Results 1 to 6 of 6
    Reputation: Bacons's Avatar
    Looking for a stoker stem for 31.8 bars...Big Dummy
    Hey guys... what stoker stem do you use for your Big Dummy? I'd like to get one that will fit the standard 27.2 seatpost but allow for 31.8 clamp bars.
    Thanks for the feedback.
    I use a standard Salsa stem with a seat post shim. I had to cut the shim down but it works.
    I used the stock 120 mm stem from my CX bike with a shim. It's a 6 degree. I'd prefer something with a little more angle/rise but it works.
    If I were buying one I might consider one of these: ~$30, 17 degree, 130 mm
    Amazon.com : Control Tech One 17-Degree Road/Mountain Bike Stem : Bike Stems And Parts : Sports & Outdoors
    But...I doubt you could beat this deal: $7, 8 degree, 130 mm
    Race Face 2012 Cadence Road Stem at BikeTiresDirect
    Unsolicited advice. I highly recommend an inverted road bar as a stoker bar. You don't need a super long stem to make it work. More options for your passenger and gets their hands out from under your butt. Got the idea here:
    The Surly Big Dummy Review. | riding against the grain
    Thanks for the advice guys. I have about 6 stems laying around, one of which is a Salsa Pro Moto 120mm. It was intended for 1 1/8" steerer tube. I'd love to use it on the 27.2 seatpost. What do you guys use for a shim?
    RE: Bars, I've got a few of them laying around as well. I am thinking of adding my Bullhorn bar (Tree Fort Bikes - Online Bicycle Parts and Accessories, Bicycle Tools and Maintenance) and taking sdwhitey's advice and invert them.
    shim for stoker bar stem
    Quote Originally Posted by Bacons View Post
    I used one of these:
    Universal Cycles -- Problem Solvers Seatpost Shims
    size should be 27.2 - 28.6
    double check my math but 28.6mm should equal 1 1/8 inches
    The shim was longer than the stack height of my stem so I cut the shim down so that it's sharp edges would not be exposed.
    I think the inverted bullhorns are a great idea.
    Here is what it looks like. Silver sliver above the stem is the top edge of the shim.
    Looking for a stoker stem for 31.8 bars...Big Dummy-14762502923_227fcd09e5_o.jpg
    Thanks again. Great advice.
  1. Need new bars and stem on '07 Flux
    By yehudanachum in forum Turner
    Last Post: 03-20-2014, 11:21 AM
  2. Alt bars - help with stem
    By architectx in forum Singlespeed
    Last Post: 11-16-2011, 04:25 AM
  3. AM bars and stem
    By The Grimmer in forum All Mountain
    Last Post: 07-28-2011, 02:24 PM
  4. what bars and stem?
    By david8613 in forum Downhill - Freeride
    Last Post: 05-21-2011, 04:58 PM
  5. Upgraded bars/stem...not 100% sure??
    By oceanminded in forum All Mountain
    Last Post: 04-22-2011, 07:37 AM
