Page 48 of 65 FirstFirst ... 3844454647484950515258 ... LastLast
Results 2,351 to 2,400 of 3232
  1. #2351
    Aug 2014
    54 1/4" wide
    downhill502, FYI, the rack measures 54 1/4" wide (love it) !
    don't tell me, "Show Me " !
  2. #2352
    Reputation: downhill502's Avatar
    Feb 2012
    Quote Originally Posted by jp08865 View Post
    rdb
    rdb is offline
    One up maintenance and lubrication
    I've had my 1up for about 6 months now. This is a long thread and I read the whole thread before I purchased the rack. I have been completely satisfied with the rack, well worth the investment.
    Last couple of rides the wheel arms were making a squeal when opening and closing and it was getting difficult to open and close them, so I decided it was time for some maintenance. I believe this may have been covered previously in the thread, but at 95 pages and increasing, I thought it wouldn't hurt to post another. I have attached two photos labeling what I call the ratchet strut, ratchet lever, and wheel arm. I checked 1up's website and couldn't find any FAQs about maintenance. If I missed it, someone please post a link.
    Bushing A in the picture is designed to bottom out before getting too tight. I loosened it to see if that fixed my problem, it sort of did, so I tightened it back down and then hit it with a spray of Tri-Flow and the wheel arms starting moving a little better. I also had to spray some Tri-Flow on both ends of bushing B. Now the wheel arm opens and closes super smooth, just like new. No problems closing the wheel arm tight against the tire.
    I think the issue is when bushing A starts to stick, the ratchet strut won't pivot freely when opening the wheel arm and ends up forcing the ratchet lever from parallel with the wheel tray. The ratchet mechanism then "digs in" making it difficult to open the wheel arm, there is not enough mechanical advantage with the ratchet lever for your fingers to easily overcome the ratchet strut friction. When closing the wheel arm, the ratchet strut forces the ratchet mechanism to "dig in" in the other direction, the ratchet spring isn't strong enough to overcome the friction in bushing A, making it difficult to fully close the wheel arm against the tire.
    In the second picture I show how I hold the ratchet lever parallel to the wheel tray when opening the wheel arm. The picture is a little tilted, but the lever is parallel to the wheel tray. I usually have my gloves on and put the ends of a couple of fingers under the wheel tray as a guide and then use the other fingers to lift the ratchet lever. When bushing A started sticking, I had to start holding the ratchet lever knob and keep fiddling with the ratchet lever as I opened the wheel arm. With the friction gone, I just let my hand slide along the bottom of the tray, keeping the lever parallel.
    I don't think the Tri-Flow will harm the bushings. There may be better lubricants, but Tri-Flow was what I had hanging around and seemed to work well in this application. WD-40 may work, but WD-40 is more of a temporary lubricant and I wanted to go with something a little more permanent.
    Attached Thumbnails Attached Thumbnails 1up Quick Rack Quick Review.-rachet-strut_reduced.jpg
  4. #2354
    Your Best Friend
    Reputation: Silentfoe's Avatar
    WD-40 is NOT a lubricant. Keep it very far away from your 1 Up rack.
    I'm a mountain bike guide in southwest Utah
  5. #2355
    Quote Originally Posted by Silentfoe View Post
    Actually it is a lubricant as well as a cleaner. It's a very light penetrating oil but only for very light lubricating applications. Go look at their website.
  6. #2356
    Your Best Friend
    Ah, the age old arguement that it is also a lubricant. It is a solvent, with a light lubricant. Once again, keep this very far away from your rack and your bike.
  7. #2357
    huh? It's light lubricating oil in an evaporating solvent. not exactly rocket science.
  8. #2358
    Trail Ninja
    Reputation: Varaxis's Avatar
    Quote Originally Posted by JohnJ80 View Post
    Well, it was created by using science, originally for rockets... so, in a way... JK JK!
    +rep for your effort to dispel the unreasonable WD-40 hate.
  9. #2359
    Jun 2010
    My trays are several years old and I have never lubed them, I do hose them off once a season though. OTOH, my rack always comes off and is stowed in the garage between rides. I see one other local car that always has the 1up in their hitch and scratch my head as to why when it's so easy to remove, I mostly see the car parked in an overly cramped indoor hospital parking lot, which happens to be the same one, due to its cramped spaces, that has led to many scrapes on my bumper and dings on my doors.
  10. #2360
    Feb 2006
    Quote Originally Posted by edthesped View Post
    OTOH, my rack always comes off and is stowed in the garage between rides. I see one other local car that always has the 1up in their hitch and scratch my head as to why when it's so easy to remove...
    I leave my rack on year-round. I ride 2-5 times per week so constantly removing and reattaching would be a pita IMHO. Rack still looks and functions great after 2 years of ownership. There is some aging on the lock bars and pivot bolts but just cosmetic. All aluminum bits still look awesome.
  11. #2361
    Jun 2010
    I too ride that frequently, but then again if I'm going for a full day ride I pop the rack and toss it in the trunk. I guess I'm well versed in removing and installing it as i can do either in under two minutes.
  12. #2362
    I almost never remove mine. My garage is so small, I have a hard time storing it out of the way. I can think of a couple of ways, but how do you store your 1up rack?
  13. #2363
    Jun 2010
    Quote Originally Posted by hatake View Post
    I have a cheapo Ikea set of shelves that i put them on.
    edit: These are the shelves I use.
    I have a 2" double 1up rack and 1 tray on the bottom shelf and a 1 1/4 single rack and 1 tray on the second shelf, (I use the 1 1/4 rack with a second tray mostly as I no longer have a vehicle with a 2" receiver) Not that it matters much but I have 6 shelves on my unit not 4 as shown in the picture.
  14. #2364
    Reputation: PerfectZero's Avatar
    Has anyone tried moving the pins at the ends of the arms? This seems super easy to do, but as usual I'm hesitant to change anything from the factory setup. I loaded up my 26er for the first time yesterday and found the arms almost get jammed perfectly under my rotors.
    buzzes like a fridge
  15. #2365
    Your Best Friend
    If you are running a 26er most of the time and your friends are also riding them, it would be worth your time to move the bolts. Otherwise you should just make sure you center the bike on the rack better and it won't get so close to the rotors.
  16. #2366
    I just got my 1up quick rack with an add on and am loving the quality and how sturdy it is. I have read this complete thread and have seen many people post about using a u-lock to prevent theft and as a device to stop the rack from sliding out if the retaining bolt loosened up. I haven't seen this mentioned and it may be a new feature, but where the security allen bolt is to secure the rack to the hitch the 1 1/4" tube protrudes a bit (3/4" or so) and there is a hole drilled through it where it appears you can add a pad lock, effectively blocking anyone from removing the rack if they happened to have a tool. Has anyone noticed this on that latest racks?
  17. #2367
    Here is a picture of what I'm talking about above.
  18. #2368
    Jan 2009
    Quote Originally Posted by C-Note View Post
    This feature was on the add-on adapter I just received too.
    Since it's not shown on their website, my guess was that it's for a long-shank padlock? Good idea I think!
    [WTB] 1987 Cannondale SM800, 20", Pink with airbrushed graphics.
  19. #2369
    That is my feeling too. Fixes the issue of some one with a "security" allen wrench form taking the rack, but does not keep the rack from moving if the bolt comes loose. Coming loose is not something I am really worried about and personally I think the velcro strap would stop the rack from falling out. I just wish they had a hole like this to lock the rack and the add on tray together as those bolt could easily be removed with vice grips or the like.
  20. #2370
    Finally joined the hitch rack and 1up group after years of putting bikes inside my car. There's been 90 pages of glorifying the rack so I won't say much more than the hype is real, and this is one of the best bike related purchases I've ever made.
    I do have a question for any other prius owners, how much depth does your 1up have into your receiver? It seems like an excessive amount of the rack is showing, but I don't know if that's normal for the small class 1 hitch receiver.
    Sorry about potato quality cell phone pic.
  21. #2371
    Reputation: tonyride1's Avatar
    Welcome to the club. I just got a fat bike adapter for my rack.
    2013 Giant Trance X 29er 0
    2015 Motobecane Sturgis Bullet
    2015 Giant AnyRoad 1
    2016 Diamondback Catch 2
  22. #2372
    unrooted
    Reputation: unrooted's Avatar
    Just spent a pretty chunk of my Tax Return (which still hasn't been accepted by the feds. . .)
    Got the 1.25" rack and the add-on in silver. Going to use it on both my Pontiac Vibe (aka toyota matrix) and my Tacoma.
    My wife has a hell of a time getting her bike onto the top of the Tacoma shell (we have a platform bed in the back). I really like not having to take the wheels on and off, and trying to find a place to store the wheels and not worrying about the discs getting smashed by something in the back of our truck/car. Now we just need to pay even more attention when backing up. . .did you read that babe?
    195 lbs-6'4" Banshee Prime XL
    Ride Mammoth, Tahoe & Vegas
    PLEASE GIVE ME NEGATIVE REP!
  23. #2373
    djrez4
    Reputation: djrez4's Avatar
    Quote Originally Posted by Fluidworks View Post
    Welcome to the club!
    Doesn't matter how much is showing. Only matters how much is inserted - at least 4.375" with the ball inserted at least 2".
  24. #2374
    Reputation: Jmp450's Avatar
    Aug 2014
    Hi was wondering who has one here in Vegas. My question is how has it held up shuttling up and down bootleg, does it hold the bikes securely going up and down that rough ass dirt road? Thanks in advance guys.
  25. #2375
    Your Best Friend
    It is off road rated. I don't know of any other rack that can claim that. We beat the crap out of a Thule T2 and a 1up on the White Rim in Moab. The T2 didn't make it out unscathed and the bikes on it took a beating. The 1up just needed to be rinsed off and the bikes were perfectly fine.
  26. #2376
    Aug 2014
    Good to know been really interested in getting one. Thanks for response.
  27. #2377
    I don't know the link but I recall seeing a vidoe on youtube of a Jeep Wrangler with a 1UP rack carrying at least 2 bikes jumping a dirt ramp and caught some air, landed, and rack and bikes were fine. I think it was a 2" receiver version, not the 1-1/4" with an adapter.
  28. #2378
    unrooted
    Quote Originally Posted by Jmp450 View Post
    That rack will out-last your vehicle. . .guaranteed!
    I can't imagine shuttling at Bootleg, the "XC" trails are so fun, up and down!
  29. #2379
    Aug 2014
    I agree all the trails out there are awesome we do both pedal from bottom and shuttle we mix it up. Thanks for all the feed back guys. Pretty sure gonna pull trigger on it next month.
  30. #2380
    There is a picture in this thread some place that shows a truck that rolled with a 1up rack with a bike in it and the rack and bike survived. That is saying something.
  31. #2381
    Oct 2007
    I've looked through the last 20 pages but I couldn't find a reason why the black is $50 more than the silver. I have been debating on the T2, Sherpa, or 1up. But I definitely like the 1up most so far just trying to figure out how to justify why black is more expensive.
  32. #2382
    Aug 2014
    I saw that. Just it's expensive so just getting more reasons to justify price lol.
  33. #2383
    unrooted
    Treating aluminum, whether it be painting or anodizing, is going to require a bit more for the manufacturers.
    I think the black looks great, but I remember somebody in this forum saying that their black rack started to fade, while the raw aluminum ones look great after years of use.
    The fact that the 1up is cheaper than many of the plastic racks from Kuat, Thule and Yakima is reason enough to buy the 1up, being that the 1up is made in the US out of all metal parts sealed the deal for me!
  34. #2384
    Aug 2014
    kylen721, I felt the same way, so I saved $50 and purchased the silver.
    Best rack I will ever have !
  35. #2385
    Oct 2007
    I just really hate silver for some reason. Dark Gray car with all the chrome blacked out I just can't put a silver rack on it.
  36. #2386
    Aug 2014
    Quote Originally Posted by kylen721 View Post
    I'm in the same boat, have dark car and black trim, and like estethics. But the more I thought about it, I don't really want my rack to blend in to the vehicle. I'd rather have it more visible as I live in a populated area with lots of traffic. Just feel it's less chance of some daydreaming tailgater ramming it. Loaded it up with DOT tape reflrectors so it is highly visible at night. It is designed well enough to unbolt it, fold it up and put in trunk in about 3 minutes when not using it.
  37. #2387
    No Clue Crew
    Apr 2005
    I was probably the person talking about fading. I bought a black one a couple years back after selling my silver one to a buddy (who's still using it).
    Not sure if they've changed the process, but mine faded really quickly to something of a rubbed bronze finish almost. I leave mine on all the time and live in the AZ sun, but it's something to consider.
  38. #2388
    Your Best Friend
    The anodized ones faded and they no longer do it that way. Now they powder coat them and the paint chips off.
  39. #2389
    Nov 2013
    I got mine a couple weeks ago, and couldn't be happier with the decision. I am switching it between mine and my wife's car, one with 1 1/4" and one with 2". It's a breeze going back and forth.
    I also got an add-on and the fat bike adapters. I'm slightly nervous about it somehow working its way loose from the receiver, even with the velcro strap. I haven't scoured this whole thread, but I assume that this is just me over worrying.
    I guess my only complaint would be that swapping the fatbike spacers in and out isn't a trivial process. I just got my fatbike, and have no plans to ride it much in the summer over my other bike... but plans change. Anyone use the fatbike spacer kit all year round and with other bikes (road and skinny MTB)?
    Obligatory photo:
  40. #2390
    Your Best Friend
    Yes, just leave in the fat bike spacers. It still works with road bikes.
  41. #2391
    Nov 2014
    Quote Originally Posted by Blatant View Post
    Hey, Blatant...Where in AZ do you live? I'd love to see what your's looks like in person if you are in the Phoenix area. I've been looking at these racks for a month now but sure would like to see one in person before spending the $$$.
    Thanks.
  42. #2392
    No Clue Crew
    Apr 2005
    Scottsdale. All you have to do is go to South Mountain and/or any of the PMP parking lots on a busy morning. Seems like half the riders in AZ sports One Up racks these days.
  43. #2393
    unrooted
    The biggest reason I'm getting a 1up is due to all the Kuats I've seen in Tahoe, the look like crap after a short period of time. The rubber/foam material Kuat uses is way too fragile.
    All of the 1ups I've seen pretty much live on the vehicle and look great!
  44. #2394
    Feb 2006
    Quote Originally Posted by unrooted View Post
    I live in the North East and mine stays on my truck all year round. Aside from a little oxidation on the slide lock bars and the nuts/bolts - all still looks and functions perfectly.
  45. #2395
    unrooted
    Heading to Vegas for the weekend tonight! Unfortunatley only my wife gets to mountain bike cause I'll be rock climbing. . .
    Attached Thumbnails Attached Thumbnails 1up Quick Rack Quick Review.-image.jpg
  46. #2396
    Aug 2014
    Well you guys convinced me decided to join the club and placed order for the rack.
  47. #2397
    Colorado
    Reputation: ltspd1's Avatar
    Nov 2007
    Quote Originally Posted by Stryder75 View Post
    Finally purchased a 1up and wish I had done it years ago! The rack is a machined piece of art and is such a pleasure to load and unload. I am coming from a fork mount roof rack with a quick release fork bike. I decided when I got my new ride with thru axels I wasn't going to do the roof rack front wheel removal with adapter crap. Wish I had come to that conclusion sooner. Great rack and I will be getting an add on soon.
    Attachment 913863
    Stryder75; can you or any other Outback owners tell me if you're able to put the rack up in the vertical position (1 or 2 bike config) without hitting the rear of the vehicle? I plan to leave the rack on all the time, so this would be a major consideration as to whether I go with the 1up. Thanks much.
  48. #2398
    Colorado
    Nov 2007
    Outback owners; can anyone tell me if you're able to put the rack up in the full vertical position (1 or 2 bike config) without hitting the rear of the vehicle? I plan to leave the rack on all the time, so this would be a major consideration as to whether I go with the 1up. Thanks much.
  49. #2399
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Mine stays on pretty much all year, too. No plastic to fade.
    I'm debating buying the fatbike spacers for my 2nd tray. I don't own a fatbike but I've borrowed one a couple of times, and it sucks to have a rack that doesn't work.
    "Back off, man. I'm a scientist." - Dr. Peter Venkman
    Riding in Helena? Everything you need to know, right here.
  50. #2400
    Quote Originally Posted by ltspd1 View Post
    I don't have an Outback, but a Forester and I have a two tray system and am able to fold up the rack without hitting the bumper with no problem, the best part is you only have to fold it down to the half way mark to open the hatch...the bad part is it fully covers the license plate when folded up. I don't leave mine on all the time, so I got one of these to go with the rack so I can put it in the exact same spot every time. 1UPUSA.com :: 1 1/4" Hitch Bar Stop
