Results 1 to 30 of 30
    1 Up USA Long Term Corrosion?
    I did a search but didn't find anything in particular about how well the 1 Up rack holds up to salt & snow exposure. My T2 is just about toast and the 1 up will likely be my next rack, but does anyone have input on how well it holds up long term to salt & moisture exposure? The Thule looked really bad after just 2 winters.
    One would think that the aluminum would hold up well, but I've seen plenty of oxidized aluminum in my time. Taking the rack off my car in the winter is not an option since my Pugsley would object if I didn't take it out to play
    Another thing I don't know: how long has this rack been in production? Has it been long enough for us to know how it will hold up for 5-6 years of use? Thanks in advance to the input!
    There are three kinds of people: those of us that are good at math and those that are not.
    My rack is at least 5 years old.
    The 1UpUSA rack will corrode to the extent that any aluminum rack will corrode when in contact with salt or other corrosive material. It will fare much better than any steel rack would. I would guess that some of the piece parts might be stainless - which will corrode but should be replaceable.
    All that said, the thing is *super* easy to mount and remove. It literally takes less than 30 seconds to mount the rack to the hitch. I have mounted mine in the time it took for my son to bring me a bike to put on it. For this reason, and because it's easy to do, I'd remove it from the vehicle when I wasn't using it.
    J.
    Quote Originally Posted by onepivot View Post
    I live in the Pacific NW so there isn't much salt but plenty of rain. I also spent a year in Phoenix so its had its share of direct sun. I leave my rack on year-round and have had it for about 4 years now. It's definitely got some exposure-related changes but no corrosion. Everything works like it did from day one.
    I think the rack has been around for over a decade.
    Quote Originally Posted by JohnJ80 View Post
    J.
    True. The videos I've seen sure seem to support what you say. Still, I ride all year & it will still see the salt & snow even if I only leave it on when it's actually being used. It certainly should hold up better than my T2. A friend bought the Kuat NV and after only one winter it is showing signs of rust on most of the fasteners. The 1 Up sure seems to use better materials than the either the Thule or Kuat but I have not seen one in the flesh.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Leaving a rack on all the time is asking for a ticket IMO.
    Why's that?
    Reputation: Naturally Aspirated's Avatar
    I think in some instances, it covers the rear license plate.
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
    On corrosion:
    Well, just the fact that it's made from Aluminum means for corrosion purposes, it has it all over anything steel (Yak, Thule, Kuat etc...). So that should be just fine. You'll probably need to replace some of the hardware pieces eventually, but that should be easy enough.
    On license plate:
    Not for one tray. That generally just covers the bumper.
    Quote Originally Posted by Naturally Aspirated View Post
    Fair enough if that's the situation but that certainly seems more case-by-case than the post I quoted implies.
    Single Speed Junkie
    Reputation: crux's Avatar
    It covers the license plate on our Mazda 3 and Xterra. On the Jeep there was no interference. I do not have an issue with it but when traveling to AZ (Between Flag & PHX) I've had issues being pulled over and ticketed for the rack with bike on blocking the plate. When it is folded up it covers the plate even more. Will still use the rack when needed as we need to get to the trail head somehow. Would be nice to have a plate relocation bracket for those that need it but would most likely cause interference with other areas on some cars.
    Quote Originally Posted by crux View Post
    I have a Honda Fit and Toyota truck and a double rack and the license plate is visible w/ the rack folded. When bikes are on there, it's a little congested but I've never had anyone (even in the podunk town I live) have issues with it. Even living in PHX with the rack on 24/7 I got by without anyone noticing. I never thought of myself as lucky but apparently I am.
    Couldn't you just make your own relocation bracket? The large flat area (with bolt holes, even) that acts as the mating surface between trays seems like the perfect place to put the plate.
    Quote Originally Posted by racerwad View Post
    Why's that?
    Because it's illegal to block your license. Usually they cut you some slack when you got bikes on the rack (and you aren't driving like an a$$), but they are usually less lenient if you just have the rack on the back.
    Reputation: kntr's Avatar
    Can you post a pic of the rack on your FIT?
    Feb 2013
    As others have indicated, it depends on your vehicle. It doesn't block my plate, even when folded...so I leave mine on most of the time.
    Attached Thumbnails Attached Thumbnails 1 Up USA Long Term Corrosion?-img_2054_small.jpg
    Quote Originally Posted by kntr View Post
    I assume you mean folded up? I'll try to take one tomorrow.
    I get where you're coming from but a blanket statement like your original comment probably doesn't work as well as you intended. I drive with my rack on all the time and it isn't asking for a ticket because it doesn't obstruct anything. It seems like that's the experience of a decent percentage of other 1up users as well. That's part of the 1up's beauty - compact, efficient, and (for the purposes of this discussion) virtually corrosion-free
    Quote Originally Posted by mfan View Post
    I think you are assuming just "straight back" is the only angle that matters. What about if its being viewed from an angle from in back? What about if slightly elevated or negative elevation? If it would have been visible from any given angle without the rack, pretty sure in every state that constitutes "blocking the plate".
    Wink
    Yeah, or if the cop is lying on the ground just behind the car, the rack could block the plate then...
    whatever...
    folded and with bikes
    Here is one folded. I'm standing at the end of a parking spot.
    You'll have to imagine what it looks like with bikes. Basically the same, but with bikes.
    Attachment 791137
    Attached Thumbnails Attached Thumbnails 1 Up USA Long Term Corrosion?-photo.jpg
    blocking a license plate?
    ballbuster
    Reputation: pimpbot's Avatar
    How much fear do you live in? Are the cops in your area pretty much bored nazis or something? I think you're picking some really tiny nits, here. And yeah... pretty much straight back, or slightly off to the side would be the only angles that matter.
    Quote Originally Posted by pimpbot View Post
    Thank goodness I'm not the only one thinking like this. Based on Jayem's logic, you'd need plates on the sides of your car because there's certainly nothing visible there. Positive or negative elevation?
    Between this and the people cutting themselves while using the rack, it's made me worry about our future.
    there are cars that have their license plate mounting in the bumper... so I can see it blocking the plate in that instance. I have no worries, my plate is hatch mounted
    Even with my plate being mounted on the rear bumper, there is still clear line of sight. It MIGHT be blocked if I fold it up, but I never do that. The rack either has a bike on it, or it's folded up and stored in my trunk.
    YETI SB-66 CARBON
    SCOTT GAMBLER 720
    So how are the 1Up racks doing long term corrosion wise?
    Man, talk about a thread hijack! At least my original question was answered. I think
    Quote Originally Posted by ALS650L View Post
    Have you not read the thread? We got it answered before the derailment lol.
    Reputation: woodyak's Avatar
    Gone through 2 New England winters with my 1Up. I ride year round and the rack pretty much lives on the car year round. I live along the coast and we get plenty of salt on the roads during the snowstorms. Yes, after 2 seasons there are some bits that you can tell are not AL or Stainless Steel. A couple of the bolts/nuts are showing some corrosion as well. A quick e-mail w/pic to 1Up resulted in fresh replacement parts sent to me w/o question. Compare this to my Thule Sidewinder bike tray which had all the bolts fully corroded to my rack after 1 season as well as the plastic parts worn enough to give it a bunch of play. An e-mail and a call to Thule resulted in no customer service at all.
    My buddy has one of the original 1Up racks that's like 10 years old and it looks perfectly new. But he lives in the city and removes it when not using it.
    Thanks, woodyak. That's what I needed to hear. We get a lot of salted roads here in Illinois but probably not as much as what you folks live with.
  1. Long Term Storage
    By plyward in forum 29er Bikes
    Last Post: 04-10-2013, 06:59 PM
  2. long term bar build
    By Irongrave in forum Beer Forum
    Last Post: 03-14-2013, 05:30 PM
  3. Long Term Use At Low PSI?
    By jonshonda in forum Fat bikes
    Last Post: 02-11-2013, 11:22 AM
  4. Replies: 8
    Last Post: 10-15-2012, 04:35 AM
  5. Which is the better long-term frame?
    By norwish in forum Bike and Frame discussion
    Last Post: 04-01-2011, 06:52 PM
