Page 11 of 36 FirstFirst ... 78910111213141521 ... LastLast
Results 1,001 to 1,100 of 3529
  1. #1001
    Nov 2006
    Quote Originally Posted by aedubber View Post
    Also maybe this might help answer your wobble question too .. The rack is tight, it doesnt move once you tighten it up.. The wobble you might see or be talking about is cuz the bikes have forks that rotate.. So there will be some type of movement ...
    I have this rack and it is perfectly solid once you tighten it down. The rack is not moving. It's some play from the forks etc.
    This is hands down the best rack I've ever owned.
    Evil Following
    weareelements.com
  2. #1002
    Reputation: Velosprocket's Avatar
    Wow, got my 1up today, amazing rack. The pic's online really do not do it justice! I wish it was easier to change for various tire sizes, but not a huge deal.
  3. #1003
    Reputation: MrEconomics's Avatar
    Quote Originally Posted by Velosprocket View Post
    I got mine today too. I couldn't believe how small the box was. This rack is beautiful.
  4. #1004
    I really like the 1up rack and think it's much better in a lot of ways than a lot of the other racks I've tried. That being said, the latching mechanism is a bit of a pain in the butt, especially if you have more than one bike on there and you want to get into the trunk. Also, that safety knob thingy is not as user friendly as I'd like. I also just noticed today that you have to use a bit of finesse to make sure the arms don't touch the rotors, at least on my demo 8 with 203mm rotors. Like I said, I really like the rack and would buy it again. I've had it for about a year and these are the only issues I found.
  5. #1005
    Oct 2010
    Quote Originally Posted by LowLow View Post
    1) Don't use the safety knob thing. In my experience it's useless.
    2) Move the arm connectors (that pinch the tire) down into a smaller notch. On my 26" bikes I use the 2nd hole from the top and that seems to work fine even on my DH bike. If the big rotor is still giving you issues then move the one for the front wheel down another position.
    3) Yes, pivoting the rack with 2+ bikes is a bit of a pain. Such is life. Luckily it's really fast & easy to remove the bikes and put them back on instead.
  6. #1006
    Really? Do you mean between an XL 29er and a kid's 16" BMX? Because I've never had to adjust the position of the little tire nubbin things. I did notice that the newer arms have switched to a regular nut instead of a wing nut on the older style. The wing nut made changing position easier but looked ridiculous.
  7. #1007
    Reputation: eurospek's Avatar
    Quote Originally Posted by rz79 View Post
    BOOOOYA!!!!! Such an awesome rack
    Were you at Palos today? Parked at Wolf Road Woods (end lot).
    Saw a 1UP 2-bike rack on a white Fusion.
    It only took 2 years to finally spot another one in the wild.
    konahonzo
  8. #1008
    Jan 2011
    Yep! That was me! Best rack ever
  9. #1009
    I like this rack but it looks like a heavy bike would put a lot of on/off pressure on the pivot point of the tire arms as you hit bumps and the bike sways back and forth. The tire arms act like a giant lever so any pressure at the top is magnified at the tire arm pivot point bolt. It seems that if anything would fatigue and break long term it would be the aluminum around the pivot point where the bolt attaches the tire arm to the tray (relatively thin aluminum further weakened by the drilling for the bolt). Also, I would like a through bolt at the receiver hitch. The cam ball might work great but it is comforting to know you have a through bolt especially if you are going on a 600+ mile trip. I would like to buy a rack like this but I would be scared to travel long distance with it.
    One question I would like answered is if the tire arms ratchet & lock into place using holes or if they use some time of friction design? If it is a friction design I would be worried about long term durability because anything based on friction will wear out and give much sooner than a ratcheting/locking design.
    I love the all metal construction and it looks like work of art. I just have some concerns about the engineering. Don't get me wrong Thule has its issues and so does Kuat.
  10. #1010
    Quote Originally Posted by Jerry288 View Post
    To the current 1up rack owners: how well do larger (2.3-2.5) tires fit?
    They fit fine. 2.4 Ardents on both bikes currently and last season I had huge Tioga 2.5 and Michelin 2.5, all fit and cleared without a problem, with room to spare.
    konahonzo
  11. #1011
    Quote Originally Posted by Blk02 View Post
    It is held by metal on metal friction. Based upon the usage of myself and others in real life, I wouldn't worry about it, or anything else you're worried about. I have put about 70k miles on mine have had only minor issues. It's a mechanical device so failure is always an option. The nice thing is the post-purchase support that 1up offers. I need to send my back for service and they have UPS'd me a new shipping box for free-and, they're paying for the shipping to get the rack back to them. And obviously, they're doing the service for free, too.
    There is almost no strain on the point where the tire arm bolts to the tray, because, as you astutely observed, it is a pivot. It is designed to move. All of the strain is transmitted to the locking arm. This is the part that uses friction to stay shut. I have kept an eye on mine as it is an obvious failure point and there has been virtually no wear. If there is, the locking bar is replaceable.
    As for the hitch pin:
    Read the thread. This very question was asked 5 days ago and answered with a great picture. In fact, this question is verbatim...
  12. #1012
    I noticed that the expanding ball tightener loosened a bit the other day. There was a little bit of wobble and it looks like the bar had slid out of the hitch by a bit less than a 1/4" (I have one of those collars on it to mark the position). Has anyone experienced this? I take it there's no way to prevent it other than to check it every so often?
    One other caution: The other day I pulled up to a light and a guy in the car behind me told me that the bikes had fallen. I got out and the rack had dropped to the down position as I came to a stop at the light. I must not have clicked it firmly into the horizontal position. So, the moral of the story is always be careful to click it into the right position and be sure to tighten the collar that secures the trays in place.
  13. #1013
    Reputation: eclipse24's Avatar
    I've been going back and forth between the Serpa and the 1up, but after reading most of this thread, I finally decided to pull the trigger last night and purchase the 1up in black. I only carry one bike, so the one tray option works for me. It would be nice if they had a safety pin for the hitch in case the ball tightener failed or became loose as sbermhb mentioned above.
  14. #1014
    RideDirt
    Reputation: aedubber's Avatar
    Engineer your own rack , problem solved .. Nothing is perfect in this world, you take a chance with life everyday when you wake up. Just sayin ....
  15. #1015
    Quote Originally Posted by sbermhb View Post
    I check mine all the time. Recently, mine developed a similar problem. I washed out the hitch and the ball system and it seemed to stop loosening up. Nevertheless, I'm sending mine back to 1up for them to take a look at.
    My rack, with two bikes loaded, never backed out, even while driving down 4wd trails. But it is disconcerting.
    As for your second problem, I think that you didn't have the locking bar in place. I've never had what you're describing happen except when I wasn't paying attention to the locking bar actually locking into place.
  16. #1016
    My 1Up rack never loosens. I always check the hitch receiver for debris before installing it. After about 100 miles, I check it again and I've never had it get loose.
    J.
  17. #1017
    Anybody have any pics of the 2" / 2-bike rack off the vehicle and folded for storage? I've looked through this thread but did not notice any.
    Also, how would the 1.25" version handle relatively smooth logging road (some potholes to negotiate) loaded up with 2, or even 3 DH bikes (say 40lb each). Would the 2" exhibit significantly less flex in this scenario?
    Thanks in advance.
  18. #1018
    Quote Originally Posted by JohnJ80 View Post
    J.
    I've never had mine loosen, either and I'm much less detail oriented. In fact, it was just habit that made me grab the rack after lunch while getting into the truck. Either way, it kinda bummed me out. There wasn't any debris in there and the ball seemed fine. Nevertheless, the best thing about my 1up is that I've never had to be worried about it. This is a bump in the road for sure but now I get to try out 1up's warranty, FWIW. Oh well. I'll report back.
    Quote Originally Posted by donkeyboy
    ...how would the 1.25" version handle relatively smooth logging road (some potholes to negotiate) loaded up with 2, or even 3 DH bikes (say 40lb each). Would the 2" exhibit significantly less flex in this scenario?
    I have the 1.25" rack and until recently, never have had an issue, esp with flex. That being said, if you don't need the smaller receiver size, get the larger rack. I would. Why not?
  19. #1019
    Quote Originally Posted by BaeckerX1 View Post
    The reasons to not use a hitch pin are simple. You don't have to worry about getting your rack lined up perfectly and dealing with getting a hitch pin through a little hole. You can even adjust the rack backwards a bit to clear a bumper (as long as you have minimum insertion). Also, the expander bolt removes shake/wobble of rack. The expander bolt is more than enough to keep the rack on. Find someone who has one of these racks and try pulling it out after it's been tightened. I know you won't be able to. There is never at any point enough force exerted on the rack in the horizontal direction away from the rack to pull the rack out when fully tightened. I don't care if you're knocking the rack for legitimate reasons, or if you prefer another design, but your posts show extreme ignorance and undue paranoia. Your post about loads makes no sense. There's side to side loads and vertical loads. There's never any significant force directly pulling the rack out and backwards away from the vehicle, unless you have it on the back of McLaren F1 accelerating at breakneck speed. Even then, I'm sure the expander bolt would hold fast.
    If your post about loads was true, when I forgot to tighten it, my rack would have come out when I was driving because it was just sitting in there, no hitch pin or tension.
    And how can you post a PERSONAL REVIEW, when you don't even own the product?
    I think the concern about not having a hitch pin is a legitimate question. Not being able to pull the carrier straight out of the hitch while sitting in your driveway is not really the issue. The issue is what constant vibration in the hitch will do to the ball mechanism over hundreds/thousands of miles. The Thule T2 succumbed to a vibration issue in several well documented instances where the friction fit sliding bars that hold the bikes slowly worked their way off the end of the main carrier spar dumping bikes on the highway. Thule ended up putting a small screw on the end of the main spar to keep this from happening again. The issue with friction fit devices is that they require you to apply torque to a fastener. The performance of that device depends on you remembering to tighten the device and tighten it to a specified torque. The ball mechanism has no visual indication to tell you that it is tightened, not tightened, or not tightened enough. Furthermore, not having a documented case of the 1UP failing is no indication that it will not fail at some point in the future. 1UP has only sold a fraction of the racks that Thule has and we only recently heard about the recall on Thule T2 racks. Incorporating a hitch pin is a fail safe and a very good fail safe. The only alternative I see is using a U-Lock through the chain holes on the hitch and around the carrier, which several people seem to have already incorporated into their setup. If people are using U-Locks as a safety measure then there are more than a few people with concerns. You cannot eliminate every potential issue but I have three concerns with this rack, which have already been addressed by some mtbr members in the pictures I see posted. Don't get me wrong I love this rack but I think it could be improved upon just like anything else.
    1) Friction ball mechanism (fail safe would be to install a U-Lock around hitch chain holes and carrier)
    2) Friction sliding mechanism to lock arms (fail safe would be to put a locking bar through the lower unused holes in the arms so if the arms move outward they will be stopped by the rim of the bike.)
    3) Fatigue at the aluminum arms where it is drilled out and bolted to the tray due to bikes swaying back and forth (I have read at least one report of the arms developing stress fractures on another forum but the user was doing some overly aggressive driving and on this thread one user posted that the bolt on the arm support bar loosened and snapped. Also, I believe 1UP switched from using two bolts to connect the arms to the tray to using a single through bolt. This was done for ease of use in checking/tightening the bolts, but it was most likely done to strengthen the connection due to the leverage from a bike on the arms.)
  20. #1020
    Yes this is true, but unfortunately I don't have the money to prototype my own rack so instead I critique the racks I would like to buy and see if anyone can put my fears to rest, counter my inquires, and answer my questions, which you obviously have no wish to do so why even respond? The reason I ask these questions is because I want someone to respond and tell me I am wrong and give me a good reason why I am wrong instead of just saying "it works fine" and "don't worry" or "engineer your own rack". I can understand people being defensive about something they purchased when someone brings up questions about reliability it is only natural. Nothing is perfect but we should all strive for perfection.
  21. #1021
    Quote Originally Posted by racerwad View Post
    So your rack moved in the hitch? Also, there is a load on the pivot at the tray but not in the folding direction of the arms. The load is from front to back as the weight of the bike shifts during acceleration/deceleration/wind trying to twist/rack the arms around the bolt running through the tray. They did switch from using two bolts to connect the arms to the tray to using a single through bolt which helps the situation greatly (prevents failure of the thin aluminum in the hollow tray) but it does not account for the fatigue in the aluminum in the arm where it is drilled for the through bolt. The arms should be reinforced at the bottom where they are drilled for the through bolt since this is a stress area.
  22. #1022
    Reputation: wsmac's Avatar
    I drive down smooth highways (Northern California...WAY Northern... to Montana, and on another trip past Amarillo, Texas), with no problems for the rack or bike(s) at all.
    Never loosened up anywhere... and I do check these things out.
    I have put hundreds of miles on dirt roads with the requisite potholes and washboard surfaces... again... no problems at all with the rack.
    Just saying that this rack has performed extremely well for me over probably 20K miles now.
    Mine is a couple of years old by now.
  23. #1023
    No Clue Crew
    Apr 2005
    Is that what you want? Or do you want to engage in an interwebz debate about a product you don't own and have no experience with in order to "prove" some sort of point (or perhaps to show how smart you are)?
    Most of us are not engineers. Therefore, you'll need to rely on anecdotal evidence from regular bikers who own the product. I suspect you're not the type of person whose inquiries or questions can be adequately countered or answered, so this is ultimately a no-win situation.
    For what it's worth, I owned this rack and it was flawless. You can go back in this thread and find my initial impressions. I sold it to a riding buddy a couple months ago and he's in love with it. I missed it so much, I just bought another one ... which gave me the opportunity to get the anodized black one that wasn't available when I bought my first one.
  24. #1024
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Nobody is defensive. It is you being offensive.
    It works. It has distinct advantages over everything else in the market. Nobody owes you any "proof". End of story.
  25. #1025
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by Blatant View Post
    I am.
  26. #1026
    The rack didn't move out of the hitch.
    I'm still not sure what you're getting at, however. This is a mechanical device so it can certainly fail. Maybe you should send your feedback to 1up? It's not like any one of us can change anything for you. Obviously, none of us have an issue because we 1) own the rack and 2) still are using it without major problems.
  27. #1027
    Axe
    Axe is offline
    Custom User Title
    We should also write concerned letter to all bike companies - because handlebars are holding on by purely friction and a couple of pinch bolts. They can rotate and you will fall at high speed.
  28. #1028
    RideDirt
    Lmao !! Asking questions like we trying to sell the rack to him , contact 1up and ask them why they haven't hired you to design and engineer their flaws ..
    This is a review thread for people that own the rack , not a tea time and critique session .. We all shared our thoughts and reviews as owners , so take it how you want .
  29. #1029
    Old,slow,still havin fun.
    Reputation: fgiraffe's Avatar
    OK, two weeks in (6 trips with it) and I finally found a minor gripe about the 1UP Rack: sharp edges. I've managed to scrape and scratch myself pretty well a few times folding the rack up and removing it from the car. I think I'll take a small sanding block and some fine sandpaper to some of the edges of doom.
    Anyone else done this, what grit did you use?
    Otherwise: I love it.
  30. #1030
    Reputation: t0pcat's Avatar
    May 2012
    Some of the questions here seem really silly to me, for all you people worried about the 1 up falling out of the receiver why not just take a cable lock wrap it around the 1 up and thru the safty chain hole on your receiver and drive in peace without all these silly worries!
    “An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo
  31. #1031
    Dec 2004
    That's exactly what I did! I was never worried about it falling out but hey better safe than sorry. I bought an inexpensive mini-Ulock for $15. Cheap insurance. Love the 1Up
  32. #1032
    I plan to do the same when mine comes in as well. Hopefully, yesterday was the last ride using the trunk rack.
  33. #1033
    Jun 2010
    I have some Cam buckle straps that I had made previously, they are about 12-16" long and I use one looped through the chain loops and around the rack. If the ball does ever fail, the rack will not go anywhere.
    Edit: Sorry, did not realize this was my first post
  34. #1034
    Reputation: Rock dude's Avatar
    Is there anyone that has this rack on a Toyota FJ Cruiser? I want to know if the rack will clear the spar tire. I will need the rack to extend 8" min to clear the tire. I really don't want to use a adapter, they move around too much.
    I drive around 50 miles a week on some pretty rough dirt and rock roads to get to where I ride (Gooseberry Mesa, Little Creek...) and I would like to know if this rack can take it.
  35. #1035
    Reputation: thatdrewguy's Avatar
    Quote Originally Posted by Rock dude View Post
    1upusa Hitch Mount Bike Rack FJ Review - Toyota FJ Cruiser Forum
  36. #1036
    That looks good, I just wounder if the rack will still fold up. It looks close.
  37. #1037
    May 2012
    [QUOTE=donkeyboy;9381329]Anybody have any pics of the 2" / 2-bike rack off the vehicle and folded for storage? I've looked through this thread but did not notice any.QUOTE]
    Here are a few pics of the 2"- 2 bike rack folded up. In one pic you can see two boxes, the larger is from the 2 bike rack, the smaller has a 1 bike attachment in it.
    Other pics are with rack in back of my Pilot.
    Attached Thumbnails Attached Thumbnails 1up Quick Rack Quick Review.-photo.jpg
  38. #1038
    No Clue Crew
    Apr 2005
    My second 1Up. First one is still being used by a buddy. I do like the black. Was interested to see they've combined the 1 1/4 and 2-inch hitches with a bolt-on piece. Definitely prefer the older solid 2-inch hitch mount. In practice, though, it didn't move anymore than my older one.
    IMG_0195 by dbozman1173, on Flickr
  39. #1039
    Jun 2010
    I noticed you have a blue C-Guide on your bike. I just added one to mine but I m not sure how much it helps. How about yours, are you happy with it?
    Btw congrats on the rack, I d love to swap out my current 1up for one of those.
  40. #1040
    No Clue Crew
    Apr 2005
    The C-Guide is fine. I didn't have many options on the Mach 5.7, given no ISCG mounts and a pressfit BB.
  41. #1041
    Anyone have current pictures of a new 2012 rack with a 29er on board? I just heard they lengthened the arms in the latest racks to better accommodate 29er bikes. I want to see how far the arms come up on the tires. I have been reading and researching a lot and I may spring for it. My biggest worry was only having the ball mechanism to hold the rack in the hitch but some of you are using a U-lock as a fail safe so that should work fine for me too. Also, for those of you with the black rack how has the anodizing held up? Thank you, to all those that replied with your mileage and reliability reports. Those statements go a long way in my eyes as verification of a products sturdiness and real world usefulness. I know my engineering questions seemed offensive but I critically analyze anything expensive I plan to purchase. I want my money to be well spent.
  42. #1042
    Dude, there is a picture of the exact thing you're looking for just a few posts up from here, post #1008.
    How far the arms come up on the tires is also a function of the bike's geometry, specifically the wheelbase.
    Obviously, I don't speak for everyone, but I didn't find your questions offensive, just kinda pointless As someone else mentioned, it's not like we can do anything about 1up's engineering shortcomings.
    Anyhow, I can't imagine that you wouldn't like it. If you don't, just take advantage of their offer to take it back. You don't even have to pay for return shipping.
  43. #1043
    RideDirt
    Ok you need to seriously READ some of this thread please , but anyways ill answer your 29er question . My friend has a Trek Rumblefish 29er in LARGE with 2.4 Schwalbe HDs front and back on it, and its PERFECT ...
    His tire profile is about as wide as my downhill tires .. The 29er fits and stays perfectly on the stand, mind you he also has his mounted via roof rack style on his bmw .
    You need to stop thinking about the ball .. You have to realize the way the rack was made with the weight countering the rack ... You literally need to have the rack perfectly straight to pull it out without any type of friction or force from the hitch .. The weight of the rack offsets its angle when its in the hitch so there is some force applied inside the hitch .. Hopefully you can kinda understand what im trying to say ...
  44. #1044
    Jan 2009
    Jeep Wrangler JKU
    I mounted ours up today. As others have said it's aluminum sculpture.
    To be honest it's heavier than I expected, but it is solid.
    My tail lights are too obscured, so I'm going to have to find some kind of strap on lights...
    More pics here: 2011 Detonator Yellow Unlimited - Page 3 - Jeep Wrangler Forum
    But here's one with the family set-up with a 29er, 26er, 24er and 20er
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
  45. #1045
    Nice setup J Westy!!
    My 1up rack arrived today and I must say, it's impressive!! The black looks great on the back of my civic. I would recommend it to anyone looking for a hitch mount rack.
  46. #1046
    Quote Originally Posted by allensta View Post
    Here are a few pics of the 2"- 2 bike rack folded up...
    Thanks for that. Just what I was looking for. Looks so much more compact than the other companies' offerings.
    ...if you don't need the smaller receiver size, get the larger rack. I would. Why not?
    Two reasons.
    1. The rack will often be used with one bike. It would be nice to just have to handle the single tray rack in these instances (the rack will be installed/uninstalled for each use)
    2. My wife will need to install/uninstall the rack as needed, and she's a little worried that the extra weight of the 2" / 2-bike version might be too much for her. Don't want an unwieldy bike rack to discourage her from getting out for a ride.
    The above reasons aside, I am leaning toward the 2" version. I think the 'offroad' sturdiness of it outweighs the cons. Any other opinions, especially on reason #2 above?
  47. #1047
    It seems like your reasons are so specific, it would be hard for anyone else but yourself to answer. I don't take off the add-on, even though I don't usually ride with someone else. So, I would assume the difference in weight between a 1.25" rack and 2" (each with two trays) is negligible. Shoot, it might even be a draw since the 2" probably has a few less nuts and bolts holding it all together.
    I don't know you, but I know people, and I doubt that the rack will be taken on/off with each use. That's based only on my own experience
    I don't think that there is any legitimate difference in off-road "sturdiness" between the two.
  48. #1048
    I emailed 1Up about what type of anodizing they use on their racks. The two most common types in the U.S. are Sulfuric Acid Anodizing Type 2 "Soft/Standard" and Type 3 "Hard Anodized/Hardcoat". I am hoping that their racks are Type 3 because the anodizing is much thicker and it will have increased wear resistance. Also, I asked them if they use any type of special sealer to protect the black dye from U.V. exposure. I have seen many black anodized parts turn purple or grey after several years in the sun.
    I will let you know what I find out.
    Update:
    I just found out they use Type 2 Anodizing "Soft/Standard" and they use a 6061-T6 Aluminum Alloy to make the bicycle racks. They could not tell me if they use a special UV resistant sealer for the black dye, but they did mention that the black anodizing will fade. 6061-T6 is the same aluminum alloy they use to make rock climbing cams, so it is strong. Also, take note that Type 3 anodizing can cause aluminum alloy to have reduced fatigue resistance since the aluminum oxide layer is much thicker, much harder, and more brittle than Type 2.
    6061-T6 is also used for these items:
    6061 is commonly used for structural components, screw machine parts, frames, brackets, jigs, fixtures, base plates, machine parts, couplings, hydraulic valve bodies, valves and valves parts, fuse parts, gears and shafts, worm gears, pistons, rectifier parts, fasteners, hardware, truck and marine components, marine fittings and hardware, electrical fittings and connectors, hinge pins, magneto parts, brake pistons, hydraulic pistons, appliance fittings, camera lens mounts, bike frames, etc. 6061 is used for heavy duty structures requiring good strength-to-weight ratio with good corrosion resistance. 6061 is easily cold worked and formed in the annealed condition. Cutting, stamping, bending, spinning, deep drawing, drilling, tapping, etc. are all readily accomplished using standard methods
    From Wikipedia, the free encyclopedia:
    6061 is a precipitation hardening aluminium alloy, containing magnesium and silicon as its major alloying elements. Originally called "Alloy 61S" it was developed in 1935.[1] It has good mechanical properties and exhibits good weldability. It is one of the most common alloys of aluminium for general purpose use. It is commonly available in pre-tempered grades such as 6061-O (solutionized) and tempered grades such as 6061-T6 (solutionized and artificially aged) and 6061-T651 (solutionized, stress-relieved stretched and artificially aged).
    Hardness Comparison Chart
    (Rockwell Surface Hardness Rating)
    Stainless Steel
    Low 50
    High 72
    Unanodized Aluminum
    Low 38
    High 44
    Type II Anodized Aluminum
    Low 48
    High 55
    Type III Anodized Aluminum
    Low 60
    High 70
  49. #1049
    Got mine today ;)
    Here's some pictures of my 1UP rack with a large 29er mounted.
    I got the 2" -2 bike rack.
    It is indeed a very heavy feeling rack, just as heavy as all of the top brands.
    It folds up like a transformer though making it much smaller and easy to handle.
    I agree with everyone else that it is much better in person, very well built and very strong/beefy feeling.
    Attached Thumbnails Attached Thumbnails 1up Quick Rack Quick Review.-1upusa-001.jpg
  50. #1050
    Type 3 anodizing is for wear applications (e.g. fork stanchions) and actually has lower corrosion resistance than Type 2 since it has unsealed pores. So, Type 2 would be the "normal" choice for something like a bike rack.
    whatever...
  51. #1051
    All anodize is sealed. If it isn't sealed they forgot
    a step. Type 2 anodize is fine, type 3 is in a different
    class and is a lot better finish.
    Best, John
  52. #1052
    Hop Head
    Reputation: toofdoc's Avatar
    May 2012
    Another very happy 1 up user. I was even impressed by the packaging it came in, very sturdy. There is nothing like this on the market in terms of build quality, others may come close in functionality. Looks sweet in black too.
  53. #1053
    Looks great on the Jeep.
  54. #1054
    Hop Head
    May 2012
    Thanks bro. If you have a black car you must get this rack in black. It looks seemless, like it's part of the jeep. And when not in use it folds up very easily in the trunk. If you don't want to take it off it's so low profile that it's really not an eye sore.
  55. #1055
    Quote Originally Posted by J_Westy View Post
    Can you open the rear door with the rack tilted down?
  56. #1056
    Jan 2009
    No, not in this configuration... it's a compromise in order to tow a trailer at the same time.
    But with the summer soft top, you just unzip the rear window.
    I haven't tried yet with the rack mounted in the lower receiver.
  57. #1057
    Quote Originally Posted by John Kuhl View Post
    Best, John
    Yes, this is correct. All anodizing has a sealer. Type 2 is the most common. Type 3 is usually used on Mil-spec products like Surefire flashlights and can usually only be done in silver and black. If Type 3 is done correctly you can take the blade of a normal knife to the anodizing and it wont leave a mark. The only down side to Type 3 is that it reduces the fatigue life of the aluminum alloy when used in high cyclic loading situations.
  58. #1058
    Reputation: tennisfan76's Avatar
    Jun 2012
    Getting ready to order my first rack
    Please forgive me.......as I am not trying to "beat a dead horse."
    I am super excited about ordering my my first bike rack, but want to make sure I get that best one for me. I had done ALOT of research but had not even heard of 1UpUSA until I ran across this review. After watching every video and reading every review that there is on the internet about the 1Up, I am 99.9% sure this is the one for me. I just have a couple of questions for those of you that are using the 1Up.
    --Because I have a black car ('08 Honda Accord 4dr), I am considering the black over the silver. For anyone with the black rack, is the black worth the extra $50 ($100 if I also get the add-on)? How easily does the black scratch off?
    --How do YOU secure YOUR bike(s) to the rack? Cable attached to what? (Mini u-lock, disc lock, etc. --- pictures would be helpful, if you have them) Do you use any extra measures to lock the rack to your car other than the tool it comes with.
    --One cable lock I was looking at was connected to a locking hitch pin. Does this rack have the holes for the hitch pin to slide through?
    --Has anyone ever had their rack stolen? They claim that if your rack is ever stolen, they will replace it for free. How would they know it actually got stolen? Do you have to provide a police report or what kind of proof?
    I probably sound like one of those crazy people that is over thinking everything, but thanks for humoring me.
    2011 Specialized Ariel Sport
    Hybrid with 29ers
  59. #1059
    a step.
    Sorry for derailing the thread, but this simply isn't correct. Read MIL-A-8625. Type II requires a sealer (usually nickel acetate or boiling water) to hydrate the oxide, but Type III only gets the sealer if specified. The reason for this is Type III are intended for wear applications and the hydrated oxide is less wear resistant, altho more corrosion resistant.
    whatever...
  60. #1060
    Quote Originally Posted by tennisfan76 View Post
    ...I probably sound like one of those crazy people that is over thinking everything...
    You do.
    All of your questions are answered in this thread except theft because no one on MTBR has reported it. That certainly does not mean it hasn't happened. I'm sure that it has. As for documentation, they probably require a police report.
    The tow bar portion of the rack (the part which goes into the receiver) does not have holes. A hitch pin is not needed or compatible with this rack.
  61. #1061
    duplicate...
  62. #1062
    Professional Amateur
    Reputation: Henrythewound's Avatar
    I've decided to order the 1up just deciding whether to go with the single version plus an add on or just go for the double from the start. I have a 2" hitch on a 4Runner so either will work but it sounds like the 2"only version (double) might be a tad more stable. I don't plan on going to more than 2 bikes so the 3 bike limit on the single doesn't matter to me. I save ~$30 by going the single + add on route. I'm thinking it might be nice to just use the single most of the time and break out the add on when I'm transporting a friend + bike but then again It's an extra step to attach the add on.
  63. #1063
    Oct 2010
    Quote Originally Posted by Henrythewound View Post
    The "extra step" to attach the second rack takes a matter of one minute. Unless you're going to be transporting 2+bikes most of the time, just buy the single rack. It will look a lot better on the car when it is folded up with no bike on than the double rack will.
    I leave my 1up rack on the car all year long, so it spends quite a bit of its time folded up on the back.
  64. #1064
    Sounds good thanks for the info. I was just concerned about the smaller hitch size with adapter not being as steady on bad roads. I'm surprised the 1Up site doesn't have any detail pics of the differences but then again their site is fairly sparse.
  65. #1065
    Quote Originally Posted by okiemtnbkr View Post
    ^ This
    I have the older version that worked in 1.25 or 2" hitches. It's solid with 4 bikes on it. I *love* having the ability to only put one tray on and I'd hate to give that up.
    J.
  66. #1066
    1Up does mention on their site that the 2" 2-Bike version will handle off-road terrain better than the 1-1/4". I have the same decision to make and I think I will stick with the 2" because I usually ride with someone else and when I don't it does not bother me having one extra rack out back. Also, I like knowing that when the road gets rough that extra metal and welding is their to hold it all together.
  67. #1067
    I'm leaning that way as well. I do wish there was a 2" single version but it's not a big deal. I did find some photos from someone else on another bike forum, there are some detailed shots of the smaller hitch version with the 2"adapter and ball mounting mechanism.
    Rack installation - a set on Flickr
    EDIT: this was the thread on mtbr with the detailed photos I meant to refer to
    http://forums.mtbr.com/car-biker/1up...ew-534654.html
  68. #1068
    How well does this rack do being left out in the elements? Meaning I'd like to leave it attached to the hitch all the time, but my car is out in the driveway, rain, sun, cold etc.
    So has anyone done this? If so how well do the pivots etc work now?
  69. #1069
    It's a simple connection at all the pivot points. An occasional drop of lube would be all it would require, I think.
    J
  70. #1070
    J
    Don't lube the pivots. They have delrin bushings and the lube would just make it worse over time.
    I have ton of miles on mine and I did notice that when I bought a new add-on it did seem tighter. Otherwise, I haven't had a huge issue with mine. I leave it out in the elements year round.
  71. #1071
    New question here. Problem with my 1Up - Help.....
    OK, so after having some concerns about my 1Up rack loosening and creeping out of the receiver a bit, I re-tightened it and everything seemed fine. Yesterday I went to take the rack off of my car. I loosened the hitch tightener bolt and the wouldn't come out of the receiver. I tried tightening the bolt back in and then backing it out again. Nothing. It seems that the ball is now stuck in place, essentially locking the rack in the receiver.
    I saw on an earlier post where someone had a similar problem, but they were able to access the ball and tap it in to release it from the receiver. I don't have access to the ball, so I'm kind of in a bind. Unless someone has a solution for me, I'm going to have to drop the receiver off of the Jeep and send the whole thing back to the company. Any suggestions? Has anyone encountered this?
  72. #1072
    Did you over tighten it?
    Can you get into the front side of the receiver (they are often open on both ends) and tap it that way after liberally dousing it with WD40?
    J
  73. #1073
    I just spoke with 1Up. They said that this is the first they've ever heard of the problem. He said that the way the tightening system is designed, there's no way that I could have overtightened it. He suggested trying to tap it from the front of the receiver to try to get the ball to drop. So, tonite, I'll give it a shot. I'll keep everyone posted.
  74. #1074
    3 questions. I'm thinking about pulling the trigger. Currently have a Raxter rack, and while I like it, having the simple swap from 1.25" to 2" is a big help for me, as we have a WRX and 4Runner in the family. Also, the Raxter is not as sturdy as I was hoping. Lastly, the "folding" mechanism of the 1Up seems pretty badass, as it would enable us to lean up one of the arms to let the dog jump into the hatch. Right now, we have to lift her over the rack and into the hatch area.
    1) How is the black anodizing holding up for people that have had the black rack for a while? I've got a white car, so was thinking the silver isn't too bad, and for some weird reason, $500 is easier to justify than $600
    2) The Raxter has the "auto stacking" feature, where it's really easy to not have seat to handlebar interference, as the bikes have a LOT of back and forth movement allowed and can still be in the rack. How does that work with the 1Up arms. Can you offset the bikes enough to not have the handlebar in the way of the seat? I know the 1Up rack gets taller the further you get away from the car, but that won't help in all situations.
    3) How easy is it to add/remove the "add on". 80% of the time, I'll be carrying one bike on the rack, and this one bike rack will live on my WRX ALL the time, as I ride 5 days a week. 1 day a week or so, we'll be taking both bikes. Is it easy enough to add the add on as I need it, or is it a pain enough to where I would leave the 2 bike setup on my WRX all the time?
    -Tom
  75. #1075
    Quote Originally Posted by trhoppe View Post
    Can't help you on this one, I have silver.
    1UpUSA has the same, if not better. You have considerable latitude to position bikes side to side to get the handlebars and seats to be separated. Very easy to do.
    -Tom
    I have the older 1.25"/2" version and we carry 4 bikes on it with 3 add on kits. I'd guess that I can add a kit in less than 30 seconds - it's that easy. This is what I really like about this rack - I hate having a rack on the car the protrudes when I only carry a single bike on it. Also, the add on kits make it so much easier to store. I just fold them up and hang them on a hook in the garage. No big deal. Most of the other hitch racks I have are a pain in the tail to store. They are heavy and they are bulky.
    J.
  76. #1076
    For the guys that got silver, do you wish you go the black? Trying to justify the extra expense. Thinking the silver on a white car might not be bad.
  77. #1077
    Jan 2011
    I went back and forth on this as well. I do think the black looks better but it's $50 more and I worried about it showing wear over the long term (scratching, fading, etc.) so I ended up choosing silver. Can't go wrong either way. Since the black is fairly new we don't know how the look holds up over the long term. If I had it to do over again I might choose black.
  78. #1078
    Yea, it's $100 for the 2 bike setup. I'm waffling on that one. I think if black for $500, I would have already pulled the trigger. They need to have a sale
  79. #1079
    I have the silver and like it. Here's the deal - if you have aluminum wheels on your car, the silver will look fine regardless of the color of the car. Save the $100 unless it's a big deal for you. Then get black.
    J.
  80. #1080
    Reputation: kreater's Avatar
    really, really liking my newest addition to the GTI. Very stealth very easy to use.
    Attached Thumbnails Attached Thumbnails 1up Quick Rack Quick Review.-gti.jpg
    Product designer @RSDBikes.com
    "Live dangerously and you live right."
    Johann Wolfgang von Goethe
  81. #1081
    -Tom
    The black model is only ~1 year old, so not sure if that's long enough to really cause a lot of fading. FWIW, my black one is still as-new, but it's only a few months old.
    1Up is THE best as far as handlebar interference...not to worry on that count. Actually, with my bikes, it works best to have the bars on the same side, rather than alternate directions. The upward angle and ability to move right-left makes interference a non-issue.
    The add-on is just 2 screws using the "special" allen wrench. Couldn't be easier to take off.
    Good luck and you won't regret it.
    whatever...
  82. #1082
    Jun 2012
    My first bike rack!!
    I struggled with the decision on color, but I just placed my order for the black 1Up rack and 1 black add-on. I cancelled my order for the Thule T2 and feel really good about my decision, thanks to all of you on this forum. I am just glad that I saw this review before I went through with the T2. I am having my hitch receiver installed on Saturday, so as soon as my rack arrives it will be on my car. I can't wait!!
    Hybrid with 29ers
  83. #1083
    I was able to free the rack from the receiver. I just jiggled the rack until it came loose. It appears that the expander ball got stuck, so after I freed it up, I put some grease in there. The guys at 1Up were surprised to hear of my problem, but said that the way the expander is designed, there's no way for the ball to get permanently stuck.
  84. #1084
    Don't put grease on the ball! It uses friction to hold the rack in place.
  85. #1085
    1Up suggested greasing the ball. If you look at the design of the expanding tightened, some grease on the ball will not reduce the friction/pressure that the ball exerts on the receiver. Also most of the friction and pressure come from the sides of the bar against the receiver and the downward force caused by the weight of the rack and bikes.
  86. #1086
    Dec 2004
    Not sure if this has been mentioned already. So far love the rack, however I have encountered a flaw.
    The stainless bolts that hold the cam arm to the upright arms are weak, inherent to being stainless. I've now broken two of them. One while putting the bike on and then another sheared when I tried to remove it.
    I have since replaced the bolts with grade 5 plated bolts and nylock nuts. If these bolts were to fail on the freeway it would be seriously bad news.
    For clarity the bolts I am talking about:
    Check those bolts!
  87. #1087
    Reputation: ric426's Avatar
    Well, I hope you're happy. You really did it now!
    Thanks to this thread (and the other reviews) I just ordered a silver single bike Quik Rack. I just bought a Ford Focus hatchback, and while I could fit one of my bikes in back, I could tell it was just a matter of time until I messed up the interior. I decided that for my purposes a rear tray rack makes more sense than a roof rack and the 1up racks look like the best choice for me.
    I sure appreciate the good advice I find here and in the other MTBR forums.
    We don't stop playing because we grow old; we grow old because we stop playing.
  88. #1088
    Well I stand corrected. Good to know.
  89. #1089
    Anyone have any maintenance tips for this rack? My cam arms seem to have a little wear on them (kind of a surface grittiness) that I was thinking about smoothing out with some superfine steel wool. What about lubrication?
    Thanks for the tip a few posts above about the bolts (BTW, where did you get the bolts/nylock nuts -- Home Depot?)
  90. #1090
    Is there any concern about the force of the wind blowing perpendicular to the bike and the rack's arms? I just purchased one (like everyone else it is the best rack on the market), however today going about 75mph on the highway the bike looked like it was being pushed over...this of course from the rear view mirror. In my case it is mounted to an impala so there is a lot of bike still above the trunk lid.
  91. #1091
    I thought about this also and want to know what other people have to say. I have carbon frame & fork road bike.
    Quote Originally Posted by jbsmith View Post
  92. #1092
    Quote Originally Posted by Cebu Boy View Post
    For what it is worth I did stop at one point because I thought it was loose...I'm not sure if the bike actually moves or if it's just an illusion from the mirror. Obviously the rack flexes some laterally so the bike shakes as expected...just looks like its getting blown over...I don't think the frame material or type of bike would matter much.
  93. #1093
    Reputation: Alaskagriz's Avatar
    Thought I would chime in about the 1-up. I likemine for sure and I'll second all the positive things people have already mentioned. However, I just have one issue with it and it's interesting to hear that others have had a similar issue: my bolt loosens up all the time. I'll get it tight as it can be and after 30 miles driving to the trailhead it will be loose to the point that I can slide the whole thing out with a little bit of wiggling. I've been using mine for year and I haven't lost a bike yet . Maybe that little bit of friction is all it needs but it does make you nervous if you know what I mean.
  94. #1094
    Tighten the bolt with allen key by hand first then take a rubber mallet and tap it tight a couple more turns.(grease the ball bearing on the rack first) Then to remove tap the allen wrench with rubber mallet to loosen. has never come loose since doing it this way.
  95. #1095
    Quote Originally Posted by Alaskagriz View Post
    Which bolt(s) is the problem child, can somebody take a pic?
  96. #1096
    I think they're referring to the main mounting bolt that forces the ball against the inside of the receiver tube on the hitch.
  97. #1097
    I've also had the retention mechanism (the ball in the hitch bar) loosen up once after thousands of miles without problem. I sent it back to 1up (on their dime, of course) and they said that one of the internal components had worn out. Perhaps yours is experiencing a similar situation?
    I should get mine back Monday and will have a full report. I would suggest that using a mallet to achieve enough torque is never the "best" option.
  98. #1098
    Aug 2010
    Anyone have one of these mounted on a newer Xterra (2005 or later). Just ordered one Friday to replace my 60 pound boat anchor Thule t2.
    Any photos of clearance/fit on an X??
    Thanks,
    Tjm
  99. #1099
    Loser
    Damn all of you. My wallet is begging for mercy.
  100. #1100
    Jun 2010
    I have to agree on this, it is still very unnerving to see the bike getting blown all over at hwy speeds. I have a Subaru Legacy which is similiar in shape which causes the bikes to get pounded by the wind. I have starting using cam straps on as a safety connecting the arms to the wheels. Plus on long hwy trips I try to control the movement with a ratchet strap setup. Nothing really helps since you're essentially dragging the bike broadside through the wind.
    I m buying a 2013 Outback so hopefully it won't be nearly as bad since its a wagon.
Members who have read this thread: 442
