• 12-16-2012
    GuruAtma
    Changing a tire on the road
    My Yuba Mundo has a 15 mm nut on the front wheel and a 19mm nut on the back wheel.
    The way the frame/derailleur crowds the nut on the back prevents me from using an adjustable wrench--I need either a box wrench or a socket wrench.
    I'd like to minimize the hardware I carry with me on the bike.
    Is there such a thing as a box wrench that is 15mm on one end and 19mm on the other I haven't been able to find one.
    Any suggestions?
  • 12-16-2012
    Mr.Magura
    The easy solution would be to weld one of two wrenches.
    I would probably make a 19mm set of nuts for the front, but that requires some sort of machine shop access.
    Magura :)
  • 12-16-2012
    Leopold Porkstacker
    Im not familiar with the Yuba Mundo (I own a Surly Big Dummy)is it possible to just use quick-release skewers or maybe use those hex-head axle nuts instead?
  • 01-12-2013
    bikeolounger
    The Yuba uses a 14mm rear axle (I think--don't have one of my own), and it is solid. I don't know of a quick-release axle that will be compatible, although I suppose one could find a machine shop and get one drilled and cut to proper length. 14mm is or was a popular axle diameter for trick bikes.
    Ratchet head and a couple of sockets seems a good solution, or, as has already been suggested, take a wrench of each size and cut/weld.
