Results 1 to 9 of 9
    Hitch rack wobble fix?
    I have a Saris Freedom platform style hitch rack. Even with the 2" adapter it still seems to wobble a bit from side to side. I've tried wrapping it with some duct tape but then it is hard to slide into the receiver. From what it looks like, it seems the edges on the sleeve of the rack itself are rounded and that is where the wobble comes from. Anyone have any solid ideas? I may just get out the welder and weld the adapter to the sleeve of the bike rack.
    LOVE THE RIDE!
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    I had this same issue on my Saris Thelma 2. It was horrible. There was so much wobble that when I tightened down the hitch pin, the rack sat noticeably crooked. Saris sent me a new piece but the issue was still there. Ended up at a welding shop and had them weld part of the rack together to prevent this. Fixed it partially, but lost all ability to fold the rack up. I don't know that I would go with Saris again for a rack, for fear of this issue happening again. I noticed that about the edges on the sleeve being rounded. I feel like they should be squared off to prevent the wobble.
    Jan 2009
    Sounds like you need a "hitch tightener" of some kind.
    I'm a fan of this one:
    StowAway Hitch Tightener
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Assuming that the fit is secure, I would like to posit that some wobble is a good thing- otherwise, the energy of the rack and bikes shaking around due to bumps, etc isn't really being dissipated anywhere- so if you tighten up where it mounts to the car, that may cause unwanted stress elsewhere in your setup. I had a Thule hitch rack that wobbled a lot, but it wasn't going anywhere so I didn't worry about it.
    '15 Specialized Fatboy
    '14 Kona Zone Two
    '13 Surly Big Dummy
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Never had any problem with wobble with a T2, but I think this is fairly limited to the "J" style hanging-racks. They tend to do this quite a bit. It's a long lever arm to the attachment point, so that's usually an issue.
    DaFaJa
    Reputation: Corbinworks's Avatar
    1up rack never moves..
    2012 Trek Superfly 100 Carbon /Sid W/C XX / Fox CTD RP / xx1 / xo type2 / Stans Flows
    Tampa FL USA
    Sorry, but false. The more solid, the better. The energy created by torsional and lateral stresses is being dissipated in the metal itself and is well within the elastic range of stresses. Over time it may cause some fatigue stress, but if the rack is properly designed then fatigue failure is not likely at all...more movement, longer moments are more likely to result in failure, not less. Everything should be nice and snug and tight.
    Quote Originally Posted by XJaredX View Post
    Ah, gotcha. Thanks for the explanation
    '14 Kona Zone Two
    '13 Surly Big Dummy
    ballbuster
    Reputation: pimpbot's Avatar
    Quote Originally Posted by mtnbiker64 View Post
    I know a guy who tack-welded a nut to a metal strip, and fixed it inside the 2" steel square tube. Then, he used a threaded hitch pin to snug it down.
    I dunno what the Saris rack uses inside, but if it's hollow and not threaded, it would be easy to add a nut inside, even if it isn't welded.
    That is... if it really bugs you that much. Keep in mind, it's really a non-issue... well, other than it being annoying to see your bikes wiggle around in the mirror.
  1. Nothing fancy, Hitch rack convert into a Roof rack
    By patineto in forum Cars and Bike Racks
    Last Post: 10-05-2015, 08:09 PM
  2. looking for hitch rack for euro ball hitch
    By adinpapa in forum Cars and Bike Racks
    Last Post: 12-07-2012, 07:02 AM
  3. How much wobble/play is normal for a hitch rack?
    By erikrc10 in forum Cars and Bike Racks
    Last Post: 11-18-2011, 09:05 PM
  4. Paid Spam: Saris Cycle On Pro Hitch Mounted Bike Rack (2" Hitch Receiver)
    By Mountain_Smith in forum California - Norcal
    Last Post: 10-05-2011, 04:20 PM
  5. Honda Fit Sport: Hitch Rack or Trunk Rack?
    By EVERYUSERNAMEISTAKEN in forum Cars and Bike Racks
    Last Post: 07-18-2011, 12:48 PM
