Where'd you find that handlebar/stem that you have connected to the seatpost? I was thinking about putting something like that on my bike so passengers have a place to hold onto.
It's an oversize (31.8mm) adjustable 1-1/8" stem, mated to a cut down carbon fiber bar w/ a 28.6->25.4 stem shim. The kids like it.
The stem is a Ritchey model in 120mm length (I think), but there are other brands with the same setup. The adjustable angle allows me to set it at zero degrees to make the setup straight.
I love the truck bed! how exactly is it attached to the frame? Is there an insert to prevent things from falling out the back or do you just bungee stuff down?
MabMan, that is an awesome looking bike-truck that you have there. Is it homemade? The bed looks really functional, although I would be tempted to design and build a tailgate for it.
heres mine, i got sick of pulling around my bob so i built this.
its all straight up 4130, i still need to build a center stand and i need to set up panniers and mount, you'd think there would be more then enough room up top but the bars hit if loaded to high.
it will get a coat of paint sometime this spring.
Yes, garage made. It is codenamed the "Bicycle Utility Motorised Vehicle"
The bed was a concept that while it works, it doesn't work as well as being able to carry the heaviest part of the load at or below axle level stability wise, but it will still haul a pretty good freight. I dragged a 20' 16" culvert up a pretty steep dirt road with the bike awhile back that totally freaked out my buddy who said it could never be done. A few bungies and a stretch cargo net has negated the need for a tail gate of any kind. The best thing about this bike perhaps is that it uses alot of recycled parts and pieces and cost less than a Big Dummy frame to achieve. :thumbsup:
powderhound82,
How'd make your own studed tires? It crossed my mind this year but we haven't really had too much icy weather here in Portland. I just can't bear to part with $100+ for tires I'll only use 10 days a year.
powderhound82,
I had some old Nevegals laying around, I'm sure most tires would work. Drill a small pilot hole through the knob from the outside, then drive a small (depends on thickness of tire)sheet metal screw into the pilot hole from inside. I put a few layers of duct tape and an old dh tube as a liner, no problems so far. I'd recommend gloves for installing the tire on the wheel, these suckas will cut ya!
As you can tell from the pic, I am snowbound. The roads and bike path around here are usually hardpack snow with big sections of ice. These tires are on their second season and have worked like a charm. No trail riding as the snow is too deep, that's what the ski are for.
Here's my Giant Yukon with racks and bags. I had it all loaded up with a full campsite and 2 days of food to test it out. I pretty much use it for grocery runs and trailer pulling.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
