FAT BIKES
WINTER APPAREL
TRAINERS
Page 109 of 112 FirstFirst ... 9 59 99 105 106 107 108 109 110 111 112 LastLast
Results 2,701 to 2,725 of 2781
  1. #2701
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    Just read a write up on the XV and it sounds okay for the base of $21k and up - as tested, 26k. Good mpg numbers if they hold out to be real.
    I'd consider it if in the market but hoping my Mazda and Infiniti get me way more down the road for a long time. The XV is the better looking Suber model IMO although the few years ago Foresters looked pretty nice, maybe 07's.
    In the Middle Ages, the biggest mistake was not putting on your armor because you were 'just going down to the corner.'
  2. #2702
    Re: Who else here drives a Subaru?
    Seriously? Do you realize how ridiculous this is?
    No not really.. Lol I've had the car a while, took about an hour all together not too bad
    Sent from my 831C using Tapatalk
  3. #2703
    Nov 2008
    Quote Originally Posted by Superorb View Post
    You didn't want to chance it with a Subaru so you went with an Audi? Thanks for the laugh, LOL.
    Haha that's my exact sentiment. Lololol
  4. #2704
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    right?
    Subaru alternator is 3 bolts and is on the top.
    The timing belts are incredibly easy as well. Pull 2 bolts, 2 wiring harnesses and 2 hoses to remove radiator (you can pull the fans instead but the rad assembly is quicker) and you've got plenty of room to do what you need to do.
  5. #2705
    To do mine I just have remove the bumper.. 2 bolts, the rad support, 4 Screws, the serp belt, and some plastic. Not exactly hard for anyone competent with a ratchet.
  6. #2706
    Quote Originally Posted by ou2mame View Post
    The front end is only a few bolts actually and you don't have to drain the coolant. I've done it to change my thermostat takes about 20 minutes. My alternator was easier to access with the front wheel off through the wheel well. Was only the one bolt I think. It's not bad if you know the car.
    That's not even possible to remove the front end without draining the coolant. The hoses run into the engine block to cool it.
    Alternator takes one bolt?? That's not true either, most take 2-bolts. 1 bolt wouldn't be very reliable for keeping tension with such a tight belt on the pulley.
    I worked on my friends Audi A4 2.0T and several jettas. I've had plenty of "WTF, who designed this POS" moments with those cars. The germans definitely never heard of the "K.I.S.S" philosophy. Subaru's are definitely easier to work on. With my friends other cars, any part stamped with "made in germany" carried a high price tag.
    The reason why subaru parts are so cheap is because they've been using the same engine for 20+ years, and the basic layout has changed little since the 90's.
  7. #2707
    Ok maybe 2 bolts it was 4 years ago. And yes, you can remove the front end it swings out. The upper hose may leak a little but pointed up you don't have to remove the coolant just run it with the cap off the reservoir for a few minutes to get the air out. I just did this to change some oil lines a few months ago.
  8. #2708
    MTB Newbie
    If you get an Audi that works you're golden. But plenty of them have electrical gremlins. I constantly see German cars in general with wonky tail lights that don't work, or that only work when you hit the brake and the reverse lights come on, or something else. I've had a few friends with turbo Audis and VWs and all of them spend their time working on the cars cursing because they were designed without any sort of common sense. Subarus are orders of magnitude easier to work on compared to an Audi. And if you need a part you'd better take out that 2nd mortgage on the house. They're also ridiculously expensive for what you get. A 25k WRX can run circles around a 40k Audi, and a 25k WRX with $15k in mods can run circles around just about any stock production car out there.
  9. #2709
    Reputation: eurospek's Avatar
    Time to start looking for a replacement.
    konahonzo
  10. #2710
    Quote Originally Posted by eurospek View Post
    Good luck finding another Saabaru.
  11. #2711
    Apr 2013
    Quote Originally Posted by bradkay View Post
    Here is my trusty '91 Loyale on a trip to the Sierra a couple of years ago. The old girl still gives me 30+mpg on trips, even after 320,000 miles.
    Well, the Loyale is being retired to local trips. My mechanic just rebuilt the engine on a '97 Outback with 227k on it and sold it to me for $3500 (he also rebuilt the clutch). I'll post pics within a few weeks.
    I'll be driving it to Mendocino and Jackson Forest in about ten days.
  12. #2712
    Not bad, when it's time for my impreza to get a new engine, i'm just going to pull it out and buy a fully rebuilt short block, slap the heads on and keep on truckin.
  13. #2713
    Apr 2013
    That's a good option for the Impreza. I wanted to rebuild the engine on the Loyale but was talked out of it. Eddie (my mechanic and local Subie wizard) tells me that every one of the old 1.8l engines (in GLs and Loyales) he has opened up in recent years has had a cracked head. It's okay to replace the head gasket and use locally, but it isn't something I want to trust on long trips. Thus the Outback...
  14. #2714
    Apr 2013
    Who else here drives a Subaru?-dscn2103.jpgHere's the Outback I am now using for my bike hauling and camping out.
  15. #2715
    Scalpel Fan
    My Subaru has a Scion badge.
    Sent from Tandy 400
  16. #2716
    Quote Originally Posted by Quentin View Post
    Sent from Tandy 400
    Any mods? These can scream from what I've heard.
  17. #2717
    Scalpel Fan
    Quote Originally Posted by SS Hack View Post
    TRD exhaust, sways, air filter. Also a set of light weight wheels with sticky rubber. It isn't a super fast car in a straight line, but the handling is simply brilliant and the chassis/steering is one of the best you can buy for under $40k.
    Sent from Tandy 400
  18. #2718
    I really like the look of the brz, but rwd in long Island wouldn't be possible.
  19. #2719
    Wahoo!
    Sep 2004
    I'm a new Subaru owner. I came from an 05' Colorado that made 15.63 mpg to a 2010 Forester at 24mpg. It's quick, agile, has a killer turning radius, and can lock my bike inside if need be. I can't wait to play around in the snow.Who else here drives a Subaru?-20141110_171325.jpg
    I will not tiptoe through life to arrive safely at death.
  20. #2720
    Reputation: otis24's Avatar
    That's why you have a daily driver and that BRZ for when it's nice out.
    I like to ride bikes.
  21. #2721
    Scalpel Fan
    Quote Originally Posted by otis24 View Post
    I'll attempt to daily the FR-S. We have an AWD Rav4 for the family hauler/winter car if I can't get out of the driveway. My wife's MINI does surprisingly good in the snow, too.
    Sent from Tandy 400
  22. #2722
    Sent from Tandy 400
    Front wheel drive just like the Rav4 works pretty well most of the time.
  23. #2723
    Scalpel Fan
    I assume that is some dig at the Rav being FWD biased. It has a transfer lock button to split the torque 50:50 front:rear that definitely gives it a leg up over most other FWD biased systems. Most of the newer systems are a little more aggressive in sending power to the back these days, too. I've owned 2 Imprezas, a 4Runner, and now the Rav as winter vehicles. All are capable of you drive cautious and keep good rubber on them.
    Sent from Tandy 400
  24. #2724
    I <3 dirt
    Oct 2010
    Rwd plus dedicated snow/winter tires works just fine for winter. Don't be that person
  25. #2725
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Seriously? I drive a camaro in Alaska. Sure, some days it doesn't really work, but I do drive it in the winter sometimes too, and the people that say "tires don't work below __ degrees" are full of ****. They may not be quite as grippy, but if you aren't a hack it's just fine. Having a clutch to feather helps a lot too in such conditions.
    Long Island? Not sure if serious...
Follow MTBR on Facebook
