Results 1 to 10 of 10
    Feb 2013
    Cutting Yakima round bars
    So I have a Yakima roof rack setup on order (Q-towers). My father gave me his older Yakima round bars, still in great condition. However, the bars are nearly 70in. long. I need to shorten them to around 50in.
    What is the best way to do this?
    Pipe cutter? Hacksaw? Both?
    -Thanks in advance
    UPDATE: Thanks for all the suggestions guys, ended up using a hacksaw per recommendation of local Yakima dealer. Took a bit of elbow grease but it came out just fine. Slightly uneven cuts, but with the end caps on you can't even tell.
    Feb 2013
    Pipe cutter if you have one. I used a Dremel to cut my Thule bars with ease.
    code: mtbr2011
    Reputation: cracksandracks.com's Avatar
    chop saw is best, but you can even use a hacksaw, but it will have a tendency to be crooked.
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    Quote Originally Posted by cracksandracks.com View Post
    ...you can even use a hacksaw, but it will have a tendency to be crooked.
    bingo. you want it straight and clean to get those end plugs back in. based on the options listed slowjams, pipe cutter is perfect.
    Put the whole thing together and try the long bars before you cut them down. You're only trimming 10" on each side, so its not like an airplane wing. The longer bar can be nice to have and functional. As they say, you can't cut them longer!
    I used a sawzall reciprocating saw and it came out just fine and accepted the end caps. If you hold the bar steady (suggest putting it on a step and then putting one foot on it), it's not big deal to cut it straight. I've done it several times and never had a problem. In fact, for all my cars, I have cut the bars to fit each specific car so it looks better. Done it with both Thule and Yak bars.
    The biggest problem is knowing how to use the tools. If you can do that, straight isn't an issue.
    J.
    Jan 2009
    Just wrap the bar with a piece of masking tape so you have a line to follow with your hack saw.
    The end cap will hide any sins.
    Good luck.
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
    Reputation: OldZaskar's Avatar
    Oct 2007
    Quote Originally Posted by J_Westy View Post
    Good luck.
    ^this^
    I used a zaws-all and followed the tape line. looked factory-clean when I was done.
    Mountain bikers who don't road ride are usually slow.
    Roadies who don't mountain bike are usually d***s.
    RTM
    RTM is offline
    #1 Latex Salesman
    Quote Originally Posted by OldZaskar View Post
    ^this^
    That's fantastic guys, except he didn't mention having a saws-all in his original question. How about a plasma cutter or lasers?
    i like rocks
    Reputation: euroford's Avatar
    cutoff wheel in an angle grinder, then clean it up with a flap disc.
    -1 mancard point for not having basic metal fabrication tools/skills
    Tim M Hovey
    Nukeproof Mega 290
    1950 CJ3a
    1999 BMW 540i
    1999 F350 PSD
    A pipe cutter works great for the tubing, but tears up the plastic coating. Masking tape works to get a straight line, Zip ties and hose clamps are easier to get on perfectly straight to use as a guide for a hacksaw. The trick for using either a hacksaw or sawzall is to make sure the pipe is held steady (bench vise, strapped solid to a table, strong friends).
  1. Cutting Carbon Bars
    By ironlegsracer in forum All Mountain
    Last Post: 11-19-2012, 08:46 AM
  2. Cutting Carbon Bars - Any tips?
    By mt11 in forum General Discussion
    Last Post: 08-26-2011, 09:45 AM
  3. Cutting down bars on a new bike
    By eastcoastrider in forum Beginner's Corner
    Last Post: 08-09-2011, 06:28 PM
  4. Cutting down bars, what tool?
    By big_slacker in forum Downhill - Freeride
    Last Post: 03-19-2011, 10:42 AM
  5. cutting carbon bars?
    By adarn in forum Tooltime
    Last Post: 02-27-2011, 10:18 AM
