Results 1 to 7 of 7
    Reputation: backcountryeti's Avatar
    Fender question...
    I recently bought a set of fenders off of the local craigslist, and due to my front fork being suspension corrected, I cannot get the fender to mount the fork, too much space to make up. Is there a part you can buy to drop down the fender from the crown of the fork, or is this a DIY job?
    DIY would be quicker and cheaper. You need piece of aluminum to drill some holes in, or premade bracket straightened with a hammer (IMO)
    I used the pretty common place Planet Bike Cascadia 29er fenders on my BD, I had some brackets left over from one of my OMM sherpas that i didn't need. .So I cut one of those brackets down, and used it to extend the front fender fork crown mount down to get the fender much closer to the tire. Worked out pretty well. pretty much any piece of aluminum
    flat stock would work.
    Down South Yooper
    Reputation: Plum's Avatar
    Sep 2004
    I'm just running my fender tight to the fork crown. There's extra room, but not much makes it past the fender. More solid mounting as well.
    Running planet bike cascadia 29ers as well.
    Plum
    This post is in 3B, three beers and it looks good eh!
    I'm using the Planet Bike Cascadia IIs (not the 29er version, just the normal 26" one from mec). The hardware that came with them mounted them fine, although like you a little high off the tire, but not more than 1", probably less. My tires are Schwalbe Super Moto 2.35" and so far the fenders have done their job just fine!
    Unless you have substantially thinner tires than I, you may be fine to just mount them.
    Thanks for the responses all. Went the DIY route, to only not like the way it turned out, and switched back to knobbies for the fall/winter months. Switching things up never gets old!
    Mar 2005
    I bought a Nashbar front rack and mounted the fender to the rack.
    There are two screw holes on top of the rack to mount the bracket to that attaches to the fork crown. I drilled through the fender (Planet Bike ATB full coverage fenders) at those two holes and bolted the fender and the bracket to the rack. It worked perfectly.
  1. 1x1 and fender question
    By briscoelab in forum Surly
    Last Post: 01-06-2009, 07:10 PM
  2. Replies: 0
    Last Post: 03-10-2008, 12:13 AM
  3. Replies: 0
    Last Post: 03-09-2008, 11:53 PM
  4. '08 Marz. 66 fender question.
    By kitsapfreerider in forum Downhill - Freeride
    Last Post: 01-16-2008, 02:08 PM
  5. fender question
    By kenaran in forum General Discussion
    Last Post: 08-26-2004, 07:31 PM
