I still need to build/attach the rear cargo rack (among other things) but I couldn't resist taking it out for some test rides first. Not as long as a Big Dummy or Mundo, but it'll still have a good sized rear cargo rack.
I plan to use some of the Yuba accessories on the rear cargo rack.
Put 40 miles on the new bike yesterday... some pavement, but a lot of dirt and sand. I think I'll eventually end up with front and rear 29+ wheels on it (Rabbit Hole/Knard combo) to get more chain/tire clearance. In order to run the full fat in back I lose access to a couple cassette cogs.
Keep it up. This is a wonderful design and artful execution. I like the slightly extended wheelbase and slightly fat tires. You have hit upon a winning design that will probably be duplicated by others. I'd like to see one based on the 26+ tires.
I don't know what trail we're on, but at least it's getting dark
Thanks. The design is inspired by a Hunter Cycles bike that was built last year. I've wanted a fat cargo bike ever since I saw the first photos of the Chupacabra built by Traffic Cycle Design.
I have a Big Dummy that has hauled all manner of groceries and misc. stuff plus elk and deer and chainsaws for trail work. What you created would work much better and faster than a fat bike (which I have) or a Dummy because of lighter weight and quicker utility. 90% of the time your design would be just right. This rest of the time a specialty bike would be better.
Now to look up that Hunter bike for comparison!
I suppose what you have is a cross between the High Plains Drifter and the Super Scrambler. Rick Hunter is really skilled, quite an artist. but I like your basic design better.
Not that it's what you're working with, but my 26x3" gazzaloddis fit in the Ute.
Personally, if Surly ever comes out with that 26x3" knard- I'd throw that in back.
I got REALLY burnt out trying to huff those gazzis back and forth, and when loaded- it's just harsh.
There's also Vee Rubber's 24x4" mission that On One is using on their baby fatty.
If steel is real then aluminium is supercallafragiliniun!
