Over the weekend while I was out shopping I came out of one of the stores and tried to put the bike on the center stand. I noticed that it seemed to wobble a bit so I thought I was on an uneven surface. When I moved the bike to locate a bit of a level surface a small part fell from under the bike. It was a part that goes to the center stand. Causing it to shift quite a bit and not hold the bike like it's supposed to. I picked up the piece, took it home, and checked things out. I have not, as yet, completely removed the stand as I am awaiting a replacement from my LBS and TREK. TREK said that this is covered under the warranty and replacement isn't going to be a problem. But I wanted to let the other owners out there know about this so that they might be able to check it and get it fixed/replaced BEFORE it completely breaks.
TREK and my LBS have been a HUGE help in getting this issue taken care of!!!!!
Here are photos of it......
The part that broke off....
Different angles of the center stand where you can see where the part broke off from....
