truck and no dice, would have been cool to effectively get 2x 2 bike racks for $400 oh well)
    It can be folded 2 different ways, here's the most compact way for when on the truck, the other way I didn't remember to take a picture of but it's how I have the 4 bike add-on portion stored in the garage for now - you can leave the vertical hold down portion vertical and the arms holding the wheel pockets can be folded vertical, I was able to slip it between my work bench and freezer in my garage no problem, it's about 6" wide by 2' deep folder up that way and stands on the hitch bar by itself.
    It uses hitch pins with retaining clips for all of the folding functions (including tilting down and away from the truck in case you need to get into the back window for something), while not as nice as the plastic pull tabs of the thule at first glance, I feel they will be 100% more reliable in the long run.
    It included 4 keys, and a locking hitch pin + a ~10' cable lock that are keyed the same, while not as convenient to lock the bikes as the locking hold down arms of the thule, this at least looks a bit harder to defeat for the average lock picker, and at least looks annoying enough to defeat that I would feel fine parking at a place after a ride to grab something to eat.
    So for someone looking for a 2/4 bike platform hitch for bikes of any size that is super stable I would definitely recommend this.
    2013 Trek/Gary Fisher Rumblefish Elite XXL/23"
    120mm 29er
    2004 Santa Cruz Bullitt XL White
    170mm 26er
    Mar 2015
    How is the Hollywood HR1400 2/4 bike rack holding up? Are you still liking it and would you still recommend it?
    Quote Originally Posted by helipilot43 View Post
    Still solid with no issues, works with any size bike we've thrown on it perfectly.
    Couple loaded trips from Socal to Colorado and back even Those are 2500 mile round trips.
    120mm 29er
    170mm 26er
    Mar 2015
    That's awesome! Glad to hear. Thanks for the review and the update.
    Jun 2013
    I just ordered a HR1400 this past Sunday. It should arrive either tomorrow or Friday. Currently, I have a traditional Allen bike rack that fits with 2" hitches. I was tired of my 29er getting scratched up by the rack itself or by other bikes' pedals, etc. I tried to use adapter bars on the Allen with my 29er to make it fit better with my wife's bike which has 27.5" tires and requires an adapter bar in order to fit on the Allen rack. I decided the old traditional bike rack was no longer worth the hassle. I tried many different configurations, but the handle bars and seats would always clash. I looked at Kuat and 1up racks... but decided on the Hollywood Racks platform racks after watching instructional videos of the HR1400 on etrailer's website. The only negative thing I anticipate with this rack is the weight. The HR1400 is heavier than some of the more expensive 4-bike platform racks such as 1up and Kuat.
    Jun 2013
    Just got the HR1400 installed. It will get its first test on Saturday.
    the only issue with bar clashing I've ran into is when bikes are similar in size. To counter act that we usually load up alternating the direction the bikes face and dropping the seats.
    It's nice to have a rack that I can load up my XXL 23" framed 29er, or 64cm XXL road bike, right along side my nieces of nephews kids bikes, and the only adjustment part that takes any time is wiggling the tire trays into position.
    120mm 29er
    170mm 26er
    Jan 2014
    Just another view of this rack, I've had mine for a couple of years. The first one I had got rusty in every place where metal contacts metal -- all the pin holes where you lock in the vertical bar, all the pivot points, even the vertical bar with the sliding clamps. I called hollywood and they sent me a replacement for free, all I had to do was send them pictures. They said the new one has an improved finish/powder coat and shouldn't rust.
    I've only used the new one about a half dozen times and it's rusting, too. I do live in WA where it's wet out, but we typically don't go riding if it's really raining, and it is stored in an insulated garage all the time. I don't think it should be rusting. It's not a huge problem, I just put some lube on the joints and they still work fine. Looks bad though.
    The bigger problem is that the foam on the clamps wore through and ruined the top tube finish on both my bike and my brother's bike. This was on a trip from Seattle to Whistler last summer. We both have completely bare metal on our top tubes where the clamps were. I have a pickup now and try not to use this rack, but when I do, I put bubble wrap and a rag under each clamp so it doesn't mess up the paint worse.
    Jun 2013
    Here's the HR1400 with Trek 29er and 27.5er....
    weird, had mine almost 2 years, use it basically every weekend with a variety of bikes. I leave the rack installed in my truck and parked outside in socal.
    There's some surface rust on the pins as the finish on them obviously gets scratched off as you use the pins.
    The clamp pads look and feel the same as the 4 bike add-on which is 90% of the time stored in my garage. The main portion kept on my truck has noticeably faded in the sun when I mount up the add-on, and that's really it. No issues with the top bars on any of my bikes getting scuffed or scratched, even my trek madone 5.2 carbon road bike...perhaps you are clamping it down too hard into the bikes top bar? One of my friends is completely paranoid about his bike flying off and I've seen him jump up to bring all his weight down on the hold down to clamp his bike in...I could see someone who always pulls them down that tight having issues with scratching! I barely make them tight at all, the bikes don't move for me if you have the alignment of the tire trays setup properly so the clamp is on a flat bar or right up against the seat tube.
    I'm still very happy with it!
    120mm 29er
    170mm 26er
    Apr 2017
    Do you keep the rack installed on the truck at all times or do you attach and detach it, if you don't mind me asking? Cause, I wrote a review for this rack a while ago and the one complaint most users had was how heavy it was and that made it a challange to store it if you have to detach and attach it. Did you find that to be the case?
    Quote Originally Posted by Ozzmanbossman View Post
    I don't have a problem taking it off and storing, it might weigh 35lbs for the main portion of the rack, and another 30lbs for the 3/4 bike add-on which I keep separete. If you try to take them off fully assembled and carry around, then sure that's almost 70lbs to haul around and big and awkward.
    Still very happy with it, coming up on 4 years now? I need to order a replacement velcro strap and tire tray hold down clamp, one of my friends left them both loose after a ride and they flew off when I was returning home from his place. No big deal, I could get both from a hardware store if I need to.
    120mm 29er
    170mm 26er
    Jan 2014
    Amazon lists the total weight as over 88lbs so I'm thinking your 35 + 30 is a little low. I don't think the packing material weighs 23lbs. I think each piece is over 40lbs. Anyway, I use mine only occasionally now; when we go camping and need the back of the truck for gear but still want to bring the bikes. I put rags under hold downs (that hold the bike frames) so the frames don't get damaged. I think they are definitely heavy. I hang mine up on a wall for storage and while it's not really a big deal for me I don't think my wife would feel comfortable doing it. If I used it more I'd trade up to something better but since it's now only a few times a year it's not really worth it.
    Apr 2017
    Blind And Saberworks, thanks for the replies. Definitely helped.
  1. Hollywood Buzz-Rider - Roof Rack - Anyone familiar?
    By wheeljack in forum Cars and Bike Racks
    Last Post: 03-13-2013, 11:20 AM
  2. Identify this Hollywood Bike Rack
    By Barheet in forum Cars and Bike Racks
    Last Post: 08-05-2012, 07:59 AM
  3. Rhino-Rack Discovery Roof Rack Bike Carrier
    By Doug_ID in forum General Discussion
    Last Post: 04-18-2012, 07:54 AM
  4. Lost: Hollywood Bike Rack Hook (East Bay)
    By o3zone in forum California - Norcal
    Last Post: 04-03-2011, 02:59 PM
  5. Bike Gallery Hollywood open house
    By free-agent in forum Oregon
    Last Post: 02-03-2011, 09:12 PM
Members who have read this thread: 29
