Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 101 to 125 of 130
  1. #101
    on my benz.
    SeaSucker Bike Rack Owners... POST YOUR PICS!-17eff022369311e3a2fe22000a1f8ce3_8.jpg
    on my wifes vw.
    SeaSucker Bike Rack Owners... POST YOUR PICS!-152ea23038d111e386b922000a9f14cd_8.jpg
  2. #102
    PROEDGEBIKER.COM
    Reputation: ProEdgeBiker's Avatar
    Pretty Sick Sneak Preview:
  3. #103
    Apr 2013
    Not many rack options for a Park Avenue - love my SeaSucker!
  4. #104
    Jul 2014
    So know one has had glass break or dents using this mounting system? Looking for my 14 Mustang.
  5. #105
    I'd rather be on my bike
    Reputation: TenSpeed's Avatar
    Feb 2012
    Get it.
    No dents. No broken glass. You can't even tell that I had used it.
    The pedals turn, not just the left one, but the right one too.
    2015 miles: 5019/5000
    2016 miles: 1453/6000
  6. #106
    Reputation: XC Mike's Avatar
    Sep 2004
    Wow looks easy!!
    would this work for a Tandem with a 15mm??
    I'm driving a Scion XB and using a hitch rack for the Tandem and putting my daughters mtb inside
  7. #107
    PROEDGEBIKER.COM
    Quote Originally Posted by XC Mike View Post
    Wow looks easy!!
    Yes, you just need the 15mm mount for it or an adapter.
  8. #108
    135 or 150 spaced for fatbikes yet? I'm probably going to get a car soon that can't take any regular roof racks.
  9. #109
    Is the Hornet strong enough to hold a fatbike? I need to be able to transport two with a BRZ. I don't have the car yet but want to have one really soon. A hitch can be installed but I'd rather not lose what little ground clearance the car has and from all the pics I've seen it appears to sit below the lowest point of the car which usually means scraping it on driveways.
  10. #110
    Mine was pre-owned. Love it!
    Attached Thumbnails Attached Thumbnails SeaSucker Bike Rack Owners... POST YOUR PICS!-img_1155.jpg
  11. #111
    PROEDGEBIKER.COM
    Quote Originally Posted by gravitylover View Post
    Yes it is. Each 4.5" cup is rated for 110 pounds and you have 2
  12. #112
    PROEDGEBIKER.COM
    Quote Originally Posted by kss29rider View Post
    Please make sure you purchase new pumps for the SeaSucker's with white cups.
  13. #113
    Reputation: cman8's Avatar
    +1. The white cups have pumps that have now been revised. Seasucker has been great and replaced mine that had failed to no fault of user.
  14. #114
    PROEDGEBIKER.COM
    Quote Originally Posted by cman8 View Post
    Unfortunately they wont do the same for a rack that was purchased used or from an unauthorized dealer
  15. #115
    Nov 2013
    Has anyone used this as a 'skisucker'? I built up one which looks remarkably like https://www.seasucker.com/shop/ski-rack/ except I put 1" risers between the rack and the suckers so that the binding fits easily.
    My worry is what happens in the cold. The web site says
    SeaSuckerís vacuum mounts typically arenít affected by heat. Cold, however, does cause the rubber of the vacuum pad to stiffen. This means that the vacuum pad must be warm when attaching it, so if it gets cold during use and you detach it, youíll have to warm the vacuum pads before reattaching it.
    Which means... I have to leave them on the car and risk them getting stolen while skiing? But it should hold otherwise? And what does 'cold' mean to a Floridian? Below 40 degrees Fahrenheit? Below 0F?
  16. #116
    Look at my post #24. If you leave em on while skiing they should be fine (have worked for me) but the plastic does get harder and any loss of air results in it being a little stiff so you might not be able to vaccum them back up. If you take them off and put them in your car usually they stay warmer depending on how cold it is outside. What I do is if I plan to take em off I just take a little thermos with hot water to soften them. Works good and helps me attach them when I take them off. Most times I leave em on though and haven't had a problem yet although I've never been at below freezing Temps while snowboarding.
  17. #117
    Feb 2012
    Quote Originally Posted by ProEdgeBiker View Post
    What did they revise on the pumps with white cups?
  18. #118
    PROEDGEBIKER.COM
    Quote Originally Posted by mbmtb View Post
    We dont have anything to worry about in FL, its mostly for freezing weather.
  19. #119
    PROEDGEBIKER.COM
    Quote Originally Posted by TenSpeed View Post
    The internals so they dont crack as often as they did.
  20. #120
    Nov 2013
    Right, in Florida you don't go skiing... but what about places where one might want to ski? I guess I can find out since I plan on being someplace rather cold (say 10-20 deg F) next week, but probably have the backup of stuffing skis into my car.
  21. #121
    Nov 2013
    fyi the seasucker held on pretty well down to zero degrees farenheit; i installed it above freezing. didn't put any load on it that cold since i wasn't sure it would work but the rack itself stayed on.
  22. #122
    Nov 2013
    oh yeah this is a photo thread...
    materials: seasucker cup (i left the velcro attached). 1"x1"x1" plastic cubes i had TAP plastics make (maybe HDPE), then I drilled holes in the center, 1/4" 20tpi bolts from the hardware store.
    if someone else does this... use a bigger spacer. and use a drill press, though the HDPE is soft enough that the off-squareness I have might just act as sort of a lockwasher.
  23. #123
    Reputation: Trekmogul's Avatar
    Jun 2014
    Seasucker in jungles of Sri Lanka
    SeaSucker Bike Rack Owners... POST YOUR PICS!-seasucker.jpg I never had so many stares as i did while riding through the jungles of central Sri Lanka with my Seasucker attached to the roof of my rental car. People were pointing and looking like heck. It works fantastic in hot and humid weather
    Trek Equinox 9.9 TTL, Trek Madone 6.9 Project One, Trek Fuel 9.5, Trek Fuel 9.0, Trek Rumblefish Pro, Trek Remedy 9.9,BGXX1
  24. #124
    Jun 2014
    Video Seasucker
  25. #125
    Jun 2014
    Here is what i believe is the first Seasucker in Sri Lanka
