Results 1 to 8 of 8
    Stray Bullet
    Reputation: Nagaredama's Avatar
    Thule T2: 1.25" to 2" conversion?
    I have a Thule T2 that fits a 1.25" hitch, sold that car and now have a car with a 2" hitch. Thule won't sell me the lower shank to convert my 1.25" rack to 2", which seems really lame.
    I've been thinking of buying a piece of 2" square aluminum tubing, drilling a few holes and bolting it on to my existing rack.
    Any recommendations on the tubing? Looking at 2" x 2" with a wall thickness of 1/8".
    Anyone else do the same? Thoughts?
    Reputation: Rock's Avatar
    They sell adapters.
    2" To 1-1/4" Hitch Receiver Adapter: Amazon.com: Automotive
    I had one for my set up. Daily driver was 1 1/4" wife's car had 2". No problems.
    How can anyone who's been riding as long as I have, be so slow???
    Reputation: bigkat273's Avatar
    Re: Thule T2: 1.25" to 2" conversion?
    Just get the adapter but only catch is don't know if you are able to add on the additional 2 trays that the 2" version of the t2 allows for if you were so inclined in the future.
    Here is the thing about equality, everyone's equal when they're dead. - Gavroche, Les Misérables
    Stray Bullet
    How well did the adapter work? Any additional sway in the rack?
    I'll probably give that a go first.
    The one I bought came with a spring loaded bolt lock thing, instead of just a pin that tightened the adapter down very well. The whole setup had the same amount of slop as the 1.25 into 1.25 receiver. I see on Amazon they also have a aluminum one that looks pretty slick for not a whole lot of $$$$.
    Cut Casing Whisperer
    Reputation: Mr.P's Avatar
    Feb 2005
    This aluminum adapter bolts to the rack for no sway and does not extend the rack out any further like other adapters can.
    Amazon.com: 2" Class III/IV to 1-1/4" Class I/IV Hitch Adapter Insert Sleeve: Rage Powersports: Automotive
    P
    Stray Bullet
    Mr. P thanks, that is just what I'm after. I bought the adapter Rock suggested and am not impressed. Doesn't fit well which results in a lot of play. I'll try yours. Otherwise I'll be buying 2" box section of aluminum and make my own 2" shank.
    Good luck with the adapters. All of them are a compromise. Anything you buy or make will have "some" slop in it. There will always be a need for clearances in order to insert racks into receivers. Adding an adapter just adds one more level of movement.
  1. Light "click" or "snap" or "clunk" when pressing down hard on pedals
    By VFXterra in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 07:37 AM
  2. Replies: 2
    Last Post: 07-14-2013, 05:24 PM
  3. EASTON EA70XC 29" and EA90XC 29" conversion kit?
    By eldeviko in forum Wheels and Tires
    Last Post: 08-15-2012, 01:02 AM
  4. Stans No tube conversion kit "discount price!!"
    By henmar77 in forum Wheels and Tires
    Last Post: 07-30-2012, 10:43 AM
  5. Thule T2: Swapping 1.25" for 2"
    By bremmick in forum Car & Biker
    Last Post: 05-02-2012, 03:43 PM
