Results 1 to 17 of 17
    My Version of Xtracycle's Running Boards
    I like the idea of Xtracycle's new running boards but at 150 bones and a backorder of months, I decided to take matters into my own hands. I had the day off and decided to make up a set of my own. I'll call 'em Po' Boards.
    I was rummaging around the garage and found a bike stand we used to use to park our bikes out back. It's this one: Allen Racks - 204lw 4 Bicycle Folding Parking / Storage Allen Bike Rack
    It has the button locks necessary to lock into place on the Big Dummy frame and lo-and-behold, it's the required outside diameter (22mm) to fit into the front part of the rack. Problem was, I only had the two bike version so had to find something for the rear part of the rack. An old shower curtain rod was in the corner and it too was 22mm OD. My lucky day.
    I had some scrap pieces of laminate 1" pine in the garage and used that for the boards. Some Thompson's Water Seal I had sitting around to coat and protect against the elements and I was almost done.
    The only thing I didn't have were four screws to finish the job. A quick run to the hardware store (on the Big Dummy of course) and $.73 later I was in business.
    This project was fueled by Highland Hollow Spoon Tongue and Alaska Brewing Co. Black IPA.
    Attached Thumbnails Attached Thumbnails My Version of Xtracycle's Running Boards-cimg0709.jpg
    The running boards look so nice you're going to have to change out the cheap plywood deck up top.
    Reputation: slimhazy's Avatar
    Quote Originally Posted by bme107 View Post
    Oh, snap!
    Is your rear tube continuous through the frame? Can you remove the running boards without unbolting?
    I've always wondered why V-Racks and V-Racks aren't anchored with the push-button fasteners. They're available here for any/all DIY projects:
    McMaster-Carr - Quick-Release Button Connectors for Telescoping Tubing
    You want one of the the 1/4" diameter, single leg styles. Unless you're drilling straight through, then go with double buttons.
    Or find a Razor scooter handlebar...
    Rhymes with fartmaster
    Quote Originally Posted by Bong_Crosby View Post
    Nice beer-powered ingenuity!!!
    Reputation: Lone Desert Walker's Avatar
    Those boards look nice. Good use of resources.
    Cars Are Evil
    Reputation: Vermont29er's Avatar
    Nice job!
    US Army Vet-Airborne 11B
    Reputation: longhaultrucker's Avatar
    VERY nicely done!
    '11 Origin 8 700CX
    '14 Surly Troll
    Quote Originally Posted by slimhazy View Post
    Oh, snap!
    Yeah, the back tube is continuous. I'll only have to unscrew one side and that will take all of sixty seconds. But to be honest, I always rode with my wideloaders on and will do the same with these. Also, the shower curtain rods are pretty flimsy and probably not a long term solution so I'll be on the lookout for something to replace them.
    Razor scooter you say? I'll have to look into it to see if it's the right size OD.
    No way! I love this deck. It was another day of beer fueled inspiration. All these parts came from the garage too. They want $12 for four SnapHooks and $25 for for the SuperHooks, plus shipping...for a handful of plastic and aluminum? Not from this dude No Snaphooks or Superhooks were used, just a piece of 1" pine, notched on each end to fit into the V-rack. Problem solved.
    And the milk crate on top is the coup de grāce. Like Bushwalla sings, "It's hard to be a gangsta with a basket on your bike..."
    Down South Yooper
    Reputation: Plum's Avatar
    Sep 2004
    I've got a spare snap deck in my garage, with snap hooks... Just sayin.
    Nice woodwork on the running boards. If you can find a straight bar, it should fit in the xtracycle frame, same 22mm diameter. Some Bmx seat posts too, and those are kid proof (and heavy as hell).
    Plum
    This post is in 3B, three beers and it looks good eh!
    Are you going to trim those bolts off? No use in hauling extra steel bro.
    Quote Originally Posted by Plum View Post
    Plum
    Alright, alright...I'll put some snap hooks on. Sheessh... Actually, I have a couple spare snap decks in the garage too. I'll pull 'em off and swap 'em out with the wood.
    I found one in a dumpster one night coming home from the bar. Rode it a few blocks, then pushed the buttons to unlock the handlebars and snapped the bungee cord holding them together. Tossed the foam grips and everything else in a trashcan.
    Shoulda kept the wheels to use as tailwheels, but the bars are the perfect length and OD to use as QR footpegs.
    Rather than the bolts you're using for the running boards, I'd suggest using T-Nuts on the top side and putting the bolts in from below.
    Oct 2012
    I used carriage-bolts on mine... smoother than the ones here, but easier to find than the T-nuts. Anything works, though.
    Oct 2013
    My similar home made running board solution. Plastic prethreaded pipe usually used for lawn sprinkers through the holes in the bike frame, wood fence planks. Hose clamps on plastic pipe control any lateral movement.
    Sun Wide Loaders Slideshow by mbrickell | Photobucket
    May 2010
    Guys, I planned to start production of xtracycle accessories... but Xtracycle stop exporting to Europe. So I have some items left.
    Rear Decks (without hooks, without graphics) - 20 EUR
    Side Boards (no bolts, 22m alu tubes black, no graphics, raw) - 40 EUR
    Side Boards (no bolts, 22m alu tubes black, no graphics, coated) - 50 EUR
    Pics are here: Home
    Contact me if interested ...
