    Feb 2010
    I change my mind.
    I will keep it as is for the best part anyway.Thanks for the help you save me a few dollars.
    Don't do it. The weight balance on a long bike is totally different than a standard wheelbase bike. A SID is a racing fork at that and would be a noodle on the Big Dummy. You have much more of your weight shifted forward on the front wheel of a BD. Stay with the stock rigid fork.
    Beastrider
    Reputation: BeastRider's Avatar
    Oct 2011
    Quote Originally Posted by kdc1956 View Post
    I,m looking at the Rockshox SID RLT 100mm,11 fork for my Big Dummy.This is what all it has to offer.
    With available remote lockout capabilities, this SID is just waiting to be taken to a race. Dont worry, youre also backed-up by the Power Bulge and the light combination of a hollow crown and legs. If needed, you can even reduce the travel to 80mm to give you that extra edge racers need.
    Motion Control damper features externally adjustable rebound, low speed compression and Floodgate threshold
    Travel is adjustable to 80mm by installing the included All-Travel spacer
    X0 lower leg color-match decal set included
    32mm 7000 series aluminum upper tubes, optimized upper tube length and hollow lower magnesium legs
    Hollow Forged AL-6061-T6 Crown
    Hollow Magnesium lower legs
    Power Bulge reinforces the lower bushing for increased stiffness and durability
    All control knobs are machined aluminum and feature detents
    External rebound adjustment
    Standard post-mount disc brake mounts accept 6degree rotors without adapters. Larger rotors accepted with correct adapters
    Shock pump included
    Intended application: XC Race and Trail
    Spring: Air
    Brake Type: Disc
    Front Axle Type: 9x1
    Front Hub Spacing: 100 mm
    Wheel Size: 26"
    Wheel Mount Center Offset: 0 mm
    Steerer Tube: 1-1/8" Threadless
    Steerer Tube Length: 265.0 mm
    Crown Race: 30.0
    Would this be a good upgrade or would I be better off with my stock fork.Thanks for any help on this.
    WHY do you want to put Racing Shocks on a Cargo Bike?
    wants a taco
    Reputation: nubcake's Avatar
    Nov 2007
    Quote Originally Posted by BeastRider View Post
    x2, if you must have suspension go with something meant for heavier duty riding and not as expensive. You do not need very sofisticated dampening on a bike meant to haul cargo. Look at heavy duty pick up trucks, they could make them more comfortable and smoother with a change to their suspension, they just know it is more important to have something tough and reliable.
    A tora is much cheaper and would serve you better in my mind
    Just another cycling blog...
    The Long Way Home
  1. RockShox Judy J1 (100mm Not)
    By mtbvfr in forum Shocks and Suspension
    Last Post: 06-29-2009, 01:31 PM
  2. RockShox Judy J1 (100mm Not)
    By mtbvfr in forum SRAM
    Last Post: 03-31-2009, 09:01 AM
  3. Help me Decide; FOX vs Rockshox 100mm
    By DMehalko(DM) in forum Shocks and Suspension
    Last Post: 03-01-2009, 12:14 PM
  4. RockShox Tora 100mm for DJ/Urban?
    By ZenkiS14 in forum Urban/DJ/Park
    Last Post: 12-25-2008, 07:21 AM
  5. Rockshox Reba SL 100mm can't get 100mm of compression
    By Z3RatuL in forum Shocks and Suspension
    Last Post: 07-14-2008, 03:16 AM
