Results 1 to 2 of 2
    Big Dummy shifting issue
    Sooo, I have a Big Dummy, 2012. It was a custom build- the crank is an SLX triple, and the rest is SRAM X-9 bits, with gripshift. Long cage derailleur.
    From the get-go, I haven't been able to use 8th and 9th gears, it would shift into them but skip and bounce around. This is on the middle and big ring, unsure of the small ring cuz I don't use those gears in the small ring.
    My LBS, which is a fantastic shop, tried adjusting the limit, they took the screw out all the way and still couldn't get it to stay in 9th gear. No signs of anything being bent. They said the chainline appears to be fine.
    Anyone have any insight? I probably should have posted this in the drivetrain forum but I figured it might be longtail specific.
    Reputation: gmats's Avatar
    Apr 2005
    Without the cable, is it possible to get the derailleur to shift to the last gear? If so, then there's probably resistance or drag in the cable or shifter not allowing the cable movement? In "old" gripshift set ups, I know there used to be a need for and upgraded spring in the derailleur with more tension.
    Is there anything impeding the movement of the derailleur or cable? On my Trek I noticed that the pannier could sometime impede the movement of the derailleur.
    Good luck with that.
  1. Chainring shifting issue
    By Roc1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-09-2013, 03:21 AM
  2. shifting issue
    By mrosey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-05-2013, 11:39 AM
  3. Sram shifting issue
    By WizzBang in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2013, 02:35 PM
  4. Firebird New Shifting Issue
    By Hangtime in forum Pivot Cycles
    Last Post: 01-31-2012, 12:08 AM
  5. Gear shifting issue?
    By EZuphill in forum All Mountain
    Last Post: 12-13-2011, 06:55 PM
